Old 07-13-2018, 11:17 PM   #29
ermax
ermax's Avatar
Well, why do some believe that 7 psi oil pressure at idle is not sufficient for this engine under normal use conditions?
How low does the oil pressure in this engine have to go, at idle, before the engine suffers damage?
Hell, engines have ran for years with the rod bearings just being splashed on.
Hey, it's Friday night
I believe the dummy light is set to 4.5psi which basically just tells you your engine just blew. Hahaha.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (07-13-2018)
Old 07-13-2018, 11:57 PM   #30
Oh, well, if that's the case, the difference between 4.5 and 7.3 psi, don't leave much margin. Just about one hiccup of the oil pump.
So, I wonder why the manufacturer didn't put a bigger gear on that pump?
Old 07-14-2018, 12:29 AM   #31
Do you have documentation that says these engines automatically blow up at 4.5? In fact can you show us anything at all that says there are oil pressure issues with this engine?
Because the very highly skilled team of engineers that designed and built the engine didn't feel the need?
humfrz (07-14-2018)
Old 07-14-2018, 12:43 AM   #32
Old 07-14-2018, 06:23 AM   #33
ermax
ermax's Avatar
Spun Rod Bearing Warranty Service
No documentation. I’m just poking fun that 4.5 is unusually low for most engines.
As for oiling problems it well documented and I will link to a thread dedicated to the topic. I’ve linked to it before but apparently you haven’t looked at it.
FA20 Engine Oiling, Bearings, and Starvation
https://r.tapatalk.com/shareLink?sha...3&share_type=t
I know what your first response to this thread will be. “They are talking about it racing”. This is true but look at how much track time other cars are capable of without having to do extensive mods to the oiling system. I’ve tracked every car I’ve owned and none of them had issues. On the other hand my FRS spun a bearing on the freaking highway.
Yes a highly trained team designed this engine. That doesn’t mean it can’t have flaws, come on.
I’m not going to follow you into a rabbit hole though where you argue just for the fun of arguing. Been there done that with you.
Old 07-14-2018, 06:36 AM   #34
ermax
ermax's Avatar
Because it’s just idle. The car jumps much higher as it comes off idle.
The FA20DIT has a larger pump and it’s been tested in the FA20 and had no impact on pressure. It doesn’t seam to be volume that’s the problem but a biasing issue between the hydraulic lifters, cam gears, bank1 and 2 and even a difference between rod bearing 1 and 4 vs 2 and 3. 1 has a dedicated oil path through the crank and so does 4 but 2 and 3 share a single feed. The feed is a tad larger but very slightly.
Tcoat’s been inside this engine. He can probably provide more details.
humfrz (07-14-2018)
Old 07-14-2018, 07:02 AM   #35
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Just as a point of reference my 1988 Toyota Pickup with the venerable 22R engine the spec was 4 psi at idle. Mine always idled about 20 psi. Usually 60 when running on a mechanical gauge.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
ermax (07-14-2018)
Old 07-14-2018, 08:17 AM   #36
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by EddieZ2 View Post
Considering oil pressure and temp gauge since these engines are oil sensitive.
For temp I just use Torque Pro and add the oil temp PID
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
EddieZ2 (07-14-2018)
Old 07-14-2018, 11:43 AM   #37
You are cherry picking the info from that one thread and ignoring the rest of what they said. They say outright that these issues will not be seen on a street car. Anybody that are running the numbers they are most certainly needs to be concerned. You need to go and read the threads where stock engines spun the bearing. The people that reported back on cause have a totally different set of results than that one race team found.
I am not arguing this for the sake of argument. You are running around screaming the sky is falling and that every single one of these cars is going to spin a bearing. This is blatantly wrong based on all the facts that are known. I know it happened to you and that sucks but you are part of a very small and exclusive club not the majority. If you want to make broad sweeping statements then back them up with some real data otherwise I will indeed continue to post a counter point.
Yes the engineers can and do screw up. They also have access to the full dataset of failures. If there are enough failures to exceed what they deem acceptable they will make changes. They have not changed the oil supply system of the car. Unless you think that their accepted failure rate is 100% then your continuing assertion that this issue extends beyond a few early production cars is not supportable. It was a manufacturing flaw that a few have to suffer through not an engineering issue.
humfrz (07-14-2018)
Old 07-15-2018, 07:06 AM   #38
ermax
ermax's Avatar
You are so predictable. I knew you would point out the racing part of that thread. As I said, there are planting of cars that can handle casual track days without extensive oiling mods. It’s clear they are at weak at oiling. To think this will not transfer over to aggressive daily driving is crazy.
I never said 100% of them would fail. I said all years will fail because nothing has been changed.
But you are right, there must not be a problem because car manufacturers always make good on flaws. They’ve never been know to keep reusing bad designs.
Old 07-15-2018, 10:42 AM   #39
Of course I bring it up since they say it several times and it is the most relevant statement to the debate. They clearly say that the oiling issue they have is because it is an extensively built engine in a car used under extreme racing conditions. Even heavy track use will not reach those conditions and anybody driving in full race mode on the streets should be in jail.
They haven't fixed the oil pressure issue on stock because there is no oil pressure issue on stock engines. They did correct the manufacturing problem that impacted a tiny percentage of the 13s though. Simple as that.
Old 07-15-2018, 12:13 PM   #40
ermax
ermax's Avatar
The thread isn’t only about Element Tuning’s car though. The thread also rules out gload as an issue on this car so the only aspect of “full race mode” that applies is RPM. Are you saying anyone hitting redline on the road should be in jail?
Answer this. What car would be at higher risk as a daily driver, one that can only do track days with extensive oiling upgrades or one you simply throw good tires and pads and call it a day?
Never mind, don’t answers. You will not do it truthfully. I’ve regularly autoxed and done track days with all my cars and not a single one needed work done to the oiling to be reliable.
Old 07-15-2018, 12:21 PM   #41
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I'm just asking...... when you see a "spun my bearing" thread when do they not immediately go to an oiling explanation.
It seems to be a trend.
Old 07-15-2018, 01:31 PM   #42
I am not saying it was not an oiling issue. I am saying that the oiling issue was a manufacturing issue on a small subgroup of 2013 cars. Ermax's repeated statement is that it is a low pressure issue that applies to all years. There is zero data to support that stand and using one racing build thread to support it is false.
Stock Motor is Toast (Spun Rod Bearing) DFW-FRS Issues | Warranty | Recalls / TSB 78 02-13-2018 11:56 AM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 06:39 PM
Engine failure - Spun rod bearing TWICE dinoniel Issues | Warranty | Recalls / TSB 38 11-07-2016 01:17 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 03:17 PM
Likely hood of a spun bearing aquaman Engine, Exhaust, Transmission 14 02-24-2016 01:37 PM
