#1345 |
Drives: Silver FR-S
#1346 |
Drives: 2016 White Pearl BRZ Premium
Jet Hot has a bunch of colors available for a minimal extra charge, and I figured why not. Make em pop
The car sees no road use (miserable unless at full song on track) so emissions compliance isn't even a fleeting concern ![]()
#1347 | |
Human
Drives: 2015 BRZ Black
I got an Ace 350 specific tune for OFT from @steve99. He charges a very reasonable amount (sub $50).
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#1348 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
I wish I would have known this. Maybe Steve99 can advertise this more. Can't look back as I've already spent the extra ~$800 on the ECUTEK/Delicious/Counterspace tune package. Already have an OFT could have saved some major cash!!!Would be cool for someone to compare a Steve $50 tune with this high priced package. Since many of us already have an OFT
| The Following User Says Thank You to SuperTom For This Useful Post: | smg1138 (06-07-2019) |
#1349 | |
Drives: Silver FR-S
Sent from my SM-G950U using Tapatalk |
| The Following User Says Thank You to Chamaco For This Useful Post: | valtore101 (07-13-2018) |
#1350 | |
Human
The tune dialed in the ignition/exhaust timing for the 350 header over the generic in the link above and fueling is the only thing that you might want to adjust (if at all). He added some other tweaks for me like quiet startup and the fix for petal lag. In my case the tune was simple as i had complete stock car other than exhaust. The only "mods" i did were a drop in high flow filter and sound tube delete which don't affect the sensor or airflow. A CAI will change the maf sensor readings and will have to be adjusted.
#1351 |
Drives: 2013 Raven FR-S
What are the different options for an OFT tune on this header? Are there good canned tunes out there or would I have to get Shiv to make me a custom tune?
#1352 |
There aren't. You'd need a dyno tune, and a LOT of dyno time, to truly unlock the potential of an ace header.
#1353 | |
I personally don't have experience but many said taking the Shiv method it could be days or weeks to just get a response on an email so keep that in mind. In summary the money for the CSG/DT is worth it in my opinion
#1354 | |
btr.life
Drives: 2022 GR86
Your best bet with an ACE header is the CSG ACE+Delicious tuning setup. Why skimp on the tuning when you are buying the best header out there?
#1355 |
Drives: 2023 BRZ
Has @steve99 done an OFT tune for this header?
Director of Rocky Mountain 86CUP
#1356 | |
2013 Series 10 FRS #553
#1357 | |
There's a reason revisions are included with every tune, and EVERY SINGLE ace/tune combo is revised until running to CSG/DT/Zach's satisfaction. One size fits all doesn't work if you're looking for the best. This isn't walmart, and you're not buying a suit off a rack; you're getting a bespoke suit tailored specific to your body, to make you look sharp. |
#1358 | |
Drives: UK GT86
Just find a local tuner who can dyno tune and pay for it or upgrade to EcuTek.
.: Stealth 86 :.
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
