Old 06-14-2018, 01:44 PM   #15
andrewsbutt
andrewsbutt's Avatar
Drives: 2017 BRZ LTD
Originally Posted by JeremyR View Post
Looks good! How was the side skirt install? any issues?
Thanks! Nope, it was very easy, as there are already pre-made holes underneath the car. Took about 30-40 mins in total to complete.
andrewsbutt is offline   Reply With Quote
The Following User Says Thank You to andrewsbutt For This Useful Post:
JeremyR (06-14-2018)
Old 06-14-2018, 02:35 PM   #16
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
https://www.blackhawkjapan.com/searc...q=trd+side+k1x
It looks like there are two with different product numbers? Which one did you grab? did it come with both sides for $380?
Sorry about the bombarding of questions!!
spicyricecake is offline   Reply With Quote
Old 06-14-2018, 02:41 PM   #17
spike021
spike021's Avatar
Guessing 18001 is the zenki version and 18004 is kouki version.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 06-14-2018, 03:12 PM   #18
spicyricecake
Oh I see. are the side skirt fitment different between the two gens? I was not aware.
Old 06-14-2018, 03:50 PM   #19
spike021
spike021's Avatar
Fitment is likely the same, but the design is slightly different.
Old 06-14-2018, 04:31 PM   #20
spicyricecake
ah! I got you. you meant they were 2 designes made for zenki and kouki.
There is slight variation of the design. it all makes sense now
Old 06-14-2018, 04:44 PM   #21
andrewsbutt
Fitment will be the same for sure. I just don't like how the newer version has the square-ish cut off near the front of the skirt. Seen it in person, and kills the lines.
Old 06-14-2018, 04:45 PM   #22
andrewsbutt
Its all good! No worries. It comes with both sides, painted, and it'll be $380 + ~$200 for shipping and customs.
Old 06-14-2018, 08:33 PM   #23
Racecomp Engineering
That looks REALLY good. I like the TRD and STI combo.
- Andrew
andrewsbutt (06-15-2018), spike021 (07-24-2018)
Old 06-15-2018, 02:57 PM   #24
andrewsbutt
- Andrew
Thanks! I appreciate it. Still more to come
Old 06-25-2018, 03:23 PM   #25
andrewsbutt
Installed ARP Extended studs, and Eibach 10mm Spacers (Only for the rear). See original post.
Old 07-24-2018, 01:25 AM   #26
andrewsbutt
Installed Corsa exhaust. See original post.
Old 07-24-2018, 09:58 AM   #27
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Love the car! Sorry to hear the Corsa install was so frustrating, I for one wish they used v-band clamps or some other system. But once you get the install and alignment right, that sound makes all your troubles go away.
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
andrewsbutt (08-22-2018)
Old 07-28-2018, 10:54 PM   #28
Boudin
Drives: Soon
Strange you had issues with it, I have the same Catback. I didn't use the spring bolts, I belive the instructions said to use their hardware. I just left every thing loose until I got all pieces installed then started aligning and tightening from the front back. My tips are perfectly centered but the drivers side sticks out about 1/2" further.
The Corsa sound is glorious.
Sent from my SM-G965U using Tapatalk
Boudin is offline   Reply With Quote
The Following User Says Thank You to Boudin For This Useful Post:
brz, subaru, subaru brz, trd, volk
Dan's Whiteout FR-S Slow Build xXDeathMaliCeXx Member's Car Journals 36 09-29-2016 01:51 AM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 08:05 PM
Twins are slow? Not as slow as these cars! babydriver Scion FR-S / Toyota 86 GT86 General Forum 66 12-12-2014 12:09 AM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 06:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 05:35 PM
