Old 07-10-2018, 02:53 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Replace blue stuff now?
My '14 Monogram had 29K on it when I bought it three months ago. I have no service records, so I'm about to change out tranny and diff fluids. I changed oil to Mobil-1 5W30 and installed a Fumito drain plug. I think I saw in the manual that the coolant is good for five years, but it seems prudent to me to flush and change now. I see now there's red stuff that is supposed to be better than blue stuff. Anyone know anything about that?
Qwimby1 is offline   Reply With Quote
Old 07-10-2018, 03:03 PM   #2
Qwimby1
I should add that I went to a Toyota dealer and asked to see the coolant bottle. It said clearly on the back "For all Toyota engines EXCEPT, Scion FRS."
So much for what some dealers know.
They also wanted $35 for a cabin air filter that I got at O'Reilly for $15.
Old 07-10-2018, 03:18 PM   #3
Impureclient
Drives: 2015 FR-S
Pretty sure the Monograms run a special coolant so be careful.
The Following User Says Thank You to Impureclient For This Useful Post:
MJones_RB (08-08-2018)
Old 07-10-2018, 03:25 PM   #4
Changing the coolant wouldn't be necessary at this time, UNLESS, you think the previous owner might have topped off with the wrong stuff.
Yep, if you change it, I'd suggest you use the recommended blue stuff.
Old 07-10-2018, 03:26 PM   #5
You're be-in mean …
Old 07-10-2018, 03:29 PM   #6
Impureclient
Drives: 2015 FR-S
You're be-in mean …
Nah, I was just car joking around.
humfrz (07-10-2018)
Old 07-10-2018, 03:48 PM   #7
Qwimby1
The local Subaru dealer knew right away what to use. He mentioned it's good for 100,000 miles, but agreed you never know what the PO might have put in there. Mine doesn't seem to use coolant, even in hot Florida. Takes a little less than 2 gallons at $25 a gallon. Blue stuff for regular FRS's and violet for Monograms.
Old 07-10-2018, 04:11 PM   #8
extrashaky
Drives: 2014 BRZ Limited
Because it's a Subaru engine with a Subaru cooling system. Stick with Subaru Blue. You can flush it out and use another type of coolant, but you have to be sure you get all the Blue out, and then the maintenance interval becomes more frequent.
It shouldn't. Even open cooling systems are not supposed to allow coolant to evaporate. Apparently it's "normal" for some coolant to disappear during the engine break-in period (and both of my engines have done it), but I put that in quotes because "normal" is not always normal with this car. After break-in, it's not supposed to use coolant, and unexplained coolant loss would be a red flag for either a leak or a blown head gasket.
Old 08-07-2018, 02:33 PM   #9
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Pentosin Pentofrost A3 is the same thing and it's cheaper than the Subaru Blue, you can also buy Pentosin at Advanced Autoparts which is probably closer than a Subaru dealer.
Trueweltall is offline   Reply With Quote
Old 08-07-2018, 02:37 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My dealership wanted $39.99 for the cabin filter!!!! I ordered one off of ebay for $8.50 shipped.
I LIKE TIRES!
ToySub1946 (08-07-2018)
Old 08-07-2018, 02:46 PM   #11
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just remember to check coolant lvs once in a while, this engine runs hot & some of the coolant escape from radiator cap once you have some fun time with the car.
*which doesn't seem to happen after I got a oil cooler... O.o
Old 08-07-2018, 03:24 PM   #12
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
I'm tired of all this anal bullshit.
Warranty and Maintenance guide:
Engine oil: Change every 7500 miles, change filter as well. Use a full synthetic 0W-20 oil.
change engine coolant at 137,500 miles or 11 years (whichever comes first). Specified coolant: Toyota Super Long-Life Coolant {SLLC} BLUE.
Manual transmission oil. Inspect every 22,500 miles. Implied: Change never.
Automatic Transmission oil: Inspect every 15, 000 miles. Change every 60,000 miles.
Rear Differential oil. Inspect every 7500 miles. Implied: Change never.
I'm a former auto tech. The above is exactly how I I'm going to treat my car. If it does not like it, too bad.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
humfrz (08-07-2018)
Old 08-07-2018, 04:24 PM   #13
Welp, kiss your warranty goodbye -
Old 08-07-2018, 04:28 PM   #14
I agree 100% (for non heavily tracked cars).
And I'm a retired agronomist -
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
EBC yellow stuff/red stuff R3AP3R_Playz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-13-2016 05:37 PM
To replace rims or not replace? unlimited86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 09-21-2015 12:12 PM
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff CruiseControl Member's Car Journals 4 07-01-2014 05:53 PM
