#8177 |
Tacticool_BRZ
Drives: ZC6 - AW11
#8178 |
Drives: 2014 WRB BRZ Limited
So Sprintex keeps offering rebates on this... last month it was a $1k rebate and now (for the next 3 days) it is a $1500 rebate.
I would get the 210 SPS, but I find that 1. I really would like the 335, but can't drop $10k to build the engine right now. Might decide to do that later... 2. The dyno comparison thread clearly shows that the Sprintex kit is great on the low end, but after about 4,000 RPMs the other kits like the Jackson Racing really out perform it. Convince me one way or the other? Those who have chosen sprintex, any regrets about not going with another SC kit? |
#8179 | |
Drives: 2017 toyota 86
I read the 335 is too big of a blower to use for low boost, meaning you need a built engine or it will be very inefficient running low boost. Also most of the dynos/dyno comparisons I see the 210 is on 7-9psi where as the other chargers are 9+, or ppl are on diff octane 91 vs 93 or cats vs no cats etc... not a 1 to 1 comparison. I would not be surprised if both running 8psi same octane if the sprintex ideal ifficiency was in that 7-9 range resulting in having the least parasitic loss to spin the blower meaning more max power and/or possibly having the power sooner meaning more power through out the powerband. I am sure someone may have the data/physics to back up or dispute these claims. But I think you are basically supposed to pick the smallest blower that can still handle the max boost you want to run and maintain it till redline. And for non built engines over 8psi is playing with Fire. I am basically in same boat as you deciding between sprintex 210 vs Edelbrock, Harrop, or possibly JRSC but I only want to run 7-8psi myself. So leaning towards sprintex. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | BR-ZED (06-17-2018) |
#8180 |
Drives: 2016 Ablaze Scion FR-S
Wondering if anyone else experiences this - sometimes when I am Rev match downshifting (car in motion, clutch in), a clicking sound comes from the drivetrain somewhere and the revs don’t go up as much as I expect, like a slight hesitation. It only occurs occasionally and can’t replicate at all in neutral. Does anyone know why this might be? Supercharger runs fine otherwise, no driveability issues. On stock exhaust if that matters
#8181 | |
Drives: 2013 Subaru BRZ Limited (Black)
VERY interesting that you mention this -- I just recently went back to stock exhaust (except for UEL catless header) and I have this same thing happen. I've always assumed the downshift spike in the revs was causing the engine to move within the mounts, and thus the exhaust was clanking against something real quick. Curious if we find out otherwise... |
#8182 | |
Interesting indeed...I wonder if it has to do with the stock exhaust being restrictive somewhere down th line. Do you definitely feel the occasional slight hesitation in the revs rising when you are rev matching? I was thinking maybe this happens with everyone but most people have aftermarket exhausts with this kit and maybe just don’t hear the little click, lol.
#8183 | |
#8184 | |
I've noticed that there isn't an issue if I 'squeeze' the gas pedal on the downshifts rather than stabbing it. This behaviour you're describing sounds exactly like what I'm experiencing but it only happens if I quickly stab the gas. |
#8185 | |
Drives: 2017 86
#8186 | |
Drives: 2018 BRZ tS
#8187 |
Drives: 2017 86
I removed the insulation on the inside of the hood and haven't had any issues. I have the intercooled version. Totally worth it.
#8188 |
PhoneFlash by EcuTeK
Hey Guys,
Just wanted to pop in and let all of you know that Phase 10 RaceROM is finally here for all model years and all regions of the world (Not just the initial 2013-2014 and 2017-2018 release), from 2013-2018 models on USDM, European, Asian, JDM (Yes it's different), and Gulf spec ECU's. Our entire tune library has been updated to accommodate the new software, and we are now rolling out these tunes to new and existing customers. A lot of our customers running Innovate/Sprintex kits have been asking about this update, so I wanted you all to be among the first to know that our Delicious tunes are all built up and vetted out for the new software. The latest version is denoted as V25.00. Though RaceROM 10 is really a complete and utter overhaul of the way we do tuning on these cars, some of the more important changes are as follows: - Improved tip in throttle response throughout entire rev range - Completely overhauled closed loop correction outside of factory closed loop scenarios - Completely overhauled Flex Fuel implementation. Ethanol content, ethanol ignition advance, and more are now all dedicated parameters in EcuTek. The way Flex Fuel is programmed is also far superior in RaceROM 10, and allows much tighter integration into the tune. What this means for the end user is a smoother transition between fuel types, and a smoother ramp in power delivery as ethanol content increases or decreases. - Dedicated custom map to warn you when your AVCS system has failed to activate in a timely manner, letting you know before you push the car and risk potential damage. - Vastly improved control over fueling in medium to full load areas. - Improved transition from low load MAF calculation to high load VE calculation. - Improved drivability. - Addressed a particular bug where some vehicles would experience a hesitation in high gear, partial (20-40%) throttle pulls. This was typically experienced when trying to pass on the highway, for example. If you have any questions about this update, feel free to contact me via email at sales@delicioustuning.com.com. This update takes what is already a great supercharger kit, and improves it more than we previously thought possible. |
| The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post: |
#8189 |
Drives: 2013 Scion FRS
Thanks zach!
ScreamingElectron - SnakeShit |
#8190 |
Drives: 14' Raven M/T - 02' is300
Is this kit still available? FT86SpeedFacyory has it labeled as discontinued and CSG has it labeled as backordered
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
