go_a_way1
Old 06-01-2018, 11:00 PM   #4565
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Hi, I am using my car for competition only (track, race) with the JRSC C38. I'm purchasing the high boost pulley + injectors, fuel pump + E85. Which would be a better option to buy for engine cooling? The JR oil cooler or the JR radiator and oil cooler?
Toyota GT 86 is offline   Reply With Quote
Old 06-01-2018, 11:04 PM   #4566
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
I don't have the kit but consensus from what I've read on here is the air to air kit is recommended for racing and warmer climates, and the rad/cooler combo is recommended for colder winter climates and occasional tracking/autocross.
PR138
IG: @pr.138
2008 LBP Honda S2000
2013 UM Scion FR-S
PR138 is offline   Reply With Quote
Old 06-02-2018, 02:16 AM   #4567
CSG Mike
CSG Mike's Avatar
Oil cooler.
Old 06-02-2018, 05:41 AM   #4568
mrbbs
Drives: GT86
Anyone knows what extra weight a C30 of C38 kit adds up?
I've read that the Edelbrock was quite heavy at 120lbs.
I'm looking to have 80-100 bhp added to my 2018 Subaru BRZ. I use it 99% for fast road use and want the most reliable option.
I'm living in Belgium so temperatures are always between -5 and 30° C (23-86 fahrenheit).
mrbbs is offline   Reply With Quote
Old 06-02-2018, 06:53 AM   #4569
iamrich83
Drives: 2017 Toyota 86, 2000 Mazda Miata
Originally Posted by BR-ZED View Post
Thanks for the replies guys. Could you all specify if you have the C30 or the C38? Worrying if that the C38 may not have enough low-end in carb form. The low end is important to me because I will be using the car primarily for autocross, where downshifting isn't really an option
Which class will you compete in?
iamrich83 is offline   Reply With Quote
Old 06-02-2018, 07:30 AM   #4570
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
SM for SCCA.
The other club I race with has classes based on vehicle weight and power. But honestly I just want to target FTD (eventually) with any setup.
BR-ZED is offline   Reply With Quote
Old 06-02-2018, 07:36 AM   #4571
BR-ZED
BR-ZED's Avatar
+30 lbs In my weight spreadsheet. +32 for the C38.
The Edelbrock is in the ballpark of <edited> iirc but don't quote me on that. That's because you install around 100 lbs of parts but also remove some.
Edit: thanks to CSG Mike, (see post 2 below mine) it is +55 lbs.
Last edited by BR-ZED; 06-03-2018 at 04:30 PM. Reason: updated to avoid incorrect figures floating around
Old 06-02-2018, 07:42 AM   #4572
BR-ZED
BR-ZED's Avatar
58lbs in a 32x24x18 box Packaging weighs a LOT; it is meticulously packed. I believe the kit components, all inclusive of everything going on the car, is 34 lbs. You'll also remove 4 lbs of parts from the car.
You're in California; get the CARB tune.
This is the post where 30 lbs came from. Edited my post above.
Old 06-02-2018, 06:59 PM   #4573
CSG Mike
CSG Mike's Avatar
Net added weight with the Edelbrock kit is closer to 55lbs.
BR-ZED (06-03-2018), funwheeldrive (06-05-2018)
Old 06-03-2018, 11:25 AM   #4574
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Originally Posted by stlgrym3 View Post
Who has JRSC with aftermarket header? Anyone pairing it up with Tomei EL? What’s your review?
Running mine with the HKS EL, 10/10 would do again
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
Old 06-05-2018, 09:51 PM   #4575
stlgrym3
Did u get custom tune for your setup? Which one did you get?
stlgrym3 is offline   Reply With Quote
Old 06-05-2018, 10:12 PM   #4576
Anderzz
Anderzz's Avatar
Etune from delicious.
Been working great but I'm probably going to get it Dyno tuned at BrenTuning
Old 06-05-2018, 10:22 PM   #4577
stlgrym3
What’s ETune? I will get a custom tune from delicious as well when I pair up my C30 with tomei EL.
Do u have a C30 or C38? I was told C38 requires ACE header plus high boost pulleys.
Old 06-05-2018, 10:27 PM   #4578
Anderzz
Anderzz's Avatar
Etune is just an electronic tune, in other words I didn't physically bring the car to them. I put the tuning software on my own laptop put on the tune, took logs, sent the log results to Delicious and then they sent back the tune after a few rounds of logs.
I have a C38, whoever told you it "requires" anything is just plain wrong. Neither the C30 or C38 require anything, they can both be run on otherwise stock systems, or with any header setup.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
