Old 05-14-2018, 10:40 PM   #1219
imhereforthecar
Drives: FRS
45mm
imhereforthecar is offline   Reply With Quote
Old 05-14-2018, 10:42 PM   #1220
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
Originally Posted by imhereforthecar View Post
45mm
I would assume unless you get a 5mm spacer you might be at your max camber.
JakeRogue is offline   Reply With Quote
Old 05-14-2018, 10:56 PM   #1221
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Shouldn't matter. The hub defines the camber and won't be different between wheels (unless one rubs the shock, then it limits the angle one can dial in of course). But whether 40 or 45, they both clear with the spec tires, so should be able to get more.
Be sure that you loosen the top and bottom, and make sure the tops are pushed all the way inboard (there's some slack in there).
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 05-14-2018, 10:57 PM   #1222
JakeRogue
JakeRogue's Avatar
--kC
Ima defer to this man’s judgment. I was just assuming.
Old 05-14-2018, 10:59 PM   #1223
blkwrxwag
Drives: DS FRS
I bet they don't have the SPC bolt orientated correctly.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 05-14-2018, 11:21 PM   #1224
imhereforthecar
Drives: FRS
I checked after their first attempt (I mistakenly didnt put the crash bolts in the top hole when I first gave it to them), and the tab is facing out towards the wheel, so I think that's right.
Old 05-14-2018, 11:21 PM   #1225
Bitters
Drives: Searching for next
so trying to do some tire forecasting for the Packwood tour... if I have 110 or so laps on the Falkens come Packwood, am I bringing pretty cooked tires to a bigger show? Or are these tires going to give their best laps until their gone?
Bitters is offline   Reply With Quote
Old 05-15-2018, 04:16 AM   #1226
tony_r
tony_r's Avatar
Drives: '15 STX
Alignment: time for a new race shop.
Tires: should be fine if your locations are asphalt or light on tire wear.
tony_r is offline   Reply With Quote
Old 05-15-2018, 11:05 AM   #1227
Bitters
When did you start finding performance fall off? Locally we are mainly on asphalt, and I think Packwood is asphalt as well (you guys will know more than me there obviously)
Old 05-15-2018, 11:38 AM   #1228
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
--kC
It's easy to check this visually. I just slide my phone in the wheel well and get a picture.
This is -3 degrees with a 40mm offset.
Twinz is offline   Reply With Quote
Old 05-15-2018, 12:58 PM   #1229
tony_r
tony_r's Avatar
Drives: '15 STX
I didn't, but I also went through 1 1/2 sets of tires within 3 months or so. The first set was toast because it was out of tread, not usable rubber. I'm not sure when they heat cycle out but it felt consistent in what it was going to give so it's not very noticeable if or when it falls off. My guess is that they start to feel like a sticker set at the end of their life.
Old 05-15-2018, 02:15 PM   #1230
Open Loop
2013 FR-S Whiteout / SSC
--kC
I think that the 40 or 45 mm offset should matter. If the inner rim is farther away from the spring assembly as a result of the lower offset (40), you should be able to get more negative camber before it rubs.
Open Loop is offline   Reply With Quote
Old 05-15-2018, 04:42 PM   #1231
bholliday
Drives: 2022 BRZ Premium
A 5mm spacer should give approximately 0.9 degrees of extra camber (i.e. acos(5mm/12.5inch)=89.1 degree).
bholliday is offline   Reply With Quote
The Following User Says Thank You to bholliday For This Useful Post:
Open Loop (05-15-2018)
Old 05-15-2018, 05:09 PM   #1232
snoxracer183
Drives: 2014 FR-S SSC
I am only seeing 2.6-2.8 camber with everything maxed out as well. We've checked orientation of everything multiple times, tire/wheel clearance to the strut looks like the above picture. I think there is some "wiggle room" in alignment machines in measuring camber. How good is the machine, how old is it, how is it calibrated etc is going to determine what your final number can be. If you are about 1/8" away from the spring perch you should have just as much camber as the rest of the builds.
-Eric K - Milwaukee Region SCCA - 2014 FR-S
snoxracer183 is offline   Reply With Quote
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
