Old 06-22-2018, 09:36 PM   #29
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I have a Perrin 2.5 and I was looking for the same quality is mentioned. From my research I don't believe the Perrin 2.5 is any less restrictive than stock, in fact if I recall correctly they state it has less restriction than stock.
Weight difference is minor.
I'm not as familiar with the HKS but I love the Perrin it looks totally stock, the whole catback feels very high quality with no drone and the perfect sound, at least for me.
DandoX is offline   Reply With Quote
Old 06-22-2018, 09:48 PM   #30
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by SuperTom View Post
Did you ever weight this exhaust. Im having a hard time believing the list weight of 22lbs
Very interested how this works out for you.
With these cars its hard to get lightweight + sounds good. I have the HKS Legamax Premium which sounds,fits,looks great. But it only 2lbs lighter than stock.
I wish someone could get a real weight of the Carbon Fiber tip version which should be a good compromise sound wise between the Legamax and the louder Spec-L that you got.
Damn I just want that weight reduction!
Check the following video at 1:15. They weigh the carbon-tip version which is a bit heavier than Ti-tip. They show 22 lbs. I will definitely post my experience
[ame]https://www.youtube.com/watch?v=s1HT-IcSDXA[/ame]
Old 06-22-2018, 10:13 PM   #31
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by Jrdad View Post
I meant it as a show of how quiet it is, even when at the extreme of catless and boost.
Then why not use Laguna seca's db limit as a measurement and say it's quieter than XX db, even catless and boosted?
Old 06-22-2018, 10:25 PM   #32
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
I was 3/4 of the way through a 12 hour night shift and not thinking totally straight lol
Jrdad is offline   Reply With Quote
Old 06-22-2018, 10:33 PM   #33
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
This
No muffler or res version.
https://shop.namelessperformance.com...haust-brz-frs/
Old 06-23-2018, 12:19 AM   #34
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Damn that is fking awesome thanks so much. I'm not sure why more people don't have that exhaust. I still like my Legamax you can hear the deep sound in the video but I may get the Carbon version and sell which ever one I don't like.
I think when I made my descision last year I wanted the exhaust stock style to fill in the area behind the bumper so I didn't have parachute effect. But the exhaust shield is light only 1lb and easy to make into a cover plate for that area.
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
mrg666 (06-23-2018)
Old 06-23-2018, 01:22 AM   #35
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'd recommend the HKS Legamax Sport, but it is roughly the same weight as stock. It does sounds great, with a nice burble, and flows well too. HKS describes it as quiet yet high flow. Though I do like the sound of the Spec-L too.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
mrg666 (06-23-2018)
Old 06-23-2018, 08:14 AM   #36
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks! I think Hi-Power Spec-L looks a little too different than stock. That was (and still is) my concern too. I wish there was a plain tip version (not blue or carbon). But it has good flow, good sound, light weight, and hopefully good quality. So, I will give those blue tips a chance. If that annoys too much, I will paint with a heat-resistant spray dark grey color. I will think about a rear diffuser under panel later.
Old 06-23-2018, 08:50 AM   #37
SuperTom
SuperTom's Avatar
I was referring to something on this post here which just lowers the stock heat shield to block the air from getting up behind the rear bumper. I think anyone going to a cannon style exhaust should be doing this at least. Some of the pics don't work but you should get the idea
http://www.ft86club.com/forums/showthread.php?t=73852
mrg666 (06-23-2018)
Old 06-23-2018, 04:04 PM   #38
I love my Ace Laguna 90. Maybe even a little quieter than stock but that noise reduction comes not from brute force damping, but rather the higher frequencies are canceled through clever design. It breaths beautifully.
mrg666 (06-23-2018)
Old 06-23-2018, 07:16 PM   #39
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks again! I was thinking about that empty space and this is definitely cheaper than the diffuser solution. That diffuser is $500
That is a very interesting one for sure. It is not light at 33 lbs ((8.7+2.2+4)/0.454) but sounds very good. I am confused about the flow part of design though. With that much complicated piping, inlets, outlets, and joints, the flow seems to be rather restricted to me.
Old 06-23-2018, 08:13 PM   #40
Actually the opposite, and is what I meant by brute force damping. Instead of shoving the 'signal' through a bunch of screens to create turbulence, it cleverly splits it evenly in sync. Then one side hits the magic can slightly later than the other to focus on canceling the higher frequencies.
Even standing far behind it one can feel more woof than hear bark.
mrg666 (06-24-2018)
Old 06-24-2018, 05:19 AM   #41
gpvecchi
gpvecchi's Avatar
But Laguna 90 muffler cutter is so ugly...
Old 06-24-2018, 08:53 AM   #42
mrg666
pessimistic skeptic
mrg666's Avatar
I think it is more of a grown up taste.
The Following User Says Thank You to mrg666 For This Useful Post:
Ultramaroon (06-24-2018)
2.5 inch front pipe and over pipe to 3 inch catback opinions (Please give your advice RedRez86 Engine, Exhaust, Transmission 2 08-21-2017 02:40 PM
Invidia Catback Ti tip Catback - SoCal PRICE LOWERED Teejay Engine, Exhaust, Bolt-Ons 10 03-31-2017 04:21 PM
Catback - perrin 2.5 catback exhaust (non resonated) vs greddy sp supreme Raychee Engine, Exhaust, Transmission 11 05-26-2016 12:24 PM
Godsnow catback opinions? wise345 Engine, Exhaust, Transmission 1 02-24-2016 03:36 AM
Catback exhaust opinions? Ms. FR-S Southern California 34 10-22-2012 08:37 PM
