#393 |
Drives: MX5 Miata Mk2.5 1.6
#394 |
Drives: '13 FRS - STX
FYI this is who you're saying shouldn't be allowed to use the internet:
http://elementtuning.com/ I mean yes, the post in itself was rather weird, the whole point of a brake booster is that it stores the vacuum energy giving you a good two or three power assisted pumps of the brake without the engine on, which he should have noted in his suggested test for all the readers so I don't agree it's driver input overlap causing a lack of braking force (or at least the way Phil describes it with a 'lack of vacuum', I lean towards it being electrically induced) but when you try to put someone down in a technical discussion by calling them children it's pretty weaksauce. And for my own pedantry, I like forums that ban people for triple posting, multi-quote isn't that hard. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Flint8821 (02-06-2019), Gringosteve (05-16-2016) |
#395 |
So to sum up, I must be banned cause I didn't multi quote replies that spread over 4 or 5 pages apart and someone who repeatedly posts wrong technical information in a car forum is just expressing his "view on the subject"???
I may sound a bit childish myself now but... glol! |
| The Following User Says Thank You to Blokatos For This Useful Post: | strat61caster (05-20-2016) |
#396 |
Drives: stx class lava frs
hey guys, new contributor, long time lurker here,
I tried the Pedal Dance at my last autocross practice day, and was not impressed. i normally just puch and hold the Trac button, and i do still occasionally activate ice mode, but after the pedal dance, pedal effort was unpredictable and sometimes exessive, and i still got into ice mode a few times. here is my basic setup Stoptechs front and rear re71r (265/35/18) edelbrock supercharger eibach coilovers custom medium rear swaybar left foot braking. maybe i am doing it wrong? any advice would be appreciated. |
#397 |
Per most of the advice in this thread: practice. Trying it out when you only have 3-4 runs to try and figure it out just isn't enough time for average folks.
#398 | |
It was a practice day, and I got 16 runs on a 76 second course. I tried Pedal dance for most of the day, and gave up around run 10 or 12. also I am a relatively experienced autocrosser, mostly in prepared and Mod class cars. probably not nationally competitive level, but i was pretty close at one time (got a trophy in FP driving an RX-7 at the solo Nats back in the 90's! ) Last edited by mitch t; 05-20-2016 at 07:49 PM. Reason: more info |
| The Following 2 Users Say Thank You to mitch t For This Useful Post: | 2superblus (05-16-2018), strat61caster (05-20-2016) |
#399 |
Drives: 2017 BRZ
Well... some oddball results today.
The afternoon was out because something tripped the CEL for ECU communication, which put the car into limp mode... after getting that sorted so I could actually drive I forgot to re-enable my 86Nanny - and didn't realize till after we were done for the day. The morning... well, my first run was fastest, but I tried with ABS disabled today (2nd run only.) If it's a good idea, I'm not ready for it! On the other hand, the ease with which I found a rear tire locking up points to a potential reason ice mode is kicking in as well. More experimenting tomorrow, we have another event. |
| The Following 2 Users Say Thank You to cjd For This Useful Post: | GeorgeJFrick (05-21-2016), TorontoNat (06-06-2018) |
#400 |
Thanks
Using pedal dance first time this weekend. Should have been doing it sooner. What was the car tryin to do with the brakes with the 5 second press I'll never know.
#401 |
Reverse Burnouts
Drives: 2013 Argento FRS
anyone know if pedal dancing and activating ice mode on the 17's is different since the vsc and abs has been recalibrated?
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#402 |
Drives: 2024 GR86/ 2015 FRS
At the Pittsburgh Tour, my co-driver and I were getting ice mode multiple runs. The lot is bumpy.
A week later at the NJ Pro Solo, I got ice mode every single run (even multiple spots during the same run) also a bumpy lot I heard getting better rear pads might help?? Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#403 |
Drives: 2013 Scion FR-S Asphalt [Gray]
Question:
What is the difference between pedal dance mode and that mode the car goes into when your brake switch button thing under the brake pedal fails. For the latter: The lights that come on are the slip light indicator (stays solid) and the ABS is working indicator light (also stays solid). I have never tested the ABS in this mode (my car does this aprox once a year.. brake switch fails... lights come on until I buy the stupid 12$ part and replace it.) but everything else is off. Perhaps removing the little switch under the brake pedal is the only way to truly turn everything off including ABS. Can anybody confirm/ give more info.
"Enjoying Performance because of it's nature not because of it's quantity''
#404 |
The switch under the brake pedal is for the brake lights.
#405 |
Precisely. and when removed or faulty it puts the car in the mode I'm asking about.....
#406 |
Unlikely, pedal dance doesn't trip the abs light, you'll have to test.
| The Following User Says Thank You to strat61caster For This Useful Post: | TorontoNat (06-06-2018) |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
