#15 |
Weight Weenie
Drives: 15 FR-S
#16 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#17 | |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | new2subaru (05-17-2018) |
#18 | |
2k rpm punch is at .01 bar basically 0psi .8 seconds later 2.5K rpm 1.3psi .8 seconds later 3k rpm 3.5psi .8 seconds later 3.5k rpm 5.8psi .7 seconds later 4K rpm 8.4psi .5 seconds later 3.9k rpm 10psi I had a difficult decision when boosting my car. Both had advantages disadvantages. I leaned toward the more reliable system and went turbo. Both systems if properly installed the one with less moving parts will be more reliable. I will stick with my hot laggy turbo! |
#19 |
My GReddy builds boost quickly enough that quick blips for heel-toe downshifts build boost. I can have full boost before 3000 rpms regardless of conditions. Unfortunately an inertial dyno will not be able to show this, as loaded driving conditions and dynos are not quite the same.
#20 |
Edelbrock dyno
![]() 2017 BRZ, Standard pulley, delicious tune, stock header, stock fp, CSG Touring 86 exhaust, Delicious FF kit. low line = 91 high line = e70 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Grady (05-18-2018), Irace86.2.0 (05-17-2018) |
#21 |
GReddy dyno
![]() 2017 BRZ, GReddy T518Z turbo, CSG ceramic, stock header, stock exhaust, Delicious FF kit, Delicious boost controller. Green line = wastegate 91 (5.5 psi at peak power) Pink line = wastegate E70 (5.5 psi at peak power) Orange line = high boost E70 (10.5 psi at peak power) |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Grady (05-18-2018), new2subaru (05-17-2018) |
#22 | |
Also, even the complete box is not 115 lbs. I can move one around by myself fairly easily, and I'm not exactly a big guy. |
#23 |
Much cooler video of the GReddy turbo in action, than what I can do.
[ame]https://www.youtube.com/watch?v=HeMJugzbDU4[/ame] The GReddy car in Japan still uses a FA20 and a turbo kit; the USDM drift car currently has a 2JZ. |
#24 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#25 | |
Manifold + SC = 46.2 lbs Radiator = 4.8 lbs Misc = 10.8 lbs ---------------------------- Total = 61.8 lbs Things to note: --The weight above does not include coolant, so the total would be higher. --The weight above does include items that replace other items like the air filter, the posterior of the air box, the manifold, etc, so the total would be lower. --The weight above doesn't consider other deletes like the sound tube, so the total weight would be lower. Conclusion and Comments: The weight is far from 120-140lbs, but it is probably more than a turbo kit and would raise the COG slightly (the Harrop SC clears several strut tower braces). On another note, a turbo adds more weight in front of the wheels than these superchargers. Also, the total weight could be corrected for with a light weight battery, some aluminum centered rotors and forged calipers when doing a BBK, spare tire removal, etc. if someone was worried about the extra weight. |
#26 |
Drives: blue - Cosworth SC stage 3.0
Our kit is about 31Kg
so 68lbs if thats any help but as Irace says you also get a bit back from removing the existing inlet ( 2kg?) to be honest this is a 1200kg car so 31 kg is only 2.5% in mass change you'd do well to notice that compared to the extra 80-100bhp you'll get with it |
| The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post: | CSG Mike (05-18-2018), Irace86.2.0 (05-18-2018) |
#27 |
86 Member
That's still too much weight for my liking plus the CoG issue on a car that Toyota touted so much about. I'd rather gain 20+ lbs without stacking that weight high because it came with 140hp/140tq.
#28 | |
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA | bren5279 | Engine, Exhaust, Bolt-Ons | 69 | 06-29-2015 10:56 PM |
| fs feeler full blown turbo kit minus turbo | kingkai23 | Engine, Exhaust, Bolt-Ons | 10 | 03-11-2014 02:59 PM |
