Old 07-03-2018, 12:50 AM   #1
ImADuck
ImADuck's Avatar
Drives: 2017 Series.Yellow BRZ
Clunk noise from rear passenger side. Any ideas?
Been having a clunk noise coming from the passenger side rear suspension and it kind of sounds like as if I was running over a manhole. It happens even on flat ground. Also, either I can't hear it anymore or something, but it just goes away once I get on the highway. Some searching says either my ball joint is going out, sway bar link nut, or diagonal strut tower bar nuts. What else could it be? Should I continue to drive it? I don't have the tools to check under my car yet... Also, my car only has 7500k miles on it so I don't think it'd be the ball joint.
ImADuck is offline   Reply With Quote
Old 07-03-2018, 01:39 AM   #2
I'd suggest you drop it off at the dealer tomorrow morning (since it's under warranty) and have them fix it.
Let us know what was wrong.
Old 07-03-2018, 03:03 AM   #3
JMon85
JMon85's Avatar
Drives: 2019 WRX
Is your tpms light illuminated by any chance?
JMon85 is offline   Reply With Quote
Old 07-03-2018, 09:48 AM   #4
ImADuck
ImADuck's Avatar
I probably can't drop it off til this weekend. Should I continue driving it or swap cars for now?
Nope
Old 07-03-2018, 11:12 AM   #5
firekat
Drives: 2018 Subaru BRZ tS
This might "sound" strange - check the fold down seats. I have a brand new tS, I go down the hill I live on, which is pretty bumpy and I get the "clunks". Make sure those seat backs are properly latched. Mine are and still occasionally make sounds. It is disconcerting and irritating. The clunks sound more ominous than you would think. I better not have suspension problems, I have less than 1200K on the clock.
Oh, and on flat ground and the highway I don't hear it either. (Of course at highway cruise speeds this car is not what I would call quiet)
firekat is offline   Reply With Quote
Old 07-03-2018, 11:57 AM   #6
Nope
Well, that's a tough call.
If it were me, and didn't have any tools, I'd just make sure all the lug nuts were tight and carefully drive it till you get a chance to take it in to the dealer.
Old 07-03-2018, 01:35 PM   #7
ImADuck
ImADuck's Avatar
Hm I'll have to check that again. I've tried taking everything out of my trunk and re latching my rear right seat, but it still made the sound. I'll try relatching it again tonight to see if that fixes anything.
I made an appointment for this Friday. Ill check the latch issue that firekat brought up though to see if that's the issue. If not and it still persists, I'll probably just drive something else in the meantime.
I'll keep y'all updated on my findings.
Old 07-04-2018, 05:35 PM   #8
ImADuck
ImADuck's Avatar
Just a quick update:
I folded down my rear seats to see if that latch was causing the noise as per @firekat's recommendation , but it still made the noise. I have an appointment with the dealers for this Friday so, hopefully they can figure it out.
Old 07-04-2018, 10:55 PM   #9
firekat
Let us know how it works out.
Old 07-05-2018, 08:42 AM   #10
gravitylover
It could be something as simple as the jack or one of the things under the rear floor have come loose. Lift the cover, pull everything and reseat them in their respective spots.
Old 07-05-2018, 09:23 AM   #11
monkeybike
Drives: 86
http://www.ft86club.com/forums/showthread.php?t=13451
Good luck.
I've got a "tick, tick, tick" in the back somewhere that I can't find that I've had since new.
monkeybike is offline   Reply With Quote
Old 07-05-2018, 12:24 PM   #12
hmmm....I suggest you have another cup of coffee then re-read his post #7.
Old 07-05-2018, 06:17 PM   #13
gravitylover
Taking things out of the trunk not under the trunk floor I was getting more detailed
Old 07-05-2018, 06:54 PM   #14
hmmmm….point well taken....
If it is discovered that the clunking was caused by something lose under the trunk floor …… I'm ah gonna @ImADuck.
fan noise / passenger side itsfun Issues | Warranty | Recalls / TSB 17 03-09-2018 10:37 AM
Rear passenger noise over bumps enivid Issues | Warranty | Recalls / TSB 3 01-20-2015 09:55 PM
What is that rattling noise near the front passenger side window? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 7 11-03-2013 07:25 PM
WTB: OEM Rear Passenger Side Tail Light StarFox3 Want-To-Buy Requests 2 10-18-2013 02:47 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
