Old 05-30-2018, 10:33 PM   #2339
dnieves
Drives: FR-S 10 Series
I replaced almost all my bulbs with LEDs and an electronic flasher (to prevent hyperflash and errors) since I purchased my 10 Series in 2013. I finally changed the last two bulbs when I swapped out the factory side markers with JDM OEM clear side markers from FT86SpeedFactory (I used the bundled yellow LEDs).
Here's my problem:
When I have my headlights & parking lights off (just the OEM LED DRLs turned on) the clock and dual AC display flash whenever I use my turn indicators.
BUT when I have my parking or headlights turned on the clock and AC display does not flash when I use my turn signals.
I sent an email to FT86SpeedFactory last weekend but have not received a response. Could it be I need one of their $60 flashers or is this normal when you have OEM LED DRLs (ex. Monogram, Release series, BRZ, 86)?
dnieves is offline   Reply With Quote
Old 05-31-2018, 07:49 AM   #2340
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
Here's my problem:
I had pretty much the same issue when I upgraded to LED's on my 10 series. I ended up ditching the LED flasher relay, put the stock relay back in and put resistors on the front blinkers to fix the problem.
czechm8 is offline   Reply With Quote
Old 05-31-2018, 09:22 PM   #2341
dnieves
Thanks!!
Old 06-05-2018, 01:06 AM   #2342
Drake_93
Drives: 10-Series Turbo FR-S #2483
Hey guys #2483 finally checking in.
I see she hadn't been posted about before.
#2483 spent 54k miles down in Maryland, eventually picking up some extra parts before sadly being discarded. I now have her under good care in Northeast Ohio.
Drake_93 is offline   Reply With Quote
Old 06-05-2018, 10:19 AM   #2343
Cheeky
Drives: 10 Series FRS
Great shots, great car, very clean. (turbo inside)
Cheeky is offline   Reply With Quote
Old 06-06-2018, 08:49 PM   #2344
HawkBYU
Drives: NA
Joined the club a couple weeks ago, and am loving it so far. 26k Miles
HawkBYU is offline   Reply With Quote
Old 09-10-2018, 11:37 PM   #2345
jcb476
Release 10 Series
jcb476's Avatar
Drives: 2013 10 Series FR-S #1874
#1874 A/T now residing in Bloomington, IN. Second owner and purchased on 08/11/2018 with 28222 miles. Have replace all lights with LEDs except for HID headlights including switchbacks for front turn signals.
jcb476 is offline   Reply With Quote
Old 10-06-2018, 09:44 PM   #2346
jflogerzi
jflogerzi's Avatar
3rd owner of # 0553. Bought it with 58K on the ODO. Almost 60K now in 2 months of ownership.
2013 Series 10 FRS #553
Old 11-14-2018, 01:38 PM   #2347
adantea
Drives: 10 Series #500
2nd owner of #500. The car spent the first 55k of its life in Michigan and is now in Socal
adantea is offline   Reply With Quote
Old 11-14-2018, 01:42 PM   #2348
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Nice! Got a pic of the # plate?
MJones_RB is offline   Reply With Quote
Old 11-14-2018, 08:06 PM   #2349
dnieves
Assuming our 10Series were built in one batch will they be part of the recall?
Old 11-16-2018, 08:10 AM   #2350
PatSciFRS
Drives: Scion FRS 10 Series
I checked mine and it's not on the recall list.
That's a good thing because otherwise it is a fairly involved repair work that requires engine pull out.
Have you checked yours at https://www.nhtsa.gov/recalls ?
PatSciFRS is offline   Reply With Quote
Old 12-01-2018, 08:48 PM   #2351
dnieves
I've checked several times and not on the list. Is the same true for you fellow 10 Series owners (I hope so)?
Old 12-03-2018, 12:46 PM   #2352
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
#974 checking in. Just ran my VIN# not to long ago and my 10 series did not pop up. Fingers crossed.
86 Owners of New England - Registry MannyO New England 247 10-27-2025 03:45 PM
**Tennessee Registry** Xryn Southeast 139 11-02-2022 12:31 PM
Mid-Atlantic Owners Registry. IloveBaldEagles Mid-Atlantic 366 10-24-2022 08:55 PM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
First 86 Registry: 2013 Scion FR-S Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 44 05-18-2012 05:54 PM
