Old 04-18-2018, 12:42 AM   #43
Totalrecall
Drives: frs
I enjoyed this thread. 10/10
Totalrecall is offline   Reply With Quote
The Following User Says Thank You to Totalrecall For This Useful Post:
HKz (04-18-2018)
Old 06-29-2018, 10:40 PM   #44
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I just finished installing the 2017 engine into my 2013. Tried to start the car a few times but no go. I just started researching and found this thread. Dammit... I'm hoping an ECU swap for the 2017 one would work.
D-VO is offline   Reply With Quote
Old 06-29-2018, 11:49 PM   #45
steve99
Drives: FT86
You dont need to swap ecu all same hardware and 2017 ecu program not compatable with older security system
What codes if any is ecu throwing, do you have your original 2013 rom in ecu , if you flashed it eith 2017 rom security will likey lock out, flash back the 2013, they usually tgrow some codes related to imobiliser if this occurred you will need to loop pins 4 to 13 on obd for more than 30 minutes with ignition on to resync ecu to security
Ultramaroon (06-29-2018)
Old 06-30-2018, 08:10 AM   #46
D-VO
Oh hey Steve. I didn't realize you answered me here already. No I still have the 2013 ROM loaded. I haven't had a chance to read any codes yet. I'm gonna see if I can find someone with a code reader.
Old 06-30-2018, 08:48 AM   #47
steve99
Drives: FT86
If you got a tactrix cavle just download techstream, you dont need any drivers like vci as you can jist get techstream to use the tactrix drivers already loaded if you have used tactrix on same computer
https://www.ft86club.com/forums/showthread.php?t=35530
When you say wont start does it crank ? And is your car key or push button start
Old 06-30-2018, 12:48 PM   #48
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Aside from the arguments, really informative thread. Thanks.
Old 06-30-2018, 02:59 PM   #49
D-VO
It cranks just doesn't start. Mine is key.
Old 07-01-2018, 06:25 PM   #50
steve99
Drives: FT86
See if you can log rpm when its cranking if not check crank sensor
Old 07-02-2018, 08:03 AM   #51
D-VO
That techstream site is dead. Oh well. I have to find my tactrix connector before I do anything else.
Old 07-04-2018, 12:34 AM   #52
D-VO
@steve99 Ok, just checked for codes today. It is a P0335 Crankshaft Position Sensor A circuit malfunction. My concern is that I don't want my car to end up like the one mentioned in this thread. I wonder if there's a way to change it in the ROM and not brick the ECU instead of having to take the tranny out.
Old 07-04-2018, 02:15 AM   #53
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Which sensor and sensor wheel did you use? The newer 2017 or your old 2013 one?
JimmyMac is offline   Reply With Quote
Old 07-04-2018, 09:46 AM   #54
D-VO
The 2017 one is in there now along with the 17' crank trigger wheel. All the sensors and wire harness are from the 17'. I had to swap the alternator to the 13' though because the connector for it was on the main harness.
Old 07-04-2018, 01:11 PM   #55
JimmyMac
JimmyMac's Avatar
So you are using the new wiring harness with the 2013 ecu and drivers (other small computers to run injectors, etc.)?
Old 07-05-2018, 11:03 PM   #56
D-VO
All the factory stuff yep. I have the 2017 Fuel Computer on the engine.
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 06:39 PM
FS: FA20 Engine Sportsguy83 Engine, Exhaust, Bolt-Ons 12 03-01-2017 02:51 PM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 05:16 PM
Looking to buy FA20 engine ndreim Want-To-Buy Requests 0 12-15-2015 06:06 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 03:39 AM
