Old 06-04-2018, 08:44 PM   #547
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by weederr33 View Post
Oh.. Wow that is a long time. Since I don't have to worry about CARB I never pay attention to the process length. But a few years does seem long.
The problem is that they may have seen the problems Edelbrock had with they CARB tune, and they decided to tweak some things, or they are having problems traveling to the states from Australia to do tests and all the stuff that goes into it. At minimum, they have to fly a team here, ship a car or get a donor car, install the kit then CARB test it then perhaps have to retest, etc. I can imagine the distance would be something that delays the process.
Even if someone wants to take the chance to run around with an illegal kit, they still need to pull the kit off each time they smog, and that will be starting next year for 2013 vehicles, so I can imagine Harrop wanting to get the kit approved too, or lose more sales to Edelbrock.
FYI, this thread was started on 7/22/16. That is almost two years ago, and it was for owners; ie, not a product release.
On 12/04/2014, this thread was started, and people seemed to be buying their kits in late 2015:
http://www.ft86club.com/forums/showt...ghlight=harrop
And on The Racer's Line page:
Currently pending CARB approval for Sale and Use in California
https://www.theracersline.com/produc...er-kit-frs-brz
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
weederr33 (06-04-2018)
Old 06-04-2018, 10:10 PM   #548
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
@HarropOz @The Racers Line
Any CARB updates?
What plugs and gaps do you suggest?
Hey I'm sorry, I have so many messages on too many platforms and I tend to lose track. I like to take my time and reply fully but often if I don't have the time, I read the message, and then forget to go back. Really bad habit. I also wanted to have a full update for you before I sent something.
Stick with stock plugs and gap. Don't worry about changing them until 60k. They are very robust and handle boost just fine.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
Irace86.2.0 (06-04-2018)
Old 06-04-2018, 10:14 PM   #549
The Racers Line
I will have something for you this week. Instead of sitting by and waiting though, I have offered to help them even more with the process with some of the resources I have here, that they do not, so I hope that will help. Sadly, with CARB, if you "fail" or make tweaks you have to back to the end of the line. Something Edelbrock ran into as well I believe.
The Following 4 Users Say Thank You to The Racers Line For This Useful Post:
CxG (06-07-2018), firekat (06-05-2018), Irace86.2.0 (06-04-2018), PhyrraM (06-05-2018)
Old 06-04-2018, 10:47 PM   #550
Irace86.2.0
Thanks.
Im at 63k and will be changing when I install my kit. Thanks for the input. It seems that is what most people have been saying too, that oem is cold enough and the gap is fine, but it is good to hear it from you
Thanks for your efforts to help them. Regardless of whether you stand to benefit financially from the kit getting CARB approved, neetheless, us owners in California appreciate the effort
vintagemxer (09-03-2018)
Old 06-06-2018, 05:15 AM   #551
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by PR138 View Post
Dumb question, but does the system sound any different at that boost level? Supercharger whine, air/boost noise, etc.? I would assume not due to the design, but I'm curious if it changes anything with high boost.
No difference.
The Following User Says Thank You to sw20kosh For This Useful Post:
PR138 (06-06-2018)
Old 06-06-2018, 05:18 AM   #552
sw20kosh
Originally Posted by CxG View Post
could you make it scarier with a smaller pulley or at you at the engines limits?
There are a few smaller pulley sizes. 18, 20 and 22 psi pulleys I believe. Those are transmission breaking pulleys.
CxG (06-07-2018)
Old 06-07-2018, 11:26 AM   #553
CxG
Drives: Pearl White '13 ZN6
good, because long term goals are transmission breaking numbers lol. What stage 2 cam do you have? did you do anything like swapping the throttle body or valve porting? Mind sharing your engine build or is that a secret you can't share =]? I'm just really loving the numbers you're putting down without having hit the blowers limit just yet.
CxG is offline   Reply With Quote
Old 06-07-2018, 07:03 PM   #554
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
What about longetivity with the stock pulley on stock engine?
MS, CSCS, TSAC-F, CPT
Old 06-07-2018, 07:54 PM   #555
The Racers Line
No issues so far. The stock pulley is only about 8psi. Lately most of the kits I have been selling have been bumping to the 9psi pulley off the bat. We are even running the 9psi pulley, on e85, on one of the shop track cars without issue. These cars and engines seem to be pretty happy in the 7-10psi range with good fuel and tuning.
The Following 2 Users Say Thank You to The Racers Line For This Useful Post:
byun (06-07-2018), weederr33 (06-07-2018)
Old 06-07-2018, 08:00 PM   #556
The Racers Line
Thanks.
Lord knows I'll be moving a lot more of these in CA once the CARB certification is done, but plenty are going to other states now, and many are taking the chance here in CA. Regardless, I do really just love the kit, the company, and the work they put in, and I want to see it succeed here in the states.
So I just got off the phone with the gentlemen at Harrop. They are having an engineering meeting on the CARB process tomorrow. The have also assured me, that this WILL NOT be something they give up on. It WILL be CARB certified, so there is no fear of it not happening!
The Following 5 Users Say Thank You to The Racers Line For This Useful Post:
byun (06-07-2018), Irace86.2.0 (06-07-2018), johan (06-07-2018), PhyrraM (06-08-2018), vintagemxer (09-03-2018)
Old 06-07-2018, 11:03 PM   #557
Irace86.2.0
That is fantastic to hear! Keep up the good work man
Old 06-08-2018, 10:01 AM   #558
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
Neil, have you had the chance to play with the variable boost controlled version that have been working on? Any thoughts? Seems ideal for those of us with flex fuel setups.
Sent from my VS996 using Tapatalk
PhyrraM is offline   Reply With Quote
Old 06-08-2018, 05:07 PM   #559
The Racers Line
Not yet! But it will be going on the shop car very soon, and I'll put up my first impressions when it does!
PhyrraM (06-08-2018), PR138 (06-12-2018)
Old 06-13-2018, 01:39 PM   #560
sw20kosh
Piper stg2 cams
Major headwork by PortFlo
1mm oversized valves
2.0L forged bottom end
ACE A350 with custom 3" FP and 3" exhaust
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
byun (06-14-2018), CxG (06-13-2018)
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
