Old 05-21-2018, 10:05 AM   #1
jslack
Drives: 2017 Red subaru BRZ Limited
quieter exhaust after stage 2 tune
Hi, group. I'm sure there are other threads out there on this topic, but got the stage 2 tune with UEL OFT catless headers and over pipe with stock mid pipe, (have a tanabe catless midpipe to, but had fitment issues), with the spec D catback. So basically very loud now. What good dual exhausts are out there that will tone down the raspiness and loud level to take advantage of the subaru rumble the headers are now creating.
jslack is offline   Reply With Quote
Old 05-21-2018, 12:04 PM   #2
Bkdshadow
Drives: 2013 Scion FRS
Invidia Q300 and CSG touring exhausts are supposedly pretty quiet.
Bkdshadow is offline   Reply With Quote
Old 05-21-2018, 01:12 PM   #3
jslack
thanks for the info. Anyone heard the Hooker blackheart catback too?
Old 05-21-2018, 02:11 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Even with the muffled version, your setup will still be quite loud.
tyler_win_photo is offline   Reply With Quote
Old 05-21-2018, 02:26 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Perrin or Milltek resonated systems are good options too
Old 05-21-2018, 02:59 PM   #6
Jasonb
Drives: 17 Series Yellow BRZ
The key is the front pipe. A catted front pipe, especially the stock front pipe will help keep things quieter. A good resonator in the mid pipe of course helps as well.
I'm running a catless JDL UEL header, and a Nameless muffled track pipe, which is a single exit axleback with a short muffler. With the stock front pipe and stock mid pipe it's not too bad at all. It's quiet when I want, and makes a good amount of noise when I want it to.
Jasonb is offline   Reply With Quote
Old 05-21-2018, 05:01 PM   #7
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
GReddy Supreme SP is a really quiet catback. Also, I don't know what version of OFT tune you're running, but I've heard a lot of people say once they switched to the new V4.03 tunes, their cars became noticeably quieter under load
NyX_Nick is offline   Reply With Quote
Old 05-21-2018, 05:16 PM   #8
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Thermal R&D catback is very civilized with the stock front pipe, and as someone said that is the key to keeping it tame. The helmholtz chamber in the Thermal exhaust keeps the car from droning.
Lincoln Logs is offline   Reply With Quote
Old 05-21-2018, 06:50 PM   #9
Whoodoo
Drives: '15 BRZ, Vortech supercharger
For what it's worth, my exhaust was a Tanabe catless UEL and over pipe, catless Tanabe front pipe, then a Tanabe concept G single exit cat back, so basically the only thing between the motor and the tailpipe was one resonator and one straight through muffler. My first step to making things quieter was to install a magnaflow catted and resonated front pipe, which didn't do a whole lot for WOT, but it really made a difference at low to part throttle. I can now drive through my neighborhood with a good conscience as long as I keep it below 2500 rpm.
I had contemplated doing a full custom cat back using the biggest offset in/dual out muffler I could find (dynomax 17577), but for a street driven daily driver I'm going the cheap and easy route and putting a stock cat back on.
In my experience with mufflers, size matters - bigger, in general, means quieter.
Whoodoo is offline   Reply With Quote
Old 05-21-2018, 07:16 PM   #10
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Yep that's the key. It you want full free flowing I had good success with the HKS dual resonated front pipe. JDL ultra quiet front pipe is another popular choice. Or just go back to stock front pipe
SuperTom is offline   Reply With Quote
Old 05-22-2018, 02:45 PM   #11
jslack
I'm running version 4.03 off the OFT. and it does seem to be quieter then stock. When I was running stage 1 before the header install, the tune really was noticeablly quieter. I've decided to leave the stock front pipe on and put the mid pipe up for sale.
Old 05-22-2018, 02:52 PM   #12
jslack
So Thermal R&D does a good job getting rid of the drone?? Sounds like my route i'm headed towards, That with the stock front pipe i hope it makes a good combo to offset the catless headers. And I'm all for as loud as possible, but the wife made it clear, it needs to get quieter.
Old 05-22-2018, 03:04 PM   #13
Lincoln Logs
The Thermal exhaust has ZERO drone with a catless header and stock front pipe. I was not expecting those results and it really smooths out the sound from the UEL header, to the point I actually like it. I am not typically a fan of the UEL sound either.
The video below I made is about aheader install but it has quite a bit of in cabin footage as well as outside of car driving footage with the exhaust.
[ame="https://www.youtube.com/watch?v=nq7cKc5_ALI"]Thermal R&D Exhaust With Header[/ame]
OFT Stage 2 UEL Tune Help jrchavar Software Tuning 3 11-21-2017 11:06 PM
Oft uel stage 2, 93 oct tune sroby Software Tuning 3 02-23-2017 12:48 AM
WTT: Invidia N1 for Quieter Exhaust (SC LOCAL ONLY) JW843 Want-To-Buy Requests 2 03-14-2016 03:39 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
