#855 |
Still 17!
Drives: 2014 Silver BRZ Limited
Does anyone know where I can find a copy of a '14 BRZ auto ZA1JB00D original file. Mine is corrupted and I need to go to the dealer for 60K checkup.
Thanks for your help.
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
#856 |
Drives: GT86
Hello, i have an 2013GT86 and because it has ZA1JA00G in it, i wanted to uprgade for ZA1JA01G rom. Why? Because i dont have full definition for 00G but found full definition for 01G.
What i did? Downloaded my ZA1JA00G and save to srf, and if i try to save bin it writes something about need to erase some zero data, and the bin file is shorter, so it cant be edited in RR. When i write the ZA1JA01G file normally without issue, but the ignition was not able to turn off. I was scared, and reflashed it back to ZA1JA00G, and the Car is fine now. I made some changes to DBW, IGN, AFR and made some progress, gained few HP and Torg. But i want to play more, also with Cams etc... Did i done something wrong, or how can be the "upgrade" of firmaware done correctly ? For example EVO has Immo code it the rom, so it neads to be transfered in new rom..... but i didnt find anthing like in the GT86/BRZ rom. Thank you for any usefull info. |
#857 | |
Drives: FT86
Jist flash A01G to car, old ro will be completly erased no need to transfer anything |
#858 |
Drives: brz 2017 hksv2
is it possible to write a v4 ots rom (so patcher with launch control and ffs) edited with rom raider, with ecuflash?
#859 |
| The Following User Says Thank You to ermax For This Useful Post: | tomm.brz (05-14-2018) |
#860 |
Drives: '02 Speedster n°586 - '23 GR86
Thank you very much Steve for your work.
For anyone wondering, the ZA1JF10I (late 2015 italian AT) uses the same def as the Subaru counterpart ZA1JF20Q, and can be replaced with ZA1JA01I for logging purposes as per Steve post. I've attached to this post the original ROM in case anyone needs it. By the way, tonight I flashed a MY17 GT86 with my Tactrix and the ZA1JK00G OFTv4.03 ROM, and I've encountered a strange problem. After the first flash and two logs I decided to pull some timing and exhaust retard since it was knocking quite heavily. I proceeded with the second reflash, and after that the car refused to start, cranking repeatedly without firing up. So I reflashed the stock ROM, and after that no cranking at all, only DCT B1571 "Immobilizer key check NG" ![]() ![]() After losing 10 years of life in an hour, since the car is of a friend of mine, I performed the "ECU communication ID registration" (also described in the ECU replacement thread) and all is well now. Isn't that supposed to happen only when flashing an older rom to a MY17 or newer car? The rom and definitions used are attached to this post. First one worked, second one triggered security lock. Is that possible? The only thing I found is this, which states a "checksum fix" performed on that definition. Can a wrong checksum trigger the security lock? |
#861 | |
Drives: FT86
When flashing with tactrix always answer yes when it asks to crrect checksum |
#862 | |
![]() So I probably misclicked "no" at "correct checksum"? 99.99% I clicked "yes" because I saved the ROM again, then reopened it and didn't ask for any checksum correction before flash.. |
#863 |
To understand better what you did and try to help:
You flashed an unmodified v4 k00g to it so ecuflash defs must be good Did you then modify the rom with romraider or ecuflash? Is v4 RR def the one from Shiv? Where do v4 ecuflash def come from? Do they match 100%? Problem came out when you did modify the map so must be something def related |
#865 | |
Drives: FT86
If it was romraider modified or oft rom you would definitly need to correct checksum Else ecuflash will write rom to ecu with incorrect checksum calculated. This will cause ecu to think rom is corrupt and will not run the rom in ecu, hence car will not start. As the ecu would likly have only run the boot area then stopped, it likely caused the imobilisier\authentication unit to lock out hence you required the ecu resync to get car going again. Good to see its all sorted now |
#866 | |
ROM has been always modified with ROMRaider using Shiv's def from the same .zip. The ECUFlash def was converted with RR2EcuFlash.exe then adjusted manually (flash method subarubrz and SH72531). If you want to see ROMS and defs used that night there's a zip containing both in my previous message. Later I'll check if EcuFlash warnes me for the checksum or not.. P.s. are you from Forlì-Cesena??? ![]() EDIT: Now I feel like a dumb ass for not recognizing your nickname. We were side by side on Muraglione on Christmas Eve ![]() ![]() EDIT 2: I am an idiot. Note to self: do not flash cars past 1 AM.. ![]() I was comparing my A01G with the new K00G on my desktop PC and ended up saving the A01G with the wrong name. Then I moved it to my laptop where I have both defs and flashed without paying attention to that little detail in EcuFlash log. That's why it locked up. Sorry for the lost time, I assume that's a good reason to keep only one definition at a time in EcuFlash folder
#867 |
Drives: FT86
Yes ecuflash no check like ecutek or oft jist flasges whatever you tell it :-)
#868 |
Drives: 2017 Halo 86
This post just saved my ass. Thanks so much dude!!
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
