Old 06-15-2018, 06:41 PM   #15
Teseo
Drives: frs
Weight reduction is the best mod for going faster, dyno is for tuning and brag out
Old 06-15-2018, 08:36 PM   #16
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Then you might like my build thread
Down to ~2536lbs will be <2500lbs by the end of this summer
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
Teseo (06-15-2018)
Old 06-15-2018, 09:07 PM   #17
NRXRaptor
Originally Posted by Joesurf79 View Post
Is the implication that the catback portion of the exhaust does significantly impact the area under the curve?
no, its simply that peak numbers don't tell the whole tale of power delivery. for instance, stock evos had ridiculous power numbers, but those numbers didn't tell you that you'd have to slog through the entire tachometer before getting to the power
hell, a user on here posted his dyno chart for his (works?) carb legal turbo kit. most people simply went "hurr u spent $6600 for that little power gain durr" while munching on crayons and completely missing the immense boost in torque and power at 3000rpm. if you only look at peak numbers you're doing it wrong
I think we can all agree that a catback is only ever going to do a little bit compared to things like headers, boost, and tunes
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Joesurf79 (06-15-2018)
Old 06-15-2018, 09:16 PM   #18
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
I gotcha, yeah - more area under the torque curve everywhere is more fun than a high peak by itself.
My car is right at 2500 lbs now, with 1/2 tank of 93 oct.
I've got plans to shave another 50 lbs by the end of summer from the car...and 10 lbs from my chubby self
With the 4.56 final drive and the headers / tune - it's peppy! Can t wait to get it on track next weekend!
Simplify and add lightness works if you carry it far and commit !
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
SuperTom (06-15-2018)
Old 06-15-2018, 09:19 PM   #19
Joesurf79
Joesurf79's Avatar
Originally Posted by Doozer View Post
Don't worry about the aero stuff. A center exit exhaust in regards to the total aero package is minimal. There are much bigger gains in other areas worth your time and energy.
I would recommend just a standard 2.5" single exit muffler delete exiting driver's side. Any form of resonator in this axle back section should help your ears.
You have to think:
Japan engineers spent a lot of hours routing of the original exhaust system.
Ace also spent lots of hours engineering the header.
The only thing both Toyota and Ace engineers did the same was to measure everything with the total length of the exhaust in place, engine-to-bumper.
Hope this helps
It does. A solid, straight as possible 2.5" with straight through resonator / muffler out to the factory driver exhaust opening shouldn't significantly hurt power production or delivery is what you're saying.
Old 06-15-2018, 09:54 PM   #20
I've been considering the concept of anti-reversion to improve scavenging.
Joesurf79 (06-16-2018)
Old 06-15-2018, 10:04 PM   #21
Joesurf79
Joesurf79's Avatar
Adding anti reversion chambers to an existing system? Where in the system? At the header in individual primaries? After the collectors? Or further back?
Old 06-15-2018, 10:29 PM   #22
Teseo
Drives: frs
Fuck yeah! Power/weight ratio is everything.
How much you weight, after lunch and some beers
Old 06-15-2018, 11:45 PM   #23
I didn't plan out my follow-up. I figured the older crew would pick up on it first.
http://www.ft86club.com/forums/showthread.php?t=77762
Old 06-16-2018, 12:53 AM   #24
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
TLDR for the new folks? I'm lazy.
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (06-16-2018)
Old 06-16-2018, 01:18 AM   #25
It's worth reading. OP is a delusional computer repair guy that happens to live right in my town. He spent a lot of money on a whim with zero understanding. Results were as expected. A real cringefest.
Joesurf79 (06-16-2018), NoHaveMSG (06-16-2018), Spuds (06-16-2018)
Old 06-16-2018, 03:03 AM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That was more entertaining then the last Star Wars movie.
I was working in the motorcycle industry in the early 2000's. I remember a lot of weird stuff coming out. The only thing that really stuck around was hemholtz resonators, and those pretty much just to meet sound restrictions.
Old 06-16-2018, 10:26 AM   #27
Joesurf79
Joesurf79's Avatar
I see what you did there that right there is internet gold
Old 06-16-2018, 01:11 PM   #28
SuperTom
SuperTom's Avatar
That's why I like the dyno #s on the Ace 350 header. Doesn't gain much up top compared to whats out there but the mid range torque dip turns into a torque surplus
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Exhaust Advice. I want a loud exhaust system please help Rambo2469 Engine, Exhaust, Transmission 28 04-21-2017 02:41 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
How secure is the Keyless Entry and Start system? SeattleJeremy BRZ First-Gen (2012+) — General Topics 31 09-22-2013 11:23 PM
ice racing theory! 7thgear Tracking / Autocross / HPDE / Drifting 3 01-30-2013 01:07 PM
