go_a_way1
Old 06-05-2018, 10:33 PM   #4579
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Originally Posted by stlgrym3 View Post
What’s ETune? I will get a custom tune from delicious as well when I pair up my C30 with tomei EL.
Do u have a C30 or C38? I was told C38 requires ACE header plus high boost pulleys.
The term you’re looking for is “recommended”. Due to the higher volume and velocity of exhaust gasses exiting the cylinder heads it’s wise to equip the motor with headers, as well-engineered headers create a sort of suction effect where the exhaust gasses are pulled from the heads.
Your potentials for power gains will skyrocket with a solid aftermarket header, especially with ACE.
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
Old 06-06-2018, 02:16 AM   #4580
CSG Mike
CSG Mike's Avatar
Originally Posted by Anderzz View Post
Etune is just an electronic tune, in other words I didn't physically bring the car to them. I put the tuning software on my own laptop put on the tune, took logs, sent the log results to Delicious and then they sent back the tune after a few rounds of logs.
I have a C38, whoever told you it "requires" anything is just plain wrong. Neither the C30 or C38 require anything, they can both be run on otherwise stock systems, or with any header setup.
Sent from my XT1650 using Tapatalk
He's not posting the full story. What he was told, is that to use a HBP with any JRSC, with CA 91 octane, safely, without massively pulling timing, the Ace header is the only known option.
Any header is fine without HBP.
With HBP, if you want to use ACN91.... well, only one option. If you use high octane or ethanol, then any header will work.
CxG (06-07-2018), mrg666 (06-06-2018)
Old 06-06-2018, 11:49 AM   #4581
stlgrym3
Anyone else running C38 with non-ACE header? How u like the setup?
stlgrym3 is offline   Reply With Quote
Old 06-06-2018, 01:10 PM   #4582
CSG Mike
CSG Mike's Avatar
Remember, context. On ACN91.
The setup is zero issue when you're flex fuel with significant ethanol content. As I've said in your PMs many times, I do not recommend redlining when on 91.
Because you have an automatic, you need to be especially watchful of this, because heavy throttle application can cause a potentially unwanted downshift, unless you're in manual mode.
Old 06-06-2018, 01:21 PM   #4583
stlgrym3
I’m not talking about C38 with HBP, just C38 with stock pulleys and another aftermarket header other than ACE. Basically I’m asking will the following work? Or do I have to go with C30 instead for the following set up?
C38
Non-ACE header (tomei EL in my case)
Factory pulleys
91 petro
Custom tune
I would prefer C38 now even though I won’t be benefiting from its full potentials, but it’s good to know the potential is there down the road.
Old 06-06-2018, 01:28 PM   #4584
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
C38
Factory pulleys
91 petro
Custom tune
That will work with a C38.
Anderzz is offline   Reply With Quote
Old 06-06-2018, 01:34 PM   #4585
CSG Mike
CSG Mike's Avatar
C38
Factory pulleys
91 petro
Custom tune
That setup will be perfectly fine.
Old 06-06-2018, 01:50 PM   #4586
stlgrym3
Thank you, I’m ready to order Mike :P
Old 06-18-2018, 07:51 PM   #4587
HyperblueJon
HyperblueJon's Avatar
Drives: Brz
Would there be any component that need upgrades or beefing up with this kit , thinking about getting it and want to know the needs/better to have parts of any
(Like fuel pump, rails ect..)
Currently on 93 pump no e85(nearly no stations that sell it around me)
Sent from my SM-G950U using Tapatalk
HyperblueJon is offline   Reply With Quote
Old 06-18-2018, 09:58 PM   #4588
mrg666
pessimistic skeptic
mrg666's Avatar
If you don't use high boost pulley or E85 and use carb tune, nothing else is necessary. If you go with delicious tune a map sensor upgrade might be required. If you add E85, injectors need to be upgraded..Talk to delicious tune for injectors and map sensor requirements. If you add HBP engine rebuild is recommended along with ACE header. Oil cooler is required for all configurations especially if you are tracking
Old 06-18-2018, 10:46 PM   #4589
Anderzz
Anderzz's Avatar
Require:
Catch can or AOS
Engine Oil cooler if you plan on driving it hard
4 BAR MAP sensor for logging for tunes
Injectors and a Fuel pump if you ever go e85
A built shortblock if you ever go HBP
Optional but I personally recommend it, a Forge Motorsport Recirc Valve instead of the plastic Kaiser one that comes with the kit.
Old 06-19-2018, 10:43 AM   #4590
max20s14
Drives: 14' Raven M/T - 02' is300
How safe do you guys reckon the c38 on a stock pulley and stock block with uel headers on 93 is?
Have a lot of people wrecked their rods on that setup?
I wanna do it but I might blow that money on a daily first
max20s14 is offline   Reply With Quote
Old 06-19-2018, 10:45 AM   #4591
max20s14
if you run the supplied tune with castles headers does that cause issues?
Old 06-19-2018, 10:59 AM   #4592
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
This my setup. Is reliable. Is safe. Do recommend.
Sent from my SM-G935V using Tapatalk
ShawnP19 is offline   Reply With Quote
The Following User Says Thank You to ShawnP19 For This Useful Post:
CSG Mike (06-19-2018)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
