#267 |
86 Nut
Drives: 86 Satin 6MT High
I fitted formula friction pads with power brake rotors.
Made a huge difference from stocks pads. Then, swapped the stock calipers for WRX 4 pots. That made a huge difference on top the first difference. |
| The Following User Says Thank You to GeeTee86 For This Useful Post: | 86 South Africa (08-21-2017) |
#268 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Thanks. So you have the same sized rotors, just better ones with different pads?
I like driving!
#269 |
86 Nut
PB rotors are 294 x 24mm, same as stock.
But it is better quality, heat treated and slotted |
| The Following User Says Thank You to GeeTee86 For This Useful Post: | 86 South Africa (08-22-2017) |
#270 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Same as GeeTee86 - WRX calipers front & rear, PB discs front and braided lines all round running Motul RBF660 fluid.
Just bear in mind, std spec got tiny rotors so upgrading to 294mm would make an even bigger difference. If you're set on getting a big brake kit, have a look here: http://www.ctsvbrakeswap.com/subaru-...er-bracket-kit A friend's done it on his Subaru with 330mm STi discs from PB. Just make sure they'd clear your wheels. He's running 18".
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | 86 South Africa (08-22-2017) |
#271 |
I have stock 17" rims so if the PB rotors, pads and better fluid makes a much bigger difference then I'd rather do that than spend big dollar on a BBK.
I like driving!
#272 |
Finally got around to ordering a set of power brake rotors with endless pads and motul 660 fluid - should all arrive in a few days.
Excited to see the difference
I like driving!
| The Following 2 Users Say Thank You to 86 South Africa For This Useful Post: | Fish Eagle (10-11-2017), FT_86_SM_GP (10-13-2017) |
#273 |
Platinum Member
Drives: Toyota 86 Vortech SC
If you use Bendix Ultimate DB1803U rear pads (for standard spec) from Powerbrake, then right now their pricing is very good.
I don't know if this is due to exchange rate fluctuations or a mistake. In April 2017 and again in August 2017, I paid 1793.20 incl, and today they're at R1300.74 incl.
| The Following User Says Thank You to Fish Eagle For This Useful Post: | 86 South Africa (02-06-2018) |
#274 |
Platinum Member
Just received new pads from Powerbrake and the front pads are the real deal again - genuine BLUE Endless pads from Japan.
![]() Some of you will know that I had a big fight with them last year about the quality of their locally made RED clones. Thrilled that they've listened to their customers ![]() Also pleased to see that the Bendix rear pads I received are the ones manufactured in Australia which are better than the others.
| The Following 2 Users Say Thank You to Fish Eagle For This Useful Post: | 86 South Africa (02-06-2018), Gregore (02-10-2018) |
#275 |
Glad to hear that!
Must say that so far I’ve noticed a huge difference in mine!
I like driving!
#276 |
GT86PersianClub
Drives: 2014 Crystal Black Silica GT86
Hi
i have EBC rotors on my car and it has a strange noise when driving about 50-60 Kph,and when i brake the sound stops,does anyone know what the problem? this is the sound and this is the rotor http://www.ft86club.com/forums/attac...1&d=1352695118 __________________
Follow Me on Instagram
: @Stock_GT86Admin & Founder of @GT86PersianClub Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light |
#277 | |
All I’d say is this.... when it comes to brakes get someone with REAL knowledge to help sort it out. It really is 1 part of the car you don’t want to fail. Also maybe take the wheels off and check for obvious signs of something wrong in the meantime?
I like driving!
#278 |
Platinum Member
Decided that today's the right time to fit the new front discs I bought a few months ago.
I've been watching this crack slowly growing, and now it's time to replace.
#279 |
Caused by excess heat on the track?
I like driving!
#280 |
Platinum Member
Yep, surface cracking is normal.
Deeper cracks like this one are a problem.
| The Following User Says Thank You to Fish Eagle For This Useful Post: | 86 South Africa (06-21-2018) |
| gc8 4 pot brakes | wholeeoh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 05-15-2022 04:38 PM |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
| GT to GTS brakes? | Turdinator | AUSTRALIA | 30 | 01-12-2014 12:33 AM |
| OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 10:26 PM |
| GT brakes | jello | AUSTRALIA | 2 | 06-10-2012 09:10 AM |
