Old 05-29-2018, 08:31 AM   #1065
ajc209
Drives: GT86 Cosworth
Originally Posted by botbs View Post
Great and thanks for your info. I have a set of Nankang AR1 and do plan to track the car. Did you install any other things to prevent oil starvation?
People on the forum said not to worry about it too much but I am not 100% sure.
Thanks!
http://www.ft86club.com/forums/showthread.php?t=63723
AR-1 are fairly grippy.
I have been using 235 AD08R and havent noticed on any UK circuit ive been to a problem with oil starvation.
However, I did recently fit the Cosworth Baffle plate as I may go for something more aggressive in the future.
I also fitted the Moroso piece of crap a few years back, it caused oil pressure drop when held above 6k rpms. I am very thankful I had my trusty Defi gauge so I could stop and save the engine.
IMO an oil pressure gauge should be the 1st mod to a car if you plan to modify the oil system in any way and do trackdays. All it take its an oil line popping off your oil cooler and the big end shell will die very quickly.
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
botbs (05-29-2018)
Old 05-29-2018, 11:10 PM   #1066
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
http://www.ft86club.com/forums/showp...&postcount=344
Sorry for digging up your old thread. I really like what you have done on the oil cooler. Few questions for you:
1) Do you still have the Mocal oil cooler on your car?
2) Any issues at all (ie: leaking)?
3) With the Cosworth Supercharger you have, any temperature issue on track?
4) Mind let me know where can I find all the required parts?
Oil cooler (160mm length, oil fitting and water fittin =?)
https://www.demon-tweeks.co.uk/motor...r-water-cooled
Sandwich Plate
https://www.mishimoto.com/m22-thermo...ich-plate.html
The PT Tuning kit is quite pricey.
Thanks
botbs is offline   Reply With Quote
Old 05-30-2018, 11:41 AM   #1067
ajc209
Sandwich Plate
Thanks
1) yes I do
2) The Mishimoto banjos started wheeping after they vibrated lose. I tightened them up and no issues in a couple years. Make sure you use cross check on them as a visual indication if they come loose. (same thing does for coilover top mounts, SC nose pulley ect)
3) The kit is designed for 400hp (1.2bar boost) so intake air temperature is really low on these kits in standard pulley form. Mines about +15C over ambient on track. I have graphs if you want to see them but I think I already posted them here.
4) I have a list here
http://www.gt86ownersclub.co.uk/foru...970_page4.html
botbs (05-30-2018)
Old 06-02-2018, 02:26 PM   #1068
aspen
Drives: Orange GT86
Part way through install of stage 2 kit. Having trouble squeezing the new radiator in as the bleed hose doesn't seem to have anywhere to go. Anyone have similar issues?
aspen is offline   Reply With Quote
Old 06-04-2018, 12:51 PM   #1069
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
RallySport Direct has a sale going on which includes the smaller pulley with the kit. Check it out!
https://www.rallysportdirect.com/par...ckage-w-ecutek
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
chaoskaze (06-06-2018)
Old 06-06-2018, 06:38 PM   #1070
botbs
botbs's Avatar
WHAT!
The Following User Says Thank You to botbs For This Useful Post:
weederr33 (06-06-2018)
Old 06-06-2018, 07:00 PM   #1071
weederr33
weederr33's Avatar
WHAT!
It's JUST out of my range. Such a great deal if you ask me!
botbs (06-09-2018)
Old 06-06-2018, 10:26 PM   #1072
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Interesting question I have is. Why don't these kits originally ship with the smaller pulley? It would make their kit seem more competitive vs others because the power would be higher.
Elliotw is offline   Reply With Quote
Old 06-06-2018, 10:48 PM   #1073
weederr33
weederr33's Avatar
The smaller pulley puts the power on the upper echelon for rod tolerance. Though they could handle it, Cosworth's more concerned with reliability than ultimate power. At least, that's my guess.
Old 06-09-2018, 01:45 PM   #1074
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Ordered the kit. Soon to have a 2.2 Cosworth.
sly is offline   Reply With Quote
The Following 2 Users Say Thank You to sly For This Useful Post:
Seba (06-10-2018), weederr33 (06-09-2018)
Old 06-17-2018, 12:03 AM   #1075
sly
sly's Avatar
OMG. @Matt@Cosworth. This is the BRZ they should have made. All props to you and Cosworth for making this kit.
Bravo.
I'll post some pics of the install and give a more detailed review later. There were some pros and cons with the install, but complete pros on the kit itself. Power feels completely linear, predictable and strong. The car feels "grown up" now. Like a European Tuner... Love it!
Old 06-17-2018, 12:10 AM   #1076
secho
secho's Avatar
Drives: GT86, forged and supercharged
Bravo.
Hey, I got the same feelings while installed mine. Now the car is excelent!
Odesláno z mého SM-G950F pomocí Tapatalk
secho is offline   Reply With Quote
Old 06-17-2018, 12:40 AM   #1077
sly
sly's Avatar
Yea, they completely redesigned the bracket that holds the reservoir and pump. Had to figure that one out on my own. Also, I think it would have been MUCH easier if I had removed the 3 bolts that hold on the AC compressor and moved it out of the way. That could have saved about an hour's work. Some of the coolant hoses do not match the install manual either. Some of them that were supposed to be "bent" were straight. Lot's of time was spent on getting all the hoses to route properly. Trial and error on getting everything to fit.
But enough of the negative. It looks totally professional. Feels awesome. Drives like a dream and was every bit worth it. Feel kind of privileged to have a Cosworth BRZ...
The Following User Says Thank You to sly For This Useful Post:
weederr33 (06-17-2018)
Old 06-17-2018, 11:54 AM   #1078
sly
sly's Avatar
Here's some pics of the bracket assembly for the coolant tank and pump. This wasn't included in the installation manual as it still mentions and old design. I actually like this design better. It mounts solid and looks very professional. No wire ties either...
There are 2 L shaped brackets. You will only use one of them depending on whether you have a left hand or right hand drive car.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
