#379 |
Drives: 2013 Raven FR-S
Why did you want the loud cold start back? All it does is heat up the catalytic converter faster for emissions purposes. I'm pretty sure my neighbors were glad to see it disappear on my car. lol
| The Following User Says Thank You to smg1138 For This Useful Post: | SuperTom (05-07-2018) |
#381 |
Spun
Drives: 23' Supra
#382 |
Drives: brz 2017 hksv2
#383 |
Drives: BRZ Ts
OTS Maps for ZA1JN10C (MY2018 US 6MT); v4.03
Created by: Anthony Cardinale for Shiv Pathak Modified on: Sat, 5 May, 2018 at 8:13 PM New v4.03 beta tunes now available for all USDM GT86s (including 2017+). They now have Launch Control and Flat-Foot-Shift (these features will need to be setup/adjusted at home)! *** NOOB ALERT *** Hi there, i'm also a Ts 2018 owner, and was able to sucessfully push in stage 1 map. Only thing i dont get right is where i can adjust or activate launch control and flat foot shift. Does it have to be ''activated'' trough romraider or it's possible via the OFT itselft? Sorry if it's been asked millions of times, but i wasn't able to get a clear answer going trough the ''search'' option on the site... |
| The Following User Says Thank You to chromes For This Useful Post: | SkyeHack (05-11-2018) |
#384 | |
Drives: 17 Series Yellow BRZ
launch control will work by default, it'll just be set way higher than it should be. |
#385 |
#386 |
Drives: GT86
It's a negative offset to the rpm fuel cut limit. OTS default is 7500 or 7600. So if you want your launch control to limit at about 2500 rpm just insert 5000 into the launch control table.
#387 |
Drives: MY20 Hakone Toyota 86
MY17 AT K00D E85 tune here. I've noticed that my rpms spike for a sec on a cold start when putting the car in gear. This causes an ever so slight jerk despite my foot on the brake. I suspect it's the multitude of "idle speed target" maps not matching and picking a different rpm once in gear.
Which of the 9 "idle speed target" maps are for what conditions and are they safe to modify? With cold start removed do they even need to be anything other than 700 across the board or is the higher rpms just for getting the engine up to temp? My intent is to make the maps for base start and in gear match so that there isn't a spike at cold start. |
#388 |
i dont think anyone knows which idle maps works at a spec time..usually you could put them all the same to have a standard controlled behaviour
#389 | |
Drives: FT86
Check the MAF OFFSET AFTER START tables are same ie the in gear and in neutral tables are same |
| The Following User Says Thank You to steve99 For This Useful Post: | redhalo (05-17-2018) |
#390 | |
Drives: 2014 BRZ
I put those all back to stock
#391 |
I do believe you are on to something here. I checked this morning and with a cold start my rpm's jump to 2000 and back down when I put it in gear. None of my idle maps go any higher than 1200 and my MAF correction maps do not match. I'm assuming copying IN GEAR over NEUTRAL would be fine.
#392 | |
Drives: FT86
yes |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
