Old 07-11-2012, 07:48 PM   #1
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Stock tires usage in winter?
Does anybody know how well our stock "Prius" tires will work in winter temperatures? I will not drive in the snow unless I get caught out so worst case is driving with a light coating of snow. I'm hoping I can just save my stock wheels and tires for the winter and then get a set of aftermarket wheels and tires for the summer. Thanks.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-11-2012, 08:02 PM   #2
MTeator
First 86
They'll get very hard and very slick as the rubber is designed for traction when warm. They're not really Prius tires as we know them, they're a summer tire that's available on a special option package on the Prius in Japan. Sell the stock tires and buy winter tires or one of the better all seasons. I'm on the fence for all seasons or winter tires... if it snows here I just work from home <shrug>.
Come winter though they'll be plenty of people claiming they work fine. Then one day they won't, and we won't hear from them again unless someone finds their facebook posting of their car in a ditch.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 07-11-2012, 08:35 PM   #3
ft86Fan
ft86Fan's Avatar
I've been driving with extreme summer performance tires on my rear wheel drive cars for years and it can get real scary. The tires basically turned into hard plastic. Now I have a set of winter tires on one of my car during the winter and I don't think I can go back. Was hoping our stock tires will at least stay a little bit soft for the winter but I think you are right that I should just get a set of winter tires.
Old 07-11-2012, 08:42 PM   #4
OrbitalEllipses
Drives: Attitude
A dedicated winter tire set will beat any other tire in snow, rain, slush, and even ice. Though that last one really depends on which snow tires you do get. If you've driven an All-Season in winter, a true snow tire will blow your mind.
Old 07-11-2012, 09:10 PM   #5
xwd
One good thing about moving south... our last winter the stock tires would have held up fine. When it actually snows or ices (which it didn't last year), I don't leave the house!
Back up north I always had a set of cheap wheels or steelies with Nokian Hakkas.
Old 07-11-2012, 09:20 PM   #6
MTeator
First 86
I'm holding off on my decision of what to buy until I see what this winter is like.... so far with as brutal as the summer has been with my luck winter will give us a blizzard in kentucky Our climate here is usually about as far north as you'd want an all-season in winter, at least in the city. If I lived in the hills... yeah real winter tire.
Old 07-11-2012, 09:38 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
cold temperatues you should be fine, just deflate your tires a bit and slow down your tempo compared to summer driving
but if there is snow on the ground for considerable amount of time where you are i would swtich to dedicated winters
Old 07-11-2012, 09:39 PM   #8
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Agreed.
Chewie4299 is offline   Reply With Quote
Old 07-11-2012, 09:44 PM   #9
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
Say we do opt for winter tires, when would be the time to put them on? First snowfall? Towards the beginning of Fall? And if we do put them on, will they be badly worn if it doesn't snow? Any help is appreciated.
Sent from HTC Rezound using Tapatalk 2
mezdup is offline   Reply With Quote
Old 07-11-2012, 09:48 PM   #10
Chewie4299
Spaceman
Chewie4299's Avatar
I think it's less about snowfall and more about temperature.
I'd switch when it gets cold enough that IF there were precipitation it would be snow.
Not long after you start seeing frost in the mornings is probably best.
Old 07-11-2012, 09:48 PM   #11
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
I'm leaning towards winter tires myself, or just driving my other car (Accord) with all seasons. The problem is that I'm in CT and we may or may not get a lot of snow or cold temperature. I'd rather not drive on my winter tires when it's warm out.
Jidonsu is offline   Reply With Quote
Old 07-11-2012, 10:03 PM   #12
b1pkkf26
Drives: 2005 civic, FR-S
Yeah I'm definitely running snow tires, even though here in toronto, we had barely any snow last two season. More worry about the temperature and first time driving rwd, better be safe then sorry IMHO.
b1pkkf26 is offline   Reply With Quote
Old 07-11-2012, 10:08 PM   #13
tinger00
tinger00's Avatar
Drives: 2013FRS-FIRESTORM
I already pulled the stock tires and threw them on my 17x8 wheels that were my dedicated summer tires for the car I just traded-in, a AWD Forester. I drove during the winter here in Chicago with dedicated snow tires on the Forester and will definately be throwing some Snow Tires on the stock 17x7 wheels for the FRS. They even made a huge difference.....
94 EJ1 Civic w/8psi Super Charger.
03 GGA WRX @16psi
04 SG Forester N/A
13 ZN6 FRS N/A
tinger00 is offline   Reply With Quote
Old 07-11-2012, 10:10 PM   #14
tinger00
tinger00's Avatar
I usually put them on when the temps hold steady under 55 deg. Snow tires have better traction than all seasons at that temp. Here in Chicago its usually last week of October - 2nd week of November.
03 GGA WRX @16psi
04 SG Forester N/A
13 ZN6 FRS N/A
Winter tires jesseps CANADA 83 12-13-2016 05:06 PM
Winter tires, what? Rossman CANADA 12 07-12-2012 04:48 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 08:33 AM
Winter tires and wheels, what is your plan? RaceR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-01-2012 10:52 PM
Stock tires winter feldy Scion FR-S / Toyota 86 GT86 General Forum 33 05-29-2012 10:38 AM
