Southern California SoCal
Old 06-22-2018, 01:37 AM   #15
Carlos.z
Drives: Limited brz
Arco and mobil made my crickets go wild.
Shell and chevron is what i mostly use.
The 76 near me is a hit or miss with the crickets, but never too bad and costco when its not packed.
Carlos.z is offline   Reply With Quote
Old 06-22-2018, 02:10 AM   #16
firekat
Drives: 2018 Subaru BRZ tS
There are a couple of Arco stations around me that are substantially lower in price than other gas stations. The last time that I filled up at the Arco station I noted the "This Fuel May Contain up to 10% Ethanol" placard on the pump where the gas nozzle sits.
That might be why it's cheaper, and different performance.
Filling up at the local Chevron and Shell stations they did not have that placard anywhere on the pump that I could see.
There is some banter about that says if you're running pure gasoline you will not get crickets.
"YMMV"
firekat is offline   Reply With Quote
Old 06-22-2018, 02:16 AM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
"YMMV"
They are 10% also.
ARCO is cheaper because cash only. Shell and Chevron have always been known for being over priced. 99.9999% chance all the gas in your area comes from one refinery.
chaoskaze (06-22-2018), Tcoat (06-22-2018)
Old 06-22-2018, 02:58 AM   #18
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
They are 10% also.
This, I guess that also influence the gas prices for the area too since same refinery = same price....
The one thing I don't understand is how gas in vegas is getting so close to cali price now....*still 40 cents cheaper but it used to be like almost a dollar cheaper just 2 years ago...
Old 06-22-2018, 09:21 AM   #19
Nope. Same refinery does not mean same price. Ironically the larger chains that tend to charge the most for gas are also the ones that buy in so much bulk that they pay the least at wholesale.
Did Nevada sneak a fuel tax into the price sometime in those two years? The biggest discrepancy in regional fuel prices is not usually the cost of the fuel itself but all the taxes and surcharges the local government tacks on top of it.
Old 06-27-2018, 04:50 PM   #20
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
When I was married I would use Arco/Costco/Ralphs/Thrifty they all seemed the same. No real big issues just louder crickets. Now that Im single Ive been living that Shell/Chevron/76 life. I also sometimes fill partial Trick racing 100 to get 97 rating but that shits like 10+ per gallon.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 07-02-2018, 02:23 PM   #21
e_lunatic
Drives: 2015 Scion FR-S
I fill up with whatever the Von's gas station uses. havent had any problems and its cheaper than most gas stations around plus i get discounts on top of it from grocery shopping
e_lunatic is offline   Reply With Quote
The Following User Says Thank You to e_lunatic For This Useful Post:
chaoskaze (07-17-2018)
Old 07-13-2018, 10:41 AM   #22
Simok
Drives: 2013 FRS
I only use Chevron or Shell. My dad worked at the Chevron refinery for 30+ years and he says its not all the same, however he could be bit biased. And both of the offer rewards programs where you earn points for shopping at ralphs or vons.
I had a old beater sentra that I would dill up with whatever was cheapest and i would notice when filling up with cheap gas like usagas it seemed like I would get less miles out of a tank. Never noticed much of a difference with name brands tho.
Simok is offline   Reply With Quote
Old 07-14-2018, 07:16 AM   #23
elekidcircus
Drives: 13 Scion FRS
Check engine light went off after continuously using arco(Used mainly because its a block away from me and high gas prices). Switched to Shell Vpower and its gone
Sent from my SM-G955U using Tapatalk
elekidcircus is offline   Reply With Quote
Thoughts? Richard_BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-01-2019 05:47 PM
new set up thoughts tofurun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-02-2017 12:29 AM
Thoughts? adjusts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 11-23-2016 09:25 AM
Thoughts on this. Style Cosmetic Modification (Interior/Exterior/Lighting) 24 08-03-2012 01:59 AM
What are your Second Thoughts? slizoth Scion FR-S / Toyota 86 GT86 General Forum 22 04-05-2012 06:13 PM
