Old 05-31-2018, 03:50 PM   #1
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
[OFT Question] Car Bunny Hops After Changing CAM Tables
So as title suggests, i changed the Intake and Exhaust CAM Tables on the Stg1 OTS at [.8 Load and up, 3700 and up] and noticed that after flashing it to the car, when i reach a certain RPM the car starts Bunny Hopping then stalls.
I know i reported this on a separate thread but that's for a different table. This time, i changed the base map without changing others.
Will add pics later if needed.
Subaru BRZ Sport Tech RS 2018
Instagram: @jedi_shifu
BuildThread: Click Here
Muchikori is offline   Reply With Quote
Old 05-31-2018, 05:00 PM   #2
tomm.brz
Drives: brz 2017 hksv2
Pics of what u modified
Did you touch engine load limits?
Old 05-31-2018, 06:19 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Logs would certainly be helpful.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-31-2018, 07:11 PM   #4
steve99
Drives: FT86
This sounds strange for just changing intake cam tables ie engine stalls.
Are you sure definitions are correct ? And you flashing correct tune, just seems weird like your ol/cl delay changes causeing stall. Did youback out all the other changes. Maybe start with fresh copy of tune
Old 05-31-2018, 07:59 PM   #5
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
here's a copy of what im using (ots as base, rev7 as the one with only cam changes, and definitions) i downloaded the definitions from oft for my ECU's version(ZA1JN10C) and made the changes there... would it be possible that rom raider v0.5.9 is the one screwing up the file?
I'll try again using a fresh copy
Old 05-31-2018, 08:00 PM   #6
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
Unfortunately i wasnt able to do any logging as i got scared the moment it bunny hopped.
Old 05-31-2018, 08:01 PM   #7
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
Please find attached the file with the changes ive done I tried to take pictures but it's crap. and no i did not touch the engine load limits
Old 06-01-2018, 12:52 PM   #8
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
Hi Guys,
I went and created my changes from scratch (OTS + Definitions newly downloaded) and unfortunately it's still happening
I made sure i made logs this time: https://datazap.me/u/muchikori/bunny...10-11-12-13-14
i hope you guys can help me with this
edit:
added my tune
Old 06-01-2018, 01:21 PM   #9
tomm.brz
Does the unmodified stage1 v4 Bunnyhops too or does it drive. Good
Old 06-01-2018, 01:21 PM   #10
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
It drives fine and no issues with it.
Old 06-01-2018, 01:34 PM   #11
tomm.brz
Are you sur3 you only have those defs on romraider?
Also dont understand why are you trying to do those strange things on closed/open switch an those unusual cam settings?
Old 06-01-2018, 01:59 PM   #12
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
Yeah only one definition is on my Rom Raider.
I just wanna make the car faster as these are some of the similar changes i did to my Mazda when i was tuning it. sorry iknow those are 2 differnet platforms.
Would you be able to give me advise as to which tables should i modify in order to squeeze out some power from a drop in filter + inlet tube?
Old 06-01-2018, 02:45 PM   #13
tomm.brz
Stage 1 are already wrtten to squeeze out more power from stock car stck exhaust header, i wouldnt modify the cam
I would just modify last value on the 2 engine load limits tables as i see my17+ tends to go higher than 1.3 and just try the map for some time
See if it knocks and how is the afr and ltft
Old 06-01-2018, 06:29 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
I wouldn't bother bar a bit of MAF scaling and as above. You're not going to gain more than a couple of HP max, nothing you'd notice.
.: Stealth 86 :.
Kodename 47 DJ:
Dash Cam: Hot Lava FR-S Hops Curb 3 times in Hit and Run gkubed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 03-26-2017 06:43 PM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 04:50 AM
Rocket Bunny V1 Question Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-14-2014 07:18 PM
Rocket Bunny Question rayted24 Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 01:31 AM
Hops Normal's White FR-S Hops Normal Member's Car Journals 8 01-06-2013 04:00 PM
