#57 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
So much yes. Silly bad drivers thinking their setup is better than the samurai made stock setup.
"Enjoying Performance because of it's nature not because of it's quantity''
| The Following User Says Thank You to TorontoNat For This Useful Post: | rvoll (07-06-2018) |
#58 |
The Angry Brown Guy
Drives: 2016 Tacoma & 2018 86 GT Black
| The Following User Says Thank You to BasementN3k0 For This Useful Post: | JD001 (07-07-2018) |
#59 |
Didn’t read the whole thread but tires are probably the only change you’re actually going to feel. My suggestion is to take the spacers off to prove it’s not the spacers causing the change you’re feeling.
#60 |
Drives: 2018 BRZ Limited, 2017 Sportage
Spacers are off and for sale. I can feel a difference. The car just seems tighter and tracks better. I guess each to their own. It looks better with spacers, but it's hard to see the wheels when you're driving and I'd rather have it drive better than look better... (As I've learned, mileage may vary depending on the owner....)
#61 | |
Interesting because the change in geometry is so incredibly small it’s essentially a cosmetic mod only. |
| The Following User Says Thank You to ermax For This Useful Post: | Summerwolf (07-07-2018) |
#62 | |
Oh, well, enough on this. Everyone will believe as they will in any event... |
#63 |
Drives: 2017 Toyota 86 Halo
Im personally not a fan of spacers just for the rare occurrence of failure (mainly with cheaper ones). However if you like the look, you should try running some up front as well as rear. Id bet the car would feel pretty similar to stock. Where as if you're only widening the front or the rear of course its going to feel a bit off.
#64 |
Drives: Subaru BRZ
The Gazoo GT86 rally car wears spacers...
#65 |
I googled the rally car and took a look. It looks just like mine WITHOUT spacers. There was one with brake vents that looked like it might have some spacers in it but not the standard one. All of the pictures of those that actually raced didn't look like they had spacers. On the rears, it's fairly easy to tell because there is some slight poke with 20mm spacers.
#66 | |
Drives: Subaru BRZ
See the order form. They have an option for 10mm spacers. |
#67 |
Drives: '15 BRZ RA
So, this is the TMG rally car. Not a Gazoo car. I have said it again, but I guess it is ok to mention it again. I would never give too much importance on a Japanese manufactured car modified by Germans. And yes, I live in Germany
. If I wanted such a car, then I would buy directly from a German manufacturer (BMW, Audi, Mercedes). By the way, I am not sure if this rally version ever made it to sell any considerable amount of cars. I remember some test runs with a development car, but I haven't heard much more. If I can recall correctly, only one team in Germany bought it (?). I am not sure if they still race with this one.
#68 |
Drives: 2014 GT86
In real rally cars (or rallycross) there is often very little left from original car. And if such heavy modified car is considered, imho it makes perfect sense to consider local shops to do the job. Not matter what original base car manufacturer is.
#69 | |
Drives: Subaru BRZ
#70 |
So I've read the posts that follow yours. It seems that the car you were referencing that had spacers was not raced much and turned like a pig. And you want to use that as a reference? And 10mm spacers? Really? I'm beginning to think that there is no good justification for using spacers at all. It just seems to be another ricer thing to make your car look more powerful than it is. And yeah, in the back of my mind, that's probably what was going on with me. Shame on me......
| The Following User Says Thank You to rvoll For This Useful Post: | JD001 (07-07-2018) |
| FS: Work Emoticon XD9s and spacers | san101 | Canada Classifieds | 0 | 07-30-2015 04:22 PM |
| Work Meister S1 3P 18x8.5 +48 comes with spacers. | Eelusive | Wheels and Tires | 17 | 08-23-2014 02:10 PM |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 05:19 PM |
| Spacers on Work Kiwamis? | JordanWho | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-14-2013 05:32 AM |
| Will WRX (GD) top hat spacers work on the BRZ? | chim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 02-12-2013 08:56 PM |
