Old 05-30-2018, 07:53 PM   #29
staplesja
Drives: 2017 Subaru BRZ
@atomicalex thanks - I'll try to get the readings you suggest. I'll upload a hi-res image shortly of one of the defect areas.
staplesja is offline   Reply With Quote
The Following User Says Thank You to staplesja For This Useful Post:
strat61caster (05-30-2018)
Old 05-30-2018, 08:04 PM   #30
staplesja
@humfrx - I am very certain this is not malicious. The NATA test agent I'm speaking to did suggest we could do 'FDR' analysis on the back side of some of the paint that had flaked off to do chemical analysis. But he was more suggesting this to determine if residual oil or other substances were present at the time of manufacture / painting that may have caused poor adhesion. I don't want to spend a fortune on tests if I don't have to - so I don't intend to do this unless I really have to.
humfrz (05-31-2018)
Old 05-30-2018, 08:35 PM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I have similar 'defects'
I believe they are caused by bird shit (or other non-paint-friendly environmental debris) being allowed to sit on the paint for ~5 days based on my experience.
2-3 days gets you clear coat etching, I think after that it goes past the clear and destroys the paint underneath.
Here's a thread with someone else posting their paint and I've got a pic in there of mine as well:
http://www.ft86club.com/forums/showthread.php?t=116099
Edit: Best of luck to you, it's not fun having to constantly worry about the crappy paint on this thing and if you can get a respray then great for you and your car.
The more people that push on this the more likely Subieyota will step up.
ineedyourdiddly
Old 05-30-2018, 08:46 PM   #32
atomicalex
Drives: 2018 BRZ Limited Perf Pack
@strat61caster (cool name!) yours are likely from a chemical attack coming from the outside of the car. The eroded edges are what gives that away.
@staplesja The testing on the paint particles is actually critical for you. There are two tests. One looks at the back of the paint chips (FTIR) and the other looks at the cure behaviour of the chips (DMA). I personally think that your car got hit with some precured paint - crap from a poorly maintained spray bell or the ecoat line. A failure due to oil or other material on the body would be much splotchier and in very particular places. The clean edges and the condition of the edges indicates a big change in the material properties of the color coat (or ecoat, that is also possible and hard to tell without seeing the car personally). If it is ecoat cure residue, that is a huge issue and there are probably many cars affected. A poorly maintained spray bell, maybe one or two cars.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
The Following User Says Thank You to atomicalex For This Useful Post:
humfrz (05-31-2018)
Old 05-30-2018, 08:54 PM   #33
strat61caster
My car is not the red one, it is the gray one.
When the 'defects' are first discovered the edges are just as sharp as shown in the OP's high definition picture. I won't speculate further than saying mine would have looked nearly identical to the OP's when first created/noticed by me but I do understand where you're coming from.
ineedyourdiddly
atomicalex (05-30-2018)
Old 05-30-2018, 09:02 PM   #34
atomicalex
Dark grey? Yours could be a bunch of things, but the general area shape lends to bird crap. Which any modern paint should stand up to. Hell, my old Passat would be naked by now if it couldn't handle bird crap. The other option would be crap falling off jhooks on the ecoat line compromising the base adhesion, but that would have a more splattery shape.
I'm disappointed to see all of this. Modern pretreat and paint chemistry is pretty damn good when you do it right. And that is not rocket science!
www.atomicalex.com
Old 05-30-2018, 09:13 PM   #35
staplesja
I'll look into it (FTIR / DMA). Thanks a lot - really appreciate the comments.
Old 05-30-2018, 09:36 PM   #36
Originally Posted by staplesja View Post
I certainly think it's a defect.
Even if it is an 'outside influence' (and I realise this next question is difficult to answer) what should a consumer 'normally' expect from the product?
I.e. what should the paint be able to withstand w.r.t. bird liming etc. I repeat that I just can't accept that my car has so many severe defects spread all over the bonnet and roof after just 123 days and 1,200km. It seems totally ridiculous.
In terms of seagulls - no - I don't live near the coast. I'm in a region of Australia that does have possums; however, my wife has a new Mazda CX-5 and this is parked next to the BRZ in our driveway. Her car has no such damage - which suggests it's not some animal causing it as you would expect damage to both cars.
You should reasonably expect the paint to stay on the car even if birds crap on it! The rest of us have had pretty normal chips but that is not them.
Old 05-31-2018, 12:28 PM   #37
evomike
Drives: frs
bird poop or dead bugs on the paint? That will cause damage like your photos show.
Realized someone else said this but that’s definitely what it looks like.
evomike is offline   Reply With Quote
Old 05-31-2018, 12:30 PM   #38
evomike
Drives: frs
We’re also looking at pics of the damage right on top of it.
Old 05-31-2018, 01:35 PM   #39
I didn't catch your answer to my question as to whether this damage happened "overnight" or over an extended period of time …… ??
Old 06-03-2018, 11:23 PM   #40
staplesja
I can't be sure exactly when all of it happened; however, I noticed the bulk of it on the front bonnet after washing it in Jan. But a number of the other defects have appears subsequent to this but I can't be sure exactly when. Ta
humfrz (06-04-2018)
Paint defect FROM DAY OF DELIVERY! Raven_FR-S Issues | Warranty | Recalls / TSB 22 03-12-2015 09:46 PM
Paint expert opinion needed, paint defect or rocks? ducky369 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2015 03:54 AM
Paint chip or paint defect? please help. BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 11 01-16-2015 09:30 PM
factor paint defect, should i repair it or leave it alone? tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 03-30-2013 10:38 PM
Driveline Defect skoodge Issues | Warranty | Recalls / TSB 0 01-18-2013 12:16 AM
