#45907 |
About any topic, or just fungii?
#45908 |
Feeling like thinking....
Drive like everyone's life around you depends on it...
| The Following User Says Thank You to MuseChaser For This Useful Post: | Ultramaroon (06-23-2018) |
#45909 |
Site Moderator
Drives: ichi 86 Project
Studs are fixed... but now, my right front brakes are getting stuck. It’s not extremely stuck that it lean towards right, while I drive. BUT there’s a clear temperature diffeerence between left and right. Plus when I lift it and let the wheel spin, I can clear pads are touching more than it should and causing the wheel spin as much. I’ve looked pads and don’t see an issue, so caliper? Man... one after an another issue.
#45910 |
What kind of brake? How many pots?
#45911 |
Site Moderator
#45912 |
How worn are your pads?
If your pads aren't new and you don't mind removing your wheel, can you then compress the inner pad all the way evenly and slowly doing something like this?
#45913 |
Famous Potatoes
Drives: '15 ultramarine
Went For a little drive this morning. Just not into it today. After 3 days of working on cars my legs and back are aching. Now it is 100°. Zero energy.
#45914 | |
Site Moderator
Also I was thinking of getting KNS Subaru 4/2 caliper kit... but sadly just noticed that they stop selling them. |
#45915 | |
The Dictater
Drives: '13 Red Scion FRS
Also, I don't remember if you did any brake work, but if you did you might want to recheck all fasteners. I missed a rear caliper bolt once. Made weird sounds, but the fronts might behave differently? |
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (06-23-2018) |
#45916 | |
If they're new, then your pots are already retracted, but if a bellows was torn when you replaced the pads, the contaminated/corroded pot could have jammed in place. Doing it the way I show allows you to check your guides like this. [ame="https://www.youtube.com/watch?v=4xNZu18bxg4"]https://www.youtube.com/watch?v=4xNZu18bxg4[/ame] Ok, I'm putting mine back together now.
#45917 |
You should use it. I bequeath it to you.
#45918 | |
Site Moderator
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Ultramaroon (06-23-2018) |
#45919 | |
Site Moderator
#45920 |
Did you reinstall them in exactly the same position as you removed them? If you mix-and-matched after they wore unevenly, that could exacerbate the misalignment.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
