#15 | |
Drives: 2013 FRS
Bottom line for E85 to help it needs to be tuned and the easiest way is with a flex fuel kit..
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
| The Following User Says Thank You to shr133 For This Useful Post: | pcguru2000 (05-29-2018) |
#16 |
Drives: 2013 FRS
But if money is a problem it's safer to go to E85 and flash in a new map after it works it's way through the system, the problem is if you ever go back the other way the extra timing can break things, so you have to be careful.
If you are building your own maps bump up knock correction to pull more timing faster ( I bump this up anyway using pump gas) and don't get crazy with the timing. When you data log make sure to back timing down so there is no knock correction + a little(.5) to be safe with 91 or 93.. So build a really good base map than go to E85...
#17 | |
Drives: 2017 subaru brz
#18 |
Drives: 2013 frs red
#19 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
FWIW, the OBDLink MX monitor can display alcohol fuel percentage. I used to use mine all the time for oil temp, but I can't get oil pressure with it so, I'm going to a dual gauge.
#20 | |
Drives: FT86
NA car no real advantage past about E70 |
| Mixing Fuels With Different Octane | ShadowReaper | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 05-15-2018 05:08 PM |
| 100 Octane? | hellyvin | Northern California | 23 | 07-24-2017 08:01 PM |
| 93 Octane vs 91 Octane | keithgold | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 01-16-2014 10:16 AM |
| What Octane for the FR-S? | 914_WHITE_FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 07-13-2013 11:43 PM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 01:23 AM |
