Old 05-26-2018, 07:52 PM   #18971
Ashikabi
Ashikabi's Avatar
Originally Posted by Kestrel View Post
I call for the public execution of whomever approved the use of torx bolts for our seats.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Agreed. I think you can actually use a 12pt socket though. It's an E10 if it helps you
Old 05-26-2018, 07:57 PM   #18972
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Stripped 2 even with an E10. About to set the car on fire.
Kestrel is offline   Reply With Quote
Old 05-26-2018, 08:05 PM   #18973
Ashikabi
Ashikabi's Avatar
Get a good set of easy outs. Or you'll be welding a nut on them
Old 05-26-2018, 11:19 PM   #18974
Originally Posted by BigHugeFatGuy View Post
Ricer pinstripe. Because +10 hp.
Actually, I kinda like that, on your black car …..
BigHugeFatGuy (05-27-2018)
Old 05-26-2018, 11:29 PM   #18975
Kestrel !……..
The seats were NOT made to be taken out ……. that's the reason they used that odd-assed kind of bolt...….
Weren't nutten wrong with your seats …… now, were there …??
Old 05-27-2018, 01:40 PM   #18976
johan
Drives: '14 981CS, '99 NB1
They changed to a normal 6 point bolt in 2017. I think even Subaru realized the error of their ways.
When I needed to pull the seats on my 2015, I had to buy a 3/8" long handle breaker bar to use with the E10 socket. Then, with that, I was able to carefully remove them all.
johan is offline   Reply With Quote
Old 05-29-2018, 10:04 AM   #18977
KDad2
KDad2's Avatar
Drives: 2013 Raven
Installed a few parts of the holiday weekend: Verus non-aggressive rear diffuser, two-piece front splitter, race upgrade, and end plates, replaced my Invidia catless front pipe (not letting go) with a JDL ultra-quiet catted front pipe (heat wrapped too). Also, replaced a few under-panels that were damaged from road debris.
I'm so glad to get rid of the drone. It was starting to get old on long commutes to work. As far as the aerodynamic additions, there was a big noticeable difference in handling as the ride is a lot smoother now at higher speeds. Other things I worked on was removing old adhesive from wheel weights and rotated tires. Overall it was a productive weekend even though it was 175 degrees in the Texas heat in the shade with multiple fans running.
KDad2 is offline   Reply With Quote
The Following 7 Users Say Thank You to KDad2 For This Useful Post:
BirdTRD (05-29-2018), Cheeky (05-29-2018), MJones_RB (05-29-2018), RFB (05-29-2018), StraightOuttaCanadaEh (05-29-2018), Teseo (05-29-2018), zeal86 (05-29-2018)
Old 05-29-2018, 10:33 AM   #18978
PacManTheRS1.0
PacManTheRS1.0's Avatar
Drives: 2015 Scion FR-S Release Series 1.0
Had to get my fuel pump fixed because of a weird squeak/cricket noise after a week of ownership Also still trying to fix a rattle in the right rear of the car that I cannot figure out although it isn't too terrible, just rather annoying
"I am not designed to come second or third. I am designed to win." - Ayrton Senna
PacManTheRS1.0 is offline   Reply With Quote
Old 05-29-2018, 11:24 AM   #18979
Ashikabi
Ashikabi's Avatar
The crickets will return
Old 05-29-2018, 02:23 PM   #18980
PacManTheRS1.0
Is there no permanent fix? As in do all owners have this issue?
Old 05-29-2018, 02:40 PM   #18981
Ashikabi
Ashikabi's Avatar
It's a lottery. Some do, some don't. Some claim ethanol free gas fixes it. Some even added oil to their gas (I can't recommend that). It's annoying but I think it gives the car character too. It's the piston seal on the high pressure fuel pump that chirps. You'd think Toyota would have gotten that fixed by now
The Following User Says Thank You to Ashikabi For This Useful Post:
PacManTheRS1.0 (05-29-2018)
Old 05-29-2018, 02:56 PM   #18982
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
I agree and want one llol.
"Enjoying Performance because of it's nature not because of it's quantity''
TorontoNat is offline   Reply With Quote
The Following User Says Thank You to TorontoNat For This Useful Post:
humfrz (05-29-2018)
Old 05-29-2018, 03:22 PM   #18983
KDad2
KDad2's Avatar
Drives: 2013 Raven
When I was under my car this weekend I noticed lots of little pebbles poking through odd holes in various supports and braces, even one of my LCAs. I used a small flat head screwdriver and knocked them out. One other time I found a few hard pieces of dog food in the trunk and a 9mm shell casing. That took forever to find and annoyed my every turn. Anyways, these cars sound like a tin can, especially when there is a foreign object hidden somewhere.
Old 05-29-2018, 04:26 PM   #18984
TorontoNat
I had an annoying rattle in the rear as well. Realized it was just my license plate cover moving around one time when I was sitting in the car engine off on a windy day.
