go_a_way1
Old 06-14-2018, 12:27 AM   #3767
KnightRyderx2
Drives: 2014 FR-S
Why did you put a 3mm spacer on the rear? What is the face setup? I want to get the same wheels but thinking to go with a +23.
Originally Posted by spd View Post
18x9.5 +20 all around, 3mm rear spacer. On bags, so camber is -3/-2 at ride height. I want to go a little wider in the rear, but haven't figured out what to do with that fender lip yet.
KnightRyderx2 is offline   Reply With Quote
Old 06-14-2018, 02:07 AM   #3768
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
Originally Posted by Impureclient View Post
Agree!
If there was something that was body color that could go right above the muffler/etc. to hide all the cut outs/holes, that would be a nice offering. Or even better, just a longer bottom end like this:
That looks pretty good too, but for now I know people like to pair the cut bumper with a bash bar in the rear since it looks a little better
NAEightySix is offline   Reply With Quote
Old 06-21-2018, 09:34 AM   #3769
spd
Drives: wrx, brz
Rear needs a bit wider to fill in, but I prefer square setups. This is the deep concave, don't remember what face letter that was.
I changed my setup since then. Something like 18x9.5 +12f +5r now.
spd is offline   Reply With Quote
The Following User Says Thank You to spd For This Useful Post:
MCTeeJ (07-30-2018)
Old 06-21-2018, 12:52 PM   #3770
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
^^ How did you get your car so clean? Impressive detailing job.
Originally Posted by humfrz
I'm old and lazy
Old 06-28-2018, 03:36 PM   #3771
Ichima
Drives: 13' Lightning Red Brz
I know these specs aren't as aggressive as what is posted here.
But I'm trying to figure out what will be needed when I fit the Work VSKF's when i get them.
The specs are 17x9 +35 and I'm thinking either 205/40/17 or 215/40/17.
Currently I'm maxed out on my coils which are about a 4 inch drop.
Any advice?
Ichima is offline   Reply With Quote
Old 06-28-2018, 05:08 PM   #3772
Impureclient
Drives: 2015 FR-S
^ Do 195/40R17 or even better 175/40r17 for the win.
Old 06-28-2018, 05:49 PM   #3773
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Any advice?
4" drop on what coils?
Are you on stock wheels now?
Do they rub?
Are your stock tires done?
Because, I would try those first if they still have any tread left. 17x9 +35 wheels are not very aggressive. They only need a minimal amount of camber up front to be dialed in, and will fit a proper size tire. (215/45, 225/45, 235/40, 245/40)
I LIKE TIRES!
Old 06-28-2018, 06:05 PM   #3774
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you are looking into obscure sizes, you can get a 165/35/17. LOL!!!!
via Imgflip Meme Generator
I LIKE TIRES!
Impureclient (06-28-2018)
Old 06-29-2018, 12:58 AM   #3775
Ya'll keep it up, soon we will be right back there …
Old 06-29-2018, 02:51 AM   #3776
Ichima
Lol thanks for the replies. But i’m maxed out on bc extreme lows and i’m looking to run a 215/45 or 215/40 but i do rub up fromt a good amount on stock wheels
Old 07-02-2018, 04:05 AM   #3777
Hella Basa
Hella Basa's Avatar
Drives: 2014 Subaru Brz Limited
Let's revive this thread!
Hella Basa is offline   Reply With Quote
Old 07-02-2018, 05:50 PM   #3778
kingthefab
Originally Posted by larryw View Post
18x9.5 +30
225/40 front and 245/35 Rear
can someone tell me where i can get these rims? i absolutely love them
kingthefab is offline   Reply With Quote
Old 07-03-2018, 09:28 AM   #3779
monkeybike
Drives: 86
http://www.evasivemotorsports.com/mm...ode=WORK-CR-KW
monkeybike is offline   Reply With Quote
Old 07-31-2018, 11:50 PM   #3780
iamhubert
iamhubert's Avatar
Drives: 2013 frs
Previous setup: RS Watanabe R Type
front 16x8.5j -9 rear 16x8.5j -6 or 16x8.5j 0 NS20 wheels
Current setup: Avs Model V
Front 17x9j +12 Rear 17x9j +20
IG: iamhubert
iamhubert is offline   Reply With Quote
The Following 4 Users Say Thank You to iamhubert For This Useful Post:
Leonardo (08-01-2018), MCTeeJ (08-02-2018), Raven86Project (12-19-2018), TylerLieberman (08-01-2018)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
