Old 07-09-2018, 12:49 PM   #71
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by SuperTom View Post
Yeah but you don't understand this kit has rotors that are thinner than stock. The first guy to use them was named Swift(something) he was supercharged. He said they were ok at first but with that much extra power needed something more.
If I went FI I would be going with a Bigger Brakes, wheels/tires, clutch ect
I know it has slightly thinner rotors. I am not tracking my car and I am just trying to save weight while maintaining the similar braking power. This is just for daily driving on the street. If it has the power to stop WRX, my car is lighter than that. My concern was disturbing the front/rear balance and since you didn't replace the rears, I wanted to get your opinion. I might go with RR racing or AP Racing @new2subaru recommended.
Old 07-09-2018, 12:56 PM   #72
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Ok cool. Im at work but I did have a file saved at home. This WRX kit had the closest to stock bias while using stock rear brakes. No worries on that.
Edit here is the article https://www.pointmeby.com/2016/09/24...z-frs-gt86-86/
There is a chart that shows the bias. Wilwood WRX is best the RR Racing is close too
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
mrg666 (07-09-2018)
Old 07-09-2018, 12:58 PM   #73
SuperTom
SuperTom's Avatar
Originally Posted by DaSilva3525 View Post
Thanks for the details, I musta been blind earlier to miss that link
My car will be down to 2350-2400 so more then enough
Damn that is great you are going to be really light. You must be stripping out the interior. I think I can get down to 2450 without doing that and some craftiness (aka $$$) on lighter parts.
Old 07-09-2018, 01:04 PM   #74
DaSilva3525
Drives: 2013 Brz
Correct, I will have one corbau fx1 still have carpet, then rear seats and trunk gutted, ac delete, light wheels, alum drive shaft, lightweight exhaust / hood exit sometimes, chromoly flywheel etc etc lol..
I will post a build thread shortly as it's enjoyable to see all the builds here and continue the tradition
DaSilva3525 is offline   Reply With Quote
The Following User Says Thank You to DaSilva3525 For This Useful Post:
new2subaru (07-11-2018)
Old 07-09-2018, 05:18 PM   #75
new2subaru
Weight Weenie
Drives: 15 FR-S
I have 17x8 konig hypergrams
16s will fit. on the website they say 15's may even fit
https://www.wilwood.com/BrakeKits/Br...temno=140-9193
Thank you! I don't know why I never found that info while searching...On a smaller more technical track they should work, I would think.
Especially if you knock a few hundred pounds of of the car.
Old 07-09-2018, 07:23 PM   #76
SuperTom
SuperTom's Avatar
That's the plan stay light my friend
Old 07-09-2018, 08:02 PM   #77
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
omg dude... your custom interior looks WAY better than stock. I have the same car! I was ok with how it looked like because I didn't know it could look any more better, but now...
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
The Following User Says Thank You to Lakitu For This Useful Post:
SuperTom (07-09-2018)
Old 07-09-2018, 08:15 PM   #78
SuperTom
SuperTom's Avatar
Thanks appreciate it.
I want to order the metal climate controls + speedometer rings.
Can't decide if I want the polish aluminum to POP or the gloss black to be Stealthy/Classy
What do you think?
https://www.aliexpress.com/item/High...ceBeautifyAB=0
https://www.aliexpress.com/store/pro...e5c04cba0mUmLo
Old 07-09-2018, 08:19 PM   #79
Lakitu
Lakitu's Avatar
I wish I was this good at modding. All I know how to do is buy boltons and install them :/
Old 07-09-2018, 08:22 PM   #80
Lakitu
Lakitu's Avatar
What do you think?
omg both look amazing, I think I would go more for silver aluminum look to offset everything else without standing out too much (red aluminum maybe too strong). black gloss does look nice on the knobs, imo
Old 07-09-2018, 08:27 PM   #81
SuperTom
SuperTom's Avatar
wont be going red on this build since the 86 threading is silver. I like the gauges in aluminum, the knobs in black. That's why I'm torn. I'm afraid the aluminum knobs will look too cheezy like an add on instead of a premium piece
Old 07-09-2018, 08:42 PM   #82
new2subaru
Weight Weenie
Drives: 15 FR-S
What do you think?
I did mine in Aluminum. IMHO it adds more depth.
Old 07-09-2018, 08:47 PM   #83
SuperTom
SuperTom's Avatar
UPS just delivered the HOLY GRAIL of NA mods!! ACE 350 headers and ECUTEK Delicious Tune From CounterSpace Garage!
Headers weight 9.75lbs
OVerpipe Weights 3.5lbs
INside Diameter at the end of the Overpipe is 60mm.
Took a 3 day weekend coming up to install these badboys. I will start off with my current Invidia FP & HKS catback but they are 56mm ID piping. I will eventually get a 2.5" FP & Catback to match up (should be 60mm ID)
This will take 13.25lbs off the FRONT
NEW estimated weight after install ~ 2534.75lbs !
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
mrg666 (07-13-2018), new2subaru (07-09-2018)
Old 07-09-2018, 08:48 PM   #84
SuperTom
SuperTom's Avatar
which one the gauges or the knobs or both?? got a pic you can share?
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
