Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
04-23-2018, 09:37 PM | #15 |
Only users lose drugs.
Drives: All the time
Then use it. Maybe you'll get lucky.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
04-24-2018, 09:21 AM | #16 |
Drives: 2013 Firestorm FR-S
The GL-5 that I bolded and quoted is specifically in the "Manual Transmission" section that discusses fluids. The Differential fluid is a different section.
04-24-2018, 10:11 AM | #17 |
I realize that, and unless Subaru/Toyota/Aisin did something different in the transmission starting that year, I'd be willing to bet it's an error. Even buffered GL5 extreme pressure additives won't protect the friction cone area of a syncro.
05-06-2018, 05:39 PM | #18 |
Drives: 2016 Cosworth 2.2 BRZ
parts.subaru.com lists every part for the 2016 and 2017 manual transmission as identical. I can find no difference between the transmissions.
Either the manual is in error and you shouldn't use GL5 in the transmission or you can use it in any model year. There is nothing special about the 2017 that makes it able to use GL5. |
The Following User Says Thank You to sly For This Useful Post: | venturaII (05-07-2018) |
05-07-2018, 11:05 AM | #19 |
Drives: 2013 WRB BRZ 6MT
From the Subaru manual:
"• Other gear oil that meets API GL-3 or upper grade and SAE 75W-90 specifications" If you ask Subaru for fluid, they will give you the same GL5 based fluid for the Trans and the diff for a MY13 car. |
05-12-2018, 01:45 PM | #20 |
Drives: DGM BRZ Limited
Gear oils have seen declines in sulfur content since the 90s and many have been used in transmissions like ours without issue. Molybdenum disulfide is the high pressure additive used iirc. Sulfur is corrosive to brass.
Not all gl4 work great for brass synchro either. Best to find a gear oil specifically designed for high performance with brass. Too slippery and gears will grind. Shifts will be stiff. Too abrasive and you'll wear synchro prematurely. Do people try using BMW mt fluid? Or porsche? |
Similar Threads | ||||
My trans oil 2nd gear problem - SOLVED! | brzstiz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 10-23-2018 12:48 PM |
Engine/Trans noise whie in gear | Madmax516 | Issues | Warranty | Recalls / TSB | 2 | 08-02-2016 07:23 PM |
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 07-03-2014 08:06 PM |
Trans & Gear Oil Package in stock+ free ship | Esoteric | Mechanical Maintenance and Tools | 10 | 05-02-2013 08:27 PM |
Got a line on two unclaimed BRZs (manual trans) | Tainen | BRZ First-Gen (2012+) -- General Topics | 0 | 07-05-2012 10:40 PM |
