Old 06-28-2018, 07:35 PM   #1
Enrique_13
Drives: 2013 Subaru BRZ
Faulty Cat causing engine problem?
Hey guys I’ve had a faulty catalytic converter for about two months now, it’s the front one by the header, as described by my mechanic. After this finding, sometimes when I drive ( usually when I’m pushing my engine a bit more into 3000 rpms and higher, the rpms indicator starts rapidly going down and up. Almost like my car is in limp mode. To fix this issue, i usually pull over to the side and rev my car a couple times into at least 6000rpms and drive again. I’m not sure why this happens but it can be stressful as I have to drive slowly in order to avoid this problem happening to my rpms. I am about to purchase a new catted header so hopefully this helps. Has this happened to anyone before?
Enrique_13 is offline   Reply With Quote
The Following User Says Thank You to Enrique_13 For This Useful Post:
humfrz (06-28-2018)
Old 06-28-2018, 07:43 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
How did your mechanic make the determination that the primary cat was "faulty"?
Originally Posted by humfrz
I'm old and lazy
Old 06-28-2018, 07:50 PM   #3
Enrique_13
Sorry I forgot to specify a couple things. The first code that appeared was P0420 CATALYST SYSTEM EFFICENCY BELOW THRESHOLD (BANL 1). I have been getting a horrible 18mpg. However after a few weeks the problem above occurred and i got an ABS light, a traction control light, and a blinking check engine light. My next check I got these codes
C1201 Engine Control System Fault
C1294
U0073 Control Module Communication Bus Off
U0126 Lost Communication With Steering Angle Sensor Monitor
Old 06-28-2018, 08:03 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
C1294
U0073 and U0126 appears sometimes when someone plugs in something odd or faulty into the OBDII port. How many miles do you have? It's odd for a CAT to go bad 5 years in, did you have issues with burning oil or anything else like that? I would make sure you take it to a dealer that knows this car a bit better.
Did he Check the o2 sensors specifically?
Old 06-28-2018, 08:06 PM   #5
Grady
Grady's Avatar
Plugged cat????, cheaper to gut that bitch and buy a tune!
Old 06-28-2018, 08:09 PM   #6
Enrique_13
It has about 108,000 miles. I don’t believe so, but I figured since I wanted to get a new header anyway I would purchase it. And no issues with oil.
Old 06-28-2018, 08:39 PM   #7
DANG, Grady, you're big on gutting cats this week …
I'll betcha beck in the day, you were big on burning out glass packed mufflers ..??
Old 06-29-2018, 01:19 AM   #8
Enrique_13
I tried recording it happening , see what y’all think
Old 06-29-2018, 09:56 AM   #9
Grady
Grady's Avatar
Never burned them out but did have them on my 73 bronco with a 351 Windsor.
The Following User Says Thank You to Grady For This Useful Post:
humfrz (06-29-2018)
Old 06-29-2018, 11:08 AM   #10
Razorlor
Drives: 2017 BRZ Limited, Perf Package
Flashin CEL indicates a misfire, which poor exhaust flow can cause. Clogged cat doesn't sound out of the question.
If this happens at lower speeds as well. You could remove the upstream 02 and see if this problem goes away (creating a new path around the restriction).
Razorlor is offline   Reply With Quote
Which problem parts should be replaced while engine is out of the car? Asus Engine, Exhaust, Transmission 17 08-01-2017 11:02 PM
Replaced transmission fluid, now it's causing problem frslee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 11-02-2016 06:35 PM
Caster off, is this causing the problem? dem00n Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-18-2015 12:31 PM
CAI causing check engine light ZombieBadger Issues | Warranty | Recalls / TSB 13 01-18-2015 08:20 PM
