Old 06-19-2018, 12:49 AM   #29
Noodlesz
Drives: '17 860 SE
Mine has the spoiler and requires a bit of force. last couple of times it won't latch closed. Had to lock and play with it with a pen a few times to get it to lock again. Think something it wrong with the latch. I will ask the dealer to fix it during the service.
Anyone have such an issue? Seems weird the trunk won't lock, but it's fine when I play with the lock myself and the trunk is still open.
Noodlesz is offline   Reply With Quote
Old 06-19-2018, 03:21 AM   #30
Maybe give it a shot of silicone spray (or WD-40) ….. to loosen up the mechanism.
Old 06-19-2018, 07:09 PM   #31
highway7
Drives: FRS 2013
Don't have this problem, if you slam your trunk shut all the way from the top I would assume you knocked the striker plate out of alignment with the latch. had this problem with my civic, had to adjust the striker plate. Your trunk should still close with just an inch of room to close it.
highway7 is offline   Reply With Quote
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 06:16 AM
Wheel Directory: Rota G-Force 18x9.0 +35 sirus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-30-2013 09:34 AM
Force induction delays? BrzRacer Forced Induction 18 04-01-2013 04:45 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 03:24 PM
Wheel Directory: D-Force 5 17x9.0 +?? HAZMAT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-12-2013 03:36 PM
