Old 07-13-2018, 02:30 PM   #29
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by nikitopo View Post
The dyno is what it is. A before and after measurement of a vendor's pulley kit installation. A 2-8whp increase depending the rpm range is not a huge difference. You might feel it a bit, but it will not change totally the car as I mentioned already. If your model cannot explain the result there are the following options:
1. Vendor doing the dyno is lying and favoring a bigger difference
2. Theoretical model is incorrect
You invited me here and I was polite to reply. What is the GTFO acronym? Please explain ...
Sorry - but the skeptic in me has to ask... About that pair of dyno plots that you posted. The plot on the left shows the Toda part resulting in almost 3x the torque of the std part at 3k rpm. Image is fuzzy, but it looks like Toda makes 11.5ish units to a few tenths above 4 units for the factory motor, right?
Keeping in mind that the factory bone stock motor is making roughly 135 ft/lbs at 3k rpm, I have to ask - Do You really believe the graph you posted? (hint: the pulley didn't triple the torque output at 3k rpm to 405 ft/lb).
There are more than just those two options, and it doesn't really matter which it is - that dyno plot simply makes no sense, the scaling is off, it's fake, who knows. But on this high strung 2.0L 4 cyl engine - That makes peak power at roughly 7K rpm, that graph is meaningless.
Joesurf79 is offline   Reply With Quote
Old 07-13-2018, 02:40 PM   #30
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It means "Get The Fuck Out" typically
MS, CSCS, TSAC-F, CPT
Old 07-13-2018, 02:43 PM   #31
86TOYO2k17
Drives: 2017 toyota 86
I didn’t realize the dyno you posted was Todas pulley set.
1. Yes all vendors lie and over hype their product.
2. Yes the Toda underdrive pulley set does work/make measurable gains. Bcs it’s underdriving alt/water pump, not bcs of its weight or being lighter. I assumed this thread was about weight reduction on pulleys. Not underdriven pulleys.
I have posted the math on previous threads. So I’ll just give numbers here.
15% underdriven alt pulley will had .65whp 15% underdriven water pump will add 1whp. Obviously 0 crank hp, but less parasitic leach from the two accessories.
I haven’t looked at the % Toda underdrives if it’s diff then the 15% fensport pulleys you can just do the conversion math.
Old 07-13-2018, 02:43 PM   #32
GT fucking O!
Old 07-13-2018, 02:51 PM   #33
mrg666
pessimistic skeptic
mrg666's Avatar
There are increased vibrations caused by the light crank pulleys that can lead to spun bearings. I wouldn't take that risk for such a small gain (if any). Installing a performance exhaust header, removing the spare tire, or using lighter rims (and/or others) can make much more difference.
Old 07-13-2018, 02:55 PM   #34
86TOYO2k17
That is why I am going to install a fluidampr with Fensport’s oversized “underdriven” alt/water pulleys. Best of all worlds!
Old 07-13-2018, 02:59 PM   #35
mrg666
pessimistic skeptic
mrg666's Avatar
I am planning to get the Fluidampr pulley as well (probably after JR dual radiator)
Old 07-13-2018, 03:50 PM   #36
gtengr
Drives: 2017 BRZ
I'm not convinced the alternator (at least on the +2017) is consuming engine power under load. My voltage spikes to +14 when I let off the throttle. Other manufacturers run schemes to eliminate alternator load under throttle, so it's not unheard of.
gtengr is offline   Reply With Quote
Old 07-13-2018, 03:52 PM   #37
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
@86TOYO2k17 You don't have a 1000lbs atlas stone and you shave 4lbs. Your engine revs much faster in 1st and 2nd gears with the same car weight, meaning that the crankshaft drives much less weight in these gears. Have you ever ride a bicycle? Do you understand the basic mechanism of gearing and the effect it has on your foot pedal?
And by the way Toda underdrives only the alternator and the gain is in the range of 1 hp max. The dyno shows more gains and it is not a 0 hp gain for the crank pulley.
