Old 05-08-2018, 09:51 PM   #29
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
Any updates on this?
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 05-09-2018, 11:39 AM   #30
Racecomp Engineering
Still tossing around ideas with a few people for specs. We like the response we've gotten, more a question of timing right now since we've got a couple projects going on at the moment.
- Andrew
Old 06-15-2018, 06:26 PM   #31
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
fwiw Id absolutely be down to get these, basically exactly what i want.
Some rally-esque fun on a budget.
<-- why is this an emote
FeRS is offline   Reply With Quote
The Following User Says Thank You to FeRS For This Useful Post:
Racecomp Engineering (06-18-2018)
Old 06-21-2018, 12:56 PM   #32
JMon85
JMon85's Avatar
Drives: 2019 WRX
Any juicy updates?
JMon85 is offline   Reply With Quote
Old 06-21-2018, 05:07 PM   #33
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
I like what I’m reading here. Speaking from 4 years of SCCA RallyCross experience with the FRs more ground clearance would be great!
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 06-22-2018, 10:28 AM   #34
Originally Posted by JMon85 View Post
Any juicy updates?
Nothing juicy, but I do think this will happen.
- Andrew
ATL BRZ (06-22-2018), JMon85 (06-22-2018)
Old 06-22-2018, 02:24 PM   #35
Or if you want....JRZ Rally Spec 3 way coilovers
- Andrew
wparsons (06-24-2018)
Old 06-24-2018, 01:21 PM   #36
churchx
churchx's Avatar
Drives: 2014 GT86
Racecomp Engineering: no carporn pics!
Old 06-24-2018, 04:11 PM   #37
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
- Andrew
How many kidneys do those cost lol
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 06-24-2018, 10:27 PM   #38
churchx
churchx's Avatar
Drives: 2014 GT86
Ricepudding: most of such are 1) with custom rates, built to order, 2) stronger to handle rally-ish abuse .. think of 7.5-15K for set. And even then they often are overhauled every 1000km. Spring & damping rates are far from being compliant for daily driving though, so despite their coolness and what miraculous maneuvers & bad road surfaces & speeds they can handle, i find hard to imagine someone installing these in daily drive, even if one can stomach the price. From this class i'm more used seeing Ohlins TTX on local rally prepped subbies & evos though.
Old 06-25-2018, 02:06 AM   #39
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Yeah I am tracking, I was being comical. Someone of Dirt Impreza ( or maybe it was special stage) started a post about daily driving on rally suspension. Not something I would want to do.
Old 06-25-2018, 01:48 PM   #40
Wiscocrashtest
Drives: 14 BRZ, 16 FoSt
I just got back from my first rally-x in the BRZ. I would buy these if they were close to stock spring rate but gave more ride height. The stock setup was really good (for me) but a little low. I was definitely not craving more oversteer. The car was very neutral.
Wiscocrashtest is offline   Reply With Quote
Old 06-25-2018, 01:54 PM   #41
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You can always give the subtle solutions lift kit a try. These are spacers that go between the body and the suspension of the car to bump up the ride height. You can also give taller/ higher aspect ratio tires a try.
Old 06-25-2018, 03:47 PM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
Unlike taller tires, spacers or longer springs don't change gearing ratio to taller, which affects acceleration. That will help with stock relatively low NA power. Tire weight and cost also is kept lower. That's why i'd prefer those for more ground clearance over taller tires.
Gauging interest for an OEM exhaust in GTA StraightOuttaCanadaEh Canada Classifieds 5 06-08-2017 01:00 PM
Gauging interest in ACE 150- Type B olsonpg Canada Classifieds 3 07-12-2016 07:10 PM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
Gauging Interest Rear Diffuser SunkenFRS Cosmetic Modification (Interior/Exterior/Lighting) 20 10-07-2013 04:28 AM
