Old 06-07-2018, 04:42 PM   #1
Seanzky
Drives: Slow
Grimmspeed front license plate relocator pushing down on bumper
So I'm very new to these forums and I've only owned the car for a week. I have a 2018 Toyota 86 GT Black. I've installed the relocation kit and the shaft is pushing down on the black part of the bumper (the strip above the grill), right below the tow hook receptacle/opening.
Is this normal? Do those of you who use the Grimmspeed kit shave down parts of the black plastic? I'll upload pictures when I get the chance in a bit.
I've tried searching the forums but couldn't find anything on this topic so I thought I'd start a new one. Thank you in advance.
Seanzky is offline   Reply With Quote
Old 06-08-2018, 02:38 AM   #2
NRXRaptor
my guess is that particular relocation kit is for pre facelift models
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Seanzky (06-08-2018)
Old 06-08-2018, 06:47 AM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Remove the Grimmspeed shaft then screw in your OEM tow hook found in the trunk with the jack stuff. (if the 2018's still have it)
Does that push down on the bumper? Is there a difference in the diameter of both shafts?
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 06-08-2018, 09:35 AM   #4
Seanzky
Drives: Slow
Originally Posted by ERA View Post
I might have to. So disappointed.
I know on the FT86SpeedFactory website it shows the new bumper style, but does it really fit without pushing down on the black part? I can't really tell from the pictures.
Old 06-08-2018, 09:39 AM   #5
Seanzky
Drives: Slow
That's the first thing I did. The diameter between the two are about the same. It pushes down on the bumper slightly but not as much as the Grimmspeed does. If the shaft was only 4-6mm thinner, this wouldn't be an issue. I'm considering returning the Grimmspeed, shaving off part of the shaft/bolt where the bumper touches it, or cutting a small U on the black part of the bumper. I'm sure I'm not the only one experiencing this. I'm curious to know what others did for their car.
Old 06-08-2018, 10:18 AM   #6
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Just an FYI. I have the Turobxs plate re-locator and the shaft diameter is within thousandths of an inch of the OEM tow hook shaft, so it will touch as well.
Old 06-08-2018, 01:22 PM   #7
Paul86Ski
Drives: Stockish 2018 Toyota 86
If you look at the pictures on the site it honestly looks like they removed the black piece where the rod would hit.
Paul86Ski is offline   Reply With Quote
The Following User Says Thank You to Paul86Ski For This Useful Post:
Old 06-08-2018, 01:24 PM   #8
Seanzky
Drives: Slow
Thanks so much for saving me the hassle, BirdTRD! I'm all out of options then. I'll probably buy another piece to cut a U-shape on and keep the original intact. My OCD won't forget that behind that license plate is a piece hanging.
Old 06-08-2018, 01:25 PM   #9
Seanzky
Drives: Slow
You're right! I can kind of see it in one of the pictures now! Hmm... either I do that or buy another piece to cut a "U" out of to accommodate the shaft.
Old 06-08-2018, 01:34 PM   #10
Paul86Ski
Would it be possible to just grind down some of the actual rod instead of messing with body pieces? I am not sure how much metal would need to be removed for it to fit right.
Old 06-08-2018, 02:58 PM   #11
Seanzky
Drives: Slow
It's possible but I don't have the tools to pull it off. I'd have to rig something up and file it down while it's rotating on something. The thing is this kit cost me $90. If that black piece is cheaper, I'd rather buy that OEM piece and cut out the shape.
Old 06-08-2018, 06:11 PM   #12
BasementN3k0
The Angry Brown Guy
BasementN3k0's Avatar
Drives: 2016 Tacoma & 2018 86 GT Black
I used the same grimmspeed relocation mount on my 86 black edition, and I had it on my 15 fr-s with no problems. Adjust so the plate won't touch the bumper.
BasementN3k0 is offline   Reply With Quote
Old 06-08-2018, 06:28 PM   #13
Paul86Ski
Let me know if you can find that black piece somewhere, Toyota's diagram for the from bumper doesn't seem to have it listed
Old 06-08-2018, 08:01 PM   #14
Seanzky
Drives: Slow
It's not the plate touching the bumper. It's the main shaft/bolt pushing down on the bumper. See the pictures in my original post.
FS> Grimmspeed front license plate relocator (SOLD) jgonx213 Exterior Parts (Aero, Lighting, Etc.) 11 01-25-2015 11:10 PM
FS: Grimmspeed License Plate Relocator Kit Lverasky Exterior Parts (Aero, Lighting, Etc.) 1 12-01-2014 11:27 PM
WTB: Grimmspeed license plate relocator trailofdead Exterior Parts (Aero, Lighting, Etc.) 0 11-13-2014 02:28 AM
FS: GrimmSpeed License plate relocator DIM Exterior Parts (Aero, Lighting, Etc.) 5 09-13-2013 03:37 AM
FS Grimmspeed License Plate Relocator LI/NY whitefrs Exterior Parts (Aero, Lighting, Etc.) 8 04-05-2013 05:09 PM
