Old 07-07-2018, 04:35 PM   #15
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by DarkSideFRS View Post
-1.7F and -1.3R
as long as the front has more negative camber, the car will be more responsive
Yep I am -2F , -1. Toe is close to zero as possible unless you want to chew up tires
SuperTom is offline   Reply With Quote
Old 07-07-2018, 04:37 PM   #16
norcalpb
norcalpb's Avatar
I ran 2 degrees front for a few years. After switching back to .4 degrees it’s anazing how straight the car drives on the highway now, but more steering input is needed to get the car turning.
Old 07-07-2018, 04:58 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
How straight now ..? Were you driving with toe off to one side?
churchx is online now   Reply With Quote
Old 07-07-2018, 05:26 PM   #18
norcalpb
norcalpb's Avatar
I always do 0 toe just because I drive on the streets 99% of the time. Sometimes tuner shops would do the whole rear toe thing in the rear but I never minded.
With less camber in the front I can let go of the steering wheel at 80+ mph and it’ll keep driving straight with less input than with the -2 degree setup.
Initial steering also seems heavier but that’s probably due to the tire having more surface contact going straight.
Heoever the car is not as fun on windy roads with less camber. I really have to turn the wheel to get the car to turn.
Old 07-07-2018, 07:50 PM   #19
carlovestela
Drives: 2015 Firestorm FRS
Whats your camber right now for rear?
I also have -0.4 in front.
Will the tire have even wear? Thanks
carlovestela is offline   Reply With Quote
Old 07-08-2018, 02:07 AM   #20
norcalpb
norcalpb's Avatar
I have 1.5 degrees rear camber, dialed it back after my 20mm drop.
I didn’t really notice any change in the wear, camber won’t really affect wear that bad.
Old 07-08-2018, 07:56 PM   #21
carlovestela
Did youchange your rear lca?
Old 07-08-2018, 09:21 PM   #22
norcalpb
norcalpb's Avatar
Yes to the Whiteline eccentric ones.
Old 07-08-2018, 09:29 PM   #23
carlovestela
You think mine was normal? -0.4 front. -2.2 rear?
Old 07-08-2018, 11:15 PM   #24
norcalpb
norcalpb's Avatar
Yes that’s completely normal with no adjustable bits. My rear camber was 1.5RL and 2.3RR after dropping 20mm. I got the control arms to even things up, which seemed to make the car drive straighter.
Old 07-09-2018, 12:02 PM   #25
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
Thanks for the help everyone! Had the alignment done this morning and she's handling great!
Geese1 is offline   Reply With Quote
Old 07-09-2018, 01:52 PM   #26
carlovestela
Whats yours?
Old 07-09-2018, 02:04 PM   #27
Vital
Drives: 2015 BRZ
Curious as well about your alignment specs. Just interested in seeing what kind of rear camber you had with the RCE Yellow springs.
Old 07-09-2018, 06:32 PM   #28
Geese1
Geese1's Avatar
Whats yours?
Ended up going with -2.0 camber and 0 toe up front, and -1.5 camber and 1/16th toe in rear. Of course, the shop didn't hit some of those numbers exactly, but everything was close enough that it shouldn't make a difference.
Don't forget as well, I had SPC camber bolts up front, and SPC lower control arms in the rear in addition to the RCE Yellow Springs.
Car was severely in need of an alignment after the parts install, especially the lower control arms, but luckily I work from home now so I don't need to drive the car on a daily basis.
Recommendations for alignment in Bay Area Surj_brz Northern California 9 06-09-2017 12:26 PM
Need alignment spec recommendations 8RZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-10-2017 09:53 PM
Alignment recommendations for my setup? sqd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-19-2016 01:33 PM
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Recommendations for alignment in Socal anewprelusion Southern California 18 01-13-2014 02:36 PM
