Old 06-25-2018, 12:42 AM   #3375
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Like a lot of scca solo rules, the vast majority don't have a dog in the fight and can take or leave the change. At this point I don't care about the weight, but I'd bet I'd be faster if I was properly strapped in and not fighting to keep myself in position, at the very least more consistent.
ineedyourdiddly
Old 06-25-2018, 07:54 AM   #3376
CoolHandMoss
Drives: 2013 FRS
Does anyone find that Rivals grip notably better after being heat cycled/scrubbed in? I just ran a new set for the first time and I was a little disappointed and I'm wondering whether I can expect them to be any more impressive at the next event. I've always heard this category of tire needs to be heat cycled when new, I'm just wondering how much if any notable difference there is.
CoolHandMoss is offline   Reply With Quote
Old 06-25-2018, 06:26 PM   #3377
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Where are all the STX people for Oscoda Pro?
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 06-25-2018, 08:56 PM   #3378
cjd
cjd's Avatar
Drives: 2017 BRZ
I think that they do improve. I have also found they need a LOT more heat to grip to their full potential.
Launch control at 2800rpm on ~50 run Rivals took till my third run to not spin and require throttle feathering. 180+ run RE71's hooked up first time out and could probably use a higher launch rpm, though outdoor temps were also 10-15 higher and that plays a role in the difference too.
C
Old 06-25-2018, 10:23 PM   #3379
CoolHandMoss
Drives: 2013 FRS
That's good to hear. They felt pretty good but I really had hoped for a little more grip out of new tires. I've just never driven on new rivals before.
Old 06-25-2018, 10:43 PM   #3380
cjd
cjd's Avatar
Drives: 2017 BRZ
I forgot to mention. Completely different tires on good concrete. Launch control was at 3400 if I remember right, and just a bit of spin off the line on first runs each heat.
Old 06-26-2018, 07:09 AM   #3381
steverife
Drives: 2016 Scion FRS
C
I don't think that has much to do with heat cycles. RE71R's just launch better, period. I launched them 1k+ rpm's higher on my Spyder.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
cjd (06-26-2018)
Old 06-26-2018, 08:38 AM   #3382
cjd
cjd's Avatar
Drives: 2017 BRZ
It is more the change as they get heat in them I find worth noting. Whether that translates to grip in a turn.. It seemed like it, but I only have data for the launches at the moment.
Old 06-26-2018, 10:12 AM   #3383
CoolHandMoss
Drives: 2013 FRS
Do you find that they get better with heat to the extent that you never spray them? Or do they need a spray on hot days on a long course? I certainly have never felt like they got too hot even with two drivers on a hot day, but once they feel very hot to the touch I usually give them a spray to try to keep them in what I imagine to be the sweet spot. I'm much more used to driving on re71's and, before that, r1r's though, neither of which really like to get too hot?
Old 06-26-2018, 12:13 PM   #3384
tony_r
tony_r's Avatar
Drives: '15 STX
There is no reason to spray the BFG.
tony_r is offline   Reply With Quote
The Following 2 Users Say Thank You to tony_r For This Useful Post:
cjd (06-27-2018), tigermack (06-26-2018)
Old 06-26-2018, 07:06 PM   #3385
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Wish I can say that for the RE71's. lol
tigermack is offline   Reply With Quote
Old 06-26-2018, 08:00 PM   #3386
ka-t_240
any tire should be scrubbed/heat cycled before compition use to help clear the mold release off the tire.
ka-t_240 is offline   Reply With Quote
Old 06-26-2018, 08:28 PM   #3387
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
For those of you guys running RE-71R's this season, how much camber are you running? I'm currently at -2.8 front -2 rear and think I need more. Rear tire wear has been pretty close to even, but I'm getting noticeable outside wear in the fronts. Going to use my friend's pyrometer next event to check temps, but just wanted to check with you guys to get a general idea.
smg1138 is offline   Reply With Quote
Old 06-26-2018, 08:34 PM   #3388
ka-t_240
I am around 3.3F and 2.4 rear
The Following User Says Thank You to ka-t_240 For This Useful Post:
smg1138 (06-26-2018)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
