#43 | |
Drives: 14' Raven M/T - 02' is300
Does this guy have a build thread? if you know em convince this guy to make one on here! |
#44 |
Drives: 2017 86 860 Special Edition
That torque/torque curve though!
I wonder if her can get more power by changing up the stack length. They look awfully short. |
#45 | |
Waiting to see a setup with this and headers with e85 |
#46 | |
No he doesn't have one, I think he said on his IG has tried to get on the forum several times but always gets log in issues. He has more pictures of the build on Instagram, pretty friendly too and he does plan to run E85 at some point. Still 60whp over stock on 91 isn't a bad result. |
#47 | |
#48 |
It appears so! But its not a cheap setup at all. I forgot to add he is running a MotecM150 standalone because he opted not to run a common plenum with a MAF. Idk if Ecutec could handle his setup
#49 |
The SARD ITB is the cost of a lower end turbo, still worth it to me if 220-230 ish whp is attainable with e85. I don't think anyone has posted numbers of an N/A ITB setup with one of their plenums yet?
#50 |
Drives: 2013 frs red
#51 |
178 torque sounds too high to be a wheel number.
#52 |
It does sound high. He has a nameless long tube header on that also though.
So if its not WHP the ITBs would have made little or nothing considering the car is supposed to come from the factory with 200 at the crank already he would have gained 4 whp with headers ITBs and custom tune on a stand alone ecu... |
#53 |
Why they wouldn't just publish what it made at the hub is beyond me. That's the actual number measured, and the only number that matters.
#54 |
Drives: 2014 BRZ
I've been going back and forth with the owner to get him to post his build here, but he's claimed that something's wrong with his account. I'm @donkielbasa in that thread
#55 |
Drives: 2014 BRZ
If you go a few of his posts back, he has a stock dyno that read 144whp. Regardless of what the final number was, a 60whp increase over stock is shocking.
#56 | |
If you look at where that term was grabbed from, it's the UI of the dyno software that said "engine power T WC", no one is posting claiming "engine power"
| The Following User Says Thank You to wparsons For This Useful Post: | fika84 (06-27-2018) |
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 669 | 06-07-2020 06:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 04:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 12:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 01:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
