Old 06-12-2018, 11:00 PM   #85
cjd
cjd's Avatar
Drives: 2017 BRZ
I just did this on my 2017 BRZ without removing the bumper. It's a bit cramped for working but quite do-able from under the car by removing the two plastic pieces from underneath and gently pushing the foam up out of the way.
Bumper sag kept at Bay just a little longer!
I got a photo of the inside with the covers off but will have to wait to upload too I can resize it...
The Following 2 Users Say Thank You to cjd For This Useful Post:
02.ACCORD.DUDE (09-17-2018), Sisko's_Baseball (12-30-2019)
Old 06-12-2018, 11:33 PM   #86
Leftyonly
Drives: 2017 Toyota 86, Halo
Originally Posted by Leftyonly View Post
Came her for this thread!! Great idea and write-up.
I did this on my wife's new 2017 86. Easy to do. Side marker lights weren't that hard given the amount of write-ups on the web for their removal. I'd hate to be the first guy that tried it. I would have broken them for sure!
-Richard
Wife lost the front plate and bracket in a brush style car wash. Luckily the car wash place held onto it and we got it back. I know most avoid these types of washes,but thought a wird of caution would be in order anyway.
Leftyonly is offline   Reply With Quote
Old 06-15-2018, 10:14 AM   #87
zero_limits
Drives: Subaru BRZ 2017 PP
I have a 17 BRZ also and was gonna attempt to do this without removing the bumper.
Did you have to use any special tools to get the magnet squeezed on the other side?
Can you also please upload the the pic with the covers off?
zero_limits is offline   Reply With Quote
Old 06-15-2018, 06:50 PM   #88
cjd
cjd's Avatar
Drives: 2017 BRZ
No special tools. I probably should have done a better job with pictures, but I'll upload the one soon as I'm actually able to fire up the computer. Crazy week, my only free time was used by the install.
Old 06-16-2018, 11:47 AM   #89
cjd
cjd's Avatar
Drives: 2017 BRZ
Alright - only photo I got, hopefully this proves helpful. This is on my 2017, easy access to the inside with the lower covers removed. May also apply to the older model since not that much has changed, but I can not verify.
The Following 3 Users Say Thank You to cjd For This Useful Post:
juenedgi (11-17-2019), shiumai (08-14-2018), Sisko's_Baseball (12-30-2019)
Old 06-16-2018, 01:27 PM   #90
zero_limits
Sweet! Appreciate the photo! Glad to know it's possible to do without removing the bumper.
Will try to do this next weekend and will report back!
Did you use anything on the front bumper to prevent scratching/marring from plate movement ? just curious.
Old 06-16-2018, 02:07 PM   #91
cjd
cjd's Avatar
Drives: 2017 BRZ
The glue is squishy and comes out the back. I smoothed that flat with a bit of thickness. That's all the extra protection I have, beyond making sure the screws don't hit the cover.
C
Old 08-14-2018, 03:12 PM   #92
zero_limits
Finally got around to doing this!
Thanks for letting me know it was possible without removing the bumper!
The Following User Says Thank You to zero_limits For This Useful Post:
cjd (08-14-2018)
Old 09-17-2018, 03:47 PM   #93
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
I'm testing something similar with my FR-S though I screwed up the angle a bit and am afraid the magnets I used weren't large enough -_-...
Don't feel like taking the bumper off again to redo it, so it'll probably be back to no license plate for now.
02.ACCORD.DUDE is offline   Reply With Quote
Old 03-13-2019, 05:25 PM   #94
ArchReactor86
Drives: 2013 GBS BRZ Limited
i have a odd question. i have the oem bracket like on the first page. it was drilled in by the dealer. i was trying to remove it and all it does is spin but not freely. is there something on the back holding it in? thanks
ArchReactor86 is offline   Reply With Quote
Old 03-14-2019, 11:27 AM   #95
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
Try this thread. Looks like different ways to do it. Planning to do it myself pretty soon. Just waiting for some warmer weather!
http://www.ft86club.com/forums/showt...+license+plate
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 03-31-2019, 06:36 PM   #96
vas
Drives: Subaru BRZ
Few notes from my install:
The 2017+ mounting bracket comes with square cutouts with rounded corners. _Don't_ buy square magnets, stick to what OP recommends. For reference, to make a 7/8" square magnet fit, I had to grind down the bracket with a dremel. That said, a 1/4" thickness fit well.
The 2017+ bumper isn't that prone to scratches, and has a cutout to fit the bracket perfectly.
Double sided tape will increase the space between the magnets enough that the pull force is definitely less.
I personally used just gorilla tape on the inside of my bumper because I'm planning to have the license plate on for daily driving, so the magnets should hold each other on most of the time.
You can also ziptie to the bottom holes as a little bit of insurance until you feel confident the magnets will stick.
Overall happy with the result. Thanks for the idea and posting!
vas is offline   Reply With Quote
The Following User Says Thank You to vas For This Useful Post:
shiumai (12-11-2020)
Old 11-17-2019, 12:57 PM   #97
juenedgi
juenedgi's Avatar
Drives: 2018 Subaru BRZ with PP
Thank you for this solution! I did it on my BRZ but I decided to go through under the plastic bumper as @cjd did.
juenedgi is offline   Reply With Quote
The Following User Says Thank You to juenedgi For This Useful Post:
cjd (11-17-2019)
Old 06-03-2021, 12:11 AM   #98
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
I knocked out this DIY last week, and it worked great. Thanks.
McMCOO is offline   Reply With Quote
The Following User Says Thank You to McMCOO For This Useful Post:
shiumai (06-29-2021)
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
