#393 |
Drives: 2015 Scion Frs Firestorm Red
Hey I'm pretty new to the tablet and tuning in general, as well as new to the v4 tunes compared to the v2 and confused about the advanced multiplier. I am currently running stage 2+ and after 15ish min of driving my AM stays at a solid 0.70. I am running shell 93 octane and everything else seems good across the board to me atleast. Tried searching the forums to see if anyone else doesnt notice a climb from 0.70 and if it's an issue that it stays there on 93 octane. Most people seem to see theirs climb to 1.00, thanks!
#394 | |
Drives: frs
#395 |
Sorry for the late reply, have been at work all day. Tried doing a couple pulls on a couple different sessions of driving tonight and the highest I got it to was 0.82 however it never went under the new set value. As it went up it stayed there, I have noticed the FLKC has gone to a maximum of 1.00 at some points but have seen .72 here and there while accelerating
#396 | |
Drives: 17 Series Yellow BRZ
#397 |
Drives: frs
#398 |
Thank you, to the both of you, for the information. I will try another gas station and see if my logging changes at all. I appreciate it, just want to keep this beast healthy
#399 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
When I'm cruising in the morning to work barely goes up sometimes to .84 in that range. After work I get on it a bit more plus its warmer out. Will eventually get to .94 - 1. Though outside temperature could have something to do with it but don't know what else determines where it goes to and how long it takes. Going to suck at the track when you turn off the car in between sessions and it will start all over again at .7 Would be much better if it could at least remember where it left off |
#400 | |
Drives: '15 BRZ RA
#401 |
Drives: brz 2017 hksv2
this is why you dont understand logic of advance multiplier.
it goes up when it doesnt sense knock during open loop higher load pulls, if you "cruise" in the morning trip to work and keep it low rpm low load it doesnt have a change to go up and anyway, knock correction A map (ignition advance in Ecutek) modify timing higher loads column anyway, so it doesn t change timing in the "cruise" zone ergo you don t even need the higher timing) as soon as you push harder, if it doesn t knock it goes higher and it s pretty obvious it s not convenient to go on track with a 0.7 IAM map but even if you do, few minutes and it goes up, if you have good fuel for that track day if you people can t understand how it works and why it could be convenient to have IAM at 0.7... DO NOT USE IT nobody is forcing you and nobody need your complaining just use other things |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Teseo (05-21-2018) |
#402 |
I have mine set to start at .9 on every startup since I always use 93 octane. I live in a community with a speed limit of 25 mph. The road my community is on is a 55 mph road. My IAM will go to 1.0 about 90 percent of the time before I even shift into 6th gear and reach 55 mph when I first pull out of my community.
#403 |
Drives: UK GT86
If it's like older Subarus then it will only advance the IAM when the advance table is greater than a certain value. Hence only at certain RPM/loads.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | tomm.brz (05-21-2018) |
#404 |
Exactly what I wanted to say, thanks for being specific
Normally one reach the >4.9 degrees cells on the ignition advance map during harder open loop pulls so if one just cruise to work in the morning with cold oil, IAM stays pretty there |
#405 | |
Drives: FT86
If the tuner knows your going to do that they can set IAM to 1 and run the tune at its most aggressive ignition timing at startup. Stock tunes are set up for the average person who maybe doesn't understand fuel types/grades and will dump in low octane fuel cause its cheaper. ie the manual says it will run on 95 so they use 95 ron cause it cheaper. Setting the IAM to 0.7 as in standard tune slows a bit more safety margin for people who may run lower octane fuels or countries where premium fuels are not widely available. In this way at each startup the tune is in a less aggressive mode until the ecu detects minimal knock and will advance timing via IAM during driving. It also makes it easier to do consistent dyno runs as you dont have the iam resetting to 0.7 each time you switch off car or reflash, save you having to do several runs to get iam to 1 |
#406 |
Best thing to do if you're using 93 is to just set it to start at .9. Still safer than starting at 1, but should go to 1 pretty quickly.
| The Following User Says Thank You to Jasonb For This Useful Post: | SuperTom (05-22-2018) |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
