Old 06-01-2018, 04:45 PM   #463
Richard_BRZ
Richard_BRZ's Avatar
Drives: 2017 WRB Subaru BRZ Sport-Tech
Originally Posted by Weigaldo View Post
Just in case you didn't know, you can flip the screen display. I would be worried about extra stress on the cord with that setup.
I know how to flip the orientation on the older tablets, but if that option still exists it’s not in the same menu location with V2 tablet. Unless you know something I don’t?!
Richard_BRZ is offline   Reply With Quote
Old 06-01-2018, 08:09 PM   #464
steve99
Drives: FT86
Nothing specisl needed just download the v4 tune for your car load to oft and flash
http://support.openflashtablet.com/support/home
Go to link above type in your ecu calid like ZA1JK00C or whatever yours is download tunes upload to oft woth openflashmanager and flash car
neilvosko (06-02-2018)
Old 06-02-2018, 11:17 AM   #465
Jasonb
Drives: 17 Series Yellow BRZ
My fueling was off a good deal on the 2017 K00C tune. Had to scale my MAF to get AFR to match the commanded AFR. I was running a but lean in open loop. You all might want to do a log and compare.
I'm also having to pull a little timing to redulce FLKC. Trying to do it with the IAT compensations. Will report results of that later.
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
DAEMANO (06-02-2018)
Old 06-02-2018, 01:03 PM   #466
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
Hi Steve,
quick sanity check, you uploaded a def file A01G in the original post that has additional tables compared to OTS 4.0 def, like Engine load, etc. so can we use your Def file instead, just change the A01G to our own cal id, ie F00C and make changes to engine loads, MAF scale per wayno, then save the new file and upload via OFT with no issues?
basically, using your def file (edited with our own cal ID in txt file) vs the one provided with OFT ?
thanks in advance,
neil
neilvosko is offline   Reply With Quote
Old 06-02-2018, 05:02 PM   #467
steve99
Drives: FT86
Originally Posted by neilvosko View Post
Hi Steve,
thanks in advance,
neil
yes should work
just check some tables to make sure all looks ok as per
http://www.ft86club.com/forums/showthread.php?t=79152
Old 06-03-2018, 01:42 AM   #468
babykwiss
Drives: Scion FRS
After flashing to v4 tune on my 18 BRZ, everywhere but the torque dip definitely feels much stronger than stock. The only issue I feel is that the torque dip feels much worse than stock. Has anyone else felt this way? I am running State 1 tune on 94 pump.
babykwiss is offline   Reply With Quote
Old 06-03-2018, 02:45 AM   #469
86HEART
Drives: 2015 asphalt FRS
Sorry i haven't read most of the new posts, but i have flashed the new tunes and goodness.... I cant believe you guys are doing so much for us. The cold start valve overlap removal and cold start on e85 makes me want to buy a v2 just to say thanks. I am in norcal so we haven't seen much cold weather since i flashed the new updates, but before i couldn't start on first try under 55ish. So far i have been down to 49 and fired right up. Also my neighbors thank you for the valve overlap fix. I tried a couple things but didnt want to get to far out there. I am almost catless (cnt midpipe with tiny HF cat, catless header) and it was a bit obnoxious before. Before the new tunes i had also went back to 91 since i couldnt start half the time. Now im burning corn juice and i almost dont remember until i smell it. I might buy a sticker just to rep. LOL. Sorry to sound so stupid but im pretty happy so far a month into running them.
86HEART is offline   Reply With Quote
Old 06-03-2018, 03:14 AM   #470
steve99
Drives: FT86
!og wahts going on and post it up here,might be able to see wahts going on
Old 06-03-2018, 10:39 AM   #471
babykwiss
Drives: Scion FRS
here is a data log.
https://datazap.me/u/babykwiss/data-...n?log=0&data=1
Old 06-03-2018, 10:52 AM   #472
tomm.brz
Drives: brz 2017 hksv2
Personally i would. Try maf scaling with vgi maf scaling tool, and try put higher timings at that rpm/load zone
Old 06-03-2018, 11:58 AM   #473
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
Originally Posted by Last Lemming Alive View Post
So let’s pretend I’m a moron (not huge stretch in this case) and you need to explain to me what I need to do to load V4 tunes. I know I have to download the file and load it up. But then I read you have to “change” something prior to install - I think. I have a 2017 so what ,if anything, do I need to do to update my V3 tune?
Ok. I loaded V4 last night without any issues. Compared to V3 it seems smoother and a bit more even in the power delivery, though total power seems on par with V3, but I’ll need to give it a few miles to be sure.
Last Lemming Alive is offline   Reply With Quote
Old 06-03-2018, 12:39 PM   #474
Jasonb
What tune are on? Stage 1, 2, or 2+?
V4 stage 2+ is much better than v3 on the 2017 manual cars. I feel like v3 basically was just there to turn the check engine light off. V4 makes quite a bit more power and is quite a bit smoother as well.
Old 06-03-2018, 02:26 PM   #475
Last Lemming Alive
V4 stage 2.
Old 06-03-2018, 04:00 PM   #476
Jasonb
V4 stage 2.
Catted header?
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