@Joesurf79 I never try to explain a dyno on the very low RPMs. For the blue curve I can assume that the operator shifted differently from 2nd to 3rd gear and the dyno measured a range of RPMs without full throttle acceleration. What matters for me is above the 3.5k RPM area and the dyno is not fake: http://www.toda-racing.co.jp/en/prod...lley-fa20.html
@weederr33 Yes this is what I figured too. Why some people behave so childish on the pulley topic?
Old 07-13-2018, 04:27 PM   #38
mrg666
pessimistic skeptic
mrg666's Avatar
Check the independent tests of lightweight pulley vs. OEM pulley vs. Fluidampr below.
https://motoiq.com/fluidampr-the-independent-test/3/
There is no HP gain from lightweight pulley as @Subsonic has shown in the first post.
This has been discussed so many times before. All power gain claims are fake.
Old 07-13-2018, 04:28 PM   #39
gtengr
Drives: 2017 BRZ
Originally Posted by SuperTom View Post
-Wont give more dyno captured HP but allows you to reach the higher RPM's quicker, which means you are at the higher HP levels of your motor quicker.
RPM is related to the speed of the car though. If you're reaching the higher RPMs quicker, it's because acceleration has improved, and that would have to show up as a horsepower gain if true.
Originally Posted by wbradley View Post
at the very least it is true that in neutral there is a quicker response to throttle input therefore the lightweight pulley might allow for quicker rev matching.
When the engine isn't tasked with accelerating the huge lump of mass that it's attached to, the weight loss in a pulley may seem to make a difference. Under load, the power required to accelerate the mass of the pulley system is limited to the same rate of RPM increase that is set by the acceleration of the car. That is the key to why pulley mass is trivial beyond the static weight loss.
Old 07-13-2018, 04:33 PM   #40
Joesurf79
Joesurf79's Avatar
If youget to assume that the dyno operator wasn't full throttle on the stock plot down low in the revs, I get to assume the were sandbagging and not going WOT from 3K to 7.3K either lol! Where is the arbitrary point in your mind where you assume the dyno op went WOT for the factory pulley set up? Okay - Lets play devils advocate, then.
You posted the plot to bolster your claim (which honestly has no bearing as it's for a set of under-driven pulleys and the discussion here is about lightened pulleys), and now we only get to scrutinize the portion that fit's your narrative?
Cool - Lets say they were WOT from 5K to 7K we can agree on that then, right? The delta looks like roughly 5% more torque 5K-7K rpm. Are you telling me you believe their motor picked up 7 ft/lbs from 5K to 7K rpm? Sorry man, the math doesn't bear it out.
In fact here is a counter article on those types of power generation numbers with an engineering flavored layman terms explanation, vibration analysis (multiple orders), and dyno plot for each crank pulley tested. Factory, light weight, and a viscous type.
https://www.enginelabs.com/news/guest-column-fluidamprs-brian-lebarron-on-fr-sbrzwrx-dampers/
When you present a bunch of engineers, physicists, and other generally sharp, Alpha male technical types with a bs argument on a slow Friday at work, well...what more do you expect from the internet? Nothing more or less than what you got, as this isn't the first time we've kicked this car-forum hornet's nest, is it?
Old 07-13-2018, 04:34 PM   #41
Joesurf79
Joesurf79's Avatar
Read the article I linked to - in those tests, the light pulley actually killed power.
Old 07-13-2018, 05:42 PM   #42
tomm.brz
Drives: brz 2017 hksv2
But nikitopo says a pulley give 8 WHP.. And that is not a huge gain.. It must be true, you all other guys are lyers.
Do Lightweight Pulleys FREE Power? With Poll NonStopTuning Engine, Exhaust, Transmission 76 09-01-2015 12:03 PM
GrimmSpeed Lightweight Crank Pulleys! RallySport Direct Engine, Exhaust, Bolt-Ons 9 01-27-2015 12:02 PM
Lightweight Pulleys in Turbo application GH05T Forced Induction 8 12-05-2014 04:21 AM
FS: GFB style lightweight pulleys. dj petey Canada Classifieds 8 05-08-2014 09:40 PM
