#1611 |
Come fall we will have to set something up.
| The Following User Says Thank You to Tcoat For This Useful Post: | echo419 (06-21-2018) |
#1612 | |
Proud of BOXER
Drives: Subaru Boxer
#1613 | |
Drives: 2014 BRZ Limited
I'll see you on once in a while but you usually log off shortly after or I'm shutting down when I see you. I haven't really played much in the last couple of months. got in a couple of hours a few days ago when I was laid up with my hammy but that's it. |
#1614 | |
Proud of BOXER
Ah, yeah, I don't get on there until after 10pm most nights!
#1615 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#1616 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Everyone I know seems to always have problems with them. ASUS or bust. The board you should get highly depends on what you plan on plugging into it. Also depending on how powerful you are building, you might have to take into account the number of PCIe lanes your chosen MB/CPU has. The GPU will pull from the CPU and the MB will provide the rest. I cant imagine any of the boards you will come across won't have the max number of 24 PCIe lanes. Make sure you have enough fan headers for however many fans you plan on having. A water cooler pump plug if going that route. I'll assume you know enough to pick the correct size of MB. Beyond all that, pretty lights and stuff like BIOS reset and other overclocking/tweaking ease of use things you probably don't need. TLDR; As long as you stick to a single GPU, just find a board that has enough plugs on it to hook up everything you need. And make sure your CPU choice has enough lanes to support the GPU. |
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Captain Snooze (06-21-2018), Dadhawk (06-21-2018) |
#1617 | |
Proud of BOXER
I have this MSI board and I've had zero issues with it.
https://www.newegg.com/Product/Produ...82E16813130972
#1618 |
Because compromise ®
Drives: Red Herring
Thanks for the tip. While some of the hardware will be overclockable I do not plan on doing so.
#1619 | |
LMGTFY
But at least in my case over the years, the person having weird MB problems 9/10 times has an MSI MB. I believe the problem with MSI stems from bad QC. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Dadhawk (06-21-2018) |
#1620 |
I have to agree, that has been my experience as well. Never had a single problem with an ASUS board, but have had issues in the past with MSI from time to time.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1621 | |
Proud of BOXER
Well that sucks. I hate trying to track down weird motherboard gremlins, or trying to deal with unexplained crashes because some component on the motherboard is failing. If I had that experience with MSI I'd probably ditch them too.
I've used Gigabyte boards previously for all my builds before this one and they've been pretty good. This was my first time going MSI and I'm happy that my experience has been positive. I've used Asus for friends builds in the past, and I've recommended them to others! I'm sure for a future build I will give them a shot.
| The Following User Says Thank You to Clipdat For This Useful Post: | Dadhawk (06-22-2018) |
#1622 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Have always used Asus or Gigabyte as well with no issues. My current build is one of the Sabretooth models with military grade capicitors ect. |
#1623 | |
Proud of BOXER
Nice caps reminds me of the PSU I got. It has all Japanese caps with high MTBF.
https://www.newegg.com/Product/Produ...82E16817438057
#1624 |
didn't get to play 5 minutes of anything this weekend.
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 04:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 06:37 PM |
