Old 06-28-2018, 12:16 PM   #155
DHitHim
Drives: 2015 CWP Limited BRZ
This is an awesome build. What was your swap budget if you don't mind me asking? I tried looking on your thread and I couldn't find it. I must've missed it if you did mention it in here.
DHitHim is offline   Reply With Quote
Old 06-28-2018, 02:37 PM   #156
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Thanks man!...there was no budget lol...spend until it’s done and then keep spending it seems on this build. I’m already upgrading the cooling fans that I had previously upgraded
ILLSMOQ is offline   Reply With Quote
Old 06-28-2018, 02:51 PM   #157
Ashikabi
Ashikabi's Avatar
Have you considered removing the front grill and getting a "drift armor" bar to increase front airflow?
Old 06-28-2018, 03:16 PM   #158
ILLSMOQ
No I haven’t, I didn’t want to remove the bumper. Also my giant oil cooler is mounted on the factory crash bar.
The fan shroud kit I have comes with 900 cfm spal fans. Spal makes the same fan with a larger motor that moves 1300 cfm, Spal also makes an 1800 cfm fan that has a slightly larger foot print. I ordered two of each to see if I could fit two of the big ones or maybe one big one and a smaller one, or just both smaller ones.
The cooling needs some help dealing with stop and go traffic type driving.
Old 06-28-2018, 03:24 PM   #159
Ashikabi
Ashikabi's Avatar
Add a radiator in the trunk lol. I don't recall, did you have hood vents?
Old 06-28-2018, 03:37 PM   #160
ILLSMOQ
No way that’s where the woofers go!
Lol. I have a siebon hood that has “some” vents
Old 06-28-2018, 03:42 PM   #161
Ashikabi
Ashikabi's Avatar
I suppose you could add more. Either a kit like Verus makes, or cut your own like I did
Old 09-13-2018, 10:18 PM   #162
ILLSMOQ
I’ll leave this here.
Old 10-16-2018, 10:47 PM   #163
ILLSMOQ
Engine was heating up during extended aggressive backroads driving on 90 degree+ days. Worked on some ducting to get more air through the radiator.
Had the engine cooler mounted to the factory crash bar.
Cut out the crash bar
Built the ducting out of home depot aluminum sheet.
Opened up the grill a bit
Mounted the cooler further back
Sealed it all up with foil tape
Old 10-23-2018, 01:09 PM   #164
ILLSMOQ
Tried drifting...didn’t work out so good. Not as easy as I thought it would be.
Old 12-04-2018, 09:51 PM   #165
karlsson
Drives: seat ibiza
Awesome build!
I understand you also drive it on the streets.
Does the fuel gauge work with the motec unit?
And do you know your mpg? Is it better than 13?
karlsson is offline   Reply With Quote
Old 12-04-2018, 09:55 PM   #166
Ashikabi
Ashikabi's Avatar
Originally Posted by karlsson View Post
Awesome build!
Surely v8s in cars do better than low teens?
Old 12-05-2018, 07:56 AM   #167
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Awesome build!
Yes, fuel gauge works perfect with the Motec. Tune might require minor adjustment depending on what motor you end up getting but there is an adjustable value used for accurate fuel gauge display.
I am getting 13ish MPG (LS2 with heads/cam), but getting tuned in two days, looking forward to increasing it.
Old 12-05-2018, 10:02 AM   #168
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
13?! hopefully thats spirited driving... I'm (untuned) getting 24-26mpg on the highway! LS2 with BTR custom cam. (calculated at the gas pump w/ odo)
spitsnaugle is offline   Reply With Quote
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Pure Automotive's 2017 Race and Show Schedule Pure Automotive Mid-Atlantic 4 01-21-2017 12:07 PM
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
Pure automotive pre meet KslayFRZ Mid-Atlantic 0 07-19-2013 11:32 AM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 02:07 PM
