Old 06-04-2018, 07:02 PM   #16871
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Originally Posted by Zoid View Post
Not today, but on Friday I finally had the springs installed, threw on some new lugs while I was at it. Eibach Pro Kit. Finally had a chance to take it out and snap some decent pictures earlier today.
Before
After
Nice Vader, that's all I noticed. I can't seem to look at the springs without jumping back to vader.
pcguru2000 is offline   Reply With Quote
Old 06-04-2018, 07:11 PM   #16872
pcguru2000
pcguru2000's Avatar
Originally Posted by BreakTraction View Post
So My wing Finally came in from AliExpress took about 25 days to have it delivered from the day I ordered it but over all super happy with how it turned out really makes the cars rear end look amazing.
@BreakTraction for more on my build.
Do you get more attention from the police because of the wing?
Old 06-04-2018, 07:15 PM   #16873
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Installed an STI front lip (with help from friends who know how to handle a drill):
Looking sweet, love the 2017 bumper and OEM lip.
I think those retro california plates are the best looking custom plates ever. I'm curious.. what does SLURVE mean?
In other news, I installed CQUK to my new wheels. Getting an Eibach pro kit and wheels + new rubber installed next week. Getting excited!
wolffbite is offline   Reply With Quote
Old 06-04-2018, 07:17 PM   #16874
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Originally Posted by rvoll View Post
Installed front parking sensors and hardwired radar detector. The two parking sensors fit right into corners of the black front grille so they are not even noticeable. Because I didn't want to use an add-a-fuse since the fuse cover would no longer fit, I used the power outlet behind the glove box and just used a plug adapter and sent it to an auxiliary 6 outlet small fuse block. I located the fuse block and sensor control unit in the passenger footwell and the monitor under the left side of the dash on the driver's side. I really didn't want any junk on the dash, either this or a phone mount, so it is a great position. I also connected the radar detector to the same fuse box. Having done this before, I also disconnected the buzzer inside of the sensor monitor because I know when to look and sometimes a heavy rain will set it off. Works great and prevents me from scraping the front. Here are the parts I used:
I also tightened the ProClip Console Phone mount which is the best solution I've seen for holding a phone. Since I have Bluetooth and Android Auto, there is no reason to have the phone high on the dash, but I don't like it just loose in the car either. And I didn't have to make any holes or take off parts to get it installed.
I have an Android Auto head unit in my BRZ and I also didn’t want any junk on the dash or to have my phone loose in the car. I installed the OEM armrest and it has a groove that allows for a cord to pass into the center console area with the lid closed, so that is where my phone resides while connected to Android Auto.
NCtoBRZ is offline   Reply With Quote
Old 06-04-2018, 07:19 PM   #16875
spike021
spike021's Avatar
Thanks! It's probably the best choice for a non-CF lip out there currently for the 2017+ bumpers. Eventually if/when more options come out I may swap but at this point new ones could be 1-2 years away.
Nice wheels
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 06-04-2018, 07:41 PM   #16876
spike021
spike021's Avatar
Oh shit, sorry I forgot to respond.
SLURVE is a type of pitch in baseball. Combination of a curve and slider.
I like baseball and felt like those two pitches themselves sort of fit the car since it's fun in the curves and it can slide a bit. Felt like a cool way to name it.
Old 06-04-2018, 07:46 PM   #16877
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
That's where I used to store my phone, but it moved around too much and occasionally I wanted to be able to look at the screen because I don't use Android Auto all of the time. Which armrest did you get? The one that slides back or tips up?
rvoll is offline   Reply With Quote
Old 06-04-2018, 08:00 PM   #16878
NCtoBRZ
The one that tips up, this one https://www.86speed.com/products/gt8...t-lhd-red.html Originally I bought it just to have somewhere comfortable to rest my arm and to be more aesthetically pleasing than a gaping hole... but it also solved the problem of where to put my phone.
Old 06-04-2018, 08:05 PM   #16879
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Originally Posted by pcguru2000 View Post
That vinyl overlay, did you buy the exact dimensions to make it look that good or did you cut it?
Where did you get it?
Luckily they come cut to size, I'm not that precise lol. Usually they come with the right sizes for front/rear and sometimes one for the steering wheel.
The blue stars logo on the rear is from ebay and the front and steering wheel are from jdmfv.com. The jdmfv stuff is a little pricier than most of whats on ebay/amazon, but I gotta say I had zero air bubble issues with them (I ruined one of the ebay ones lifting/reapplying/trying to get air bubbles out).
BRZyJ is offline   Reply With Quote
Old 06-05-2018, 01:03 AM   #16880
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pic plz
And yes, marker lights are going back in. Next on the list is bumper quick release.
Clipdat (06-05-2018)
Old 06-05-2018, 04:57 AM   #16881
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
Installed a new clutch today. Throw out bearing went out on me less than a week after coming back from a deployment. Since the throw out bearing gave up and you have to take apart the transmission, I figured I’d replace the clutch too. Went with Sounthbends stage 2 endurance clutch. Good for about 350 ft/lb of torque
sactownbwoy is offline   Reply With Quote
Old 06-05-2018, 07:34 PM   #16882
BreakTraction
BreakTraction's Avatar
Nope Not a single cop has stopped me I actually had a few cops give me a thumbs up lol.
BreakTraction is offline   Reply With Quote
The Following User Says Thank You to BreakTraction For This Useful Post:
pcguru2000 (06-05-2018)
Old 06-05-2018, 07:55 PM   #16883
pcguru2000
pcguru2000's Avatar
Hood ventilation is off the hook!
The Following User Says Thank You to pcguru2000 For This Useful Post:
NoHaveMSG (06-06-2018)
Old 06-06-2018, 11:07 AM   #16884
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
My spacers arrived but I have to wait until my friend tells me I can go over to his place so we can install them
Zoid is offline   Reply With Quote
