#659 | |
Are you asking if the springs the same as a stock spring set from a WRX STi or a BRZ tS?
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#660 |
I mean the BRZ STi JDM model. They are the same as tS version. But I don’t know anything about the STi aftermarket, they have different part number...
#661 |
Drives: 2015 BRZ
No, they are not the same. The JDM STI Springs lower 15mm and the USDM tS springs lower the 10mm. They are completely different parts so they will have different part numbers.
#662 | |
As mentioned above the JDM versions are 15mm down vs. 10mm down. My springs are specific to the showa dampers on the JDM tS from 2013. Other iterations were revised to pair with the bilstein dampers for 2015 and another for the new JDM STi sport. If you want a set that pairs to the USDM tS for the additional 5mm you can look at the JDM STI sport version as it uses the same dampers as the US car.
@dsomegax.cars
| The Following User Says Thank You to DSOmegaX For This Useful Post: | Tristor (05-10-2018) |
#663 | |
The Fail Boat
Drives: CWP S.B.
https://www.sti.jp/parts/subarubrz_z.../ST20330AS000/ Sti Sport/Showa/Bilstein had their own. |
#664 | |
#665 |
Drives: 14' BRZ supercharged
Any tips on applying the STi pinstripes? I have them, I am just nervous about them not looking even and the instructions are in Japanese haha. Love your car by the way.
#666 |
#667 | |
The pictures should help you position the templates. Take your time, make sure you clean off any dust and dirt in the area. Helps to have another person to make sure it’s aligned. It’s not too bad once you get started!
@dsomegax.cars
#668 |
Dealerships will have them. It’s off the USDM tS
@dsomegax.cars
#669 |
#670 |
#671 |
I’m happy to announce that the BRZ will be having a baby sister!
![]() I’ve been looking into an M2 since almost two years ago and was close to pulling the trigger back then, but when I started hearing rumblings of the competition model, I decided to wait it out to see if the rumors would be true; and sure enough it does not disappoint! Delivery should be around end of September/early October.
@dsomegax.cars
#672 |
So sick! Just don't sell the brz
| Completed build | JK21 | Member's Car Journals | 46 | 12-11-2014 09:48 AM |
| Completed!! FBM 700+HP Build Dyno graph & Vid inside | FullBlown | Forced Induction | 214 | 03-31-2014 01:56 PM |
| Vinyl wrap completed!! | laley81 | Southern California | 14 | 08-30-2013 11:10 PM |
| Nearly Completed my Firstorm Build - Lots of Pics | msile | Member's Car Journals | 52 | 03-10-2013 10:25 AM |
| Turbo FRS completed! | Philly | CANADA | 24 | 09-03-2012 09:18 AM |
