Old 06-30-2018, 11:38 PM   #1
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Car won't turn on!
So my car is having trouble turning on. It's a push start and when I go to turn the car on the electronics and radio turn on fine. When I press on the clutch and hit the push start the car just turns off, doesn't even turn over, almost as if the car is not registering that the clutch is being pressed and just turning off. Any ideas or has anyone else had this issue?
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 07-01-2018, 12:57 AM   #2
You may wish to check the clutch start switch. It may be loose, disconnected or burnt out.
Here is an active thread that talks all about it.
http://www.ft86club.com/forums/showthread.php?t=128398
Old 07-01-2018, 01:00 AM   #3
sato
sato's Avatar
Drives: Dodge Patitas
First off, I don't know how I landed on this thread
Have you checked the battery recently? An almost dead battery may be able to turn on accessories and/or lights. However, it may die immediately upon attempting to do so since starting the car takes a lot of juice. If it's not even trying to turn over, it could be in really bad shape.
My suggestion would be to have it checked out at your local AutoZone or PepBoys. If in need of a new one, those Optima batteries have given me good service life, and reliability.
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 07-03-2018, 01:04 AM   #4
BlOody_BoOger
So...turns out it was the clutch position sensor, all I did was turn the nut a bit where the sensor is mounted so that it sticks out a bit more, and gets fully pressed down when I step on the clutch. The only thing that sucked was twisting up all down there like a contortionist
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
