Old 05-11-2018, 06:12 PM   #15
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
@Subsonic, don't like tcoat's post at the same time as me. Tcoast's like belong to me.
The Following 2 Users Say Thank You to chaoskaze For This Useful Post:
Subsonic (05-11-2018), Tcoat (05-11-2018)
Old 05-11-2018, 06:26 PM   #16
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Originally Posted by nikitopo View Post
I've done this logging twice. The difference was in the range of .01 sec.
you are the one trying to prove this, just get a stock one and run the exact same test. hell grab a fluiddamper too since that one is heavier and they claim more hp too. No one is going to have your exact car setup, so your data is only useful to you.
G-Man is offline   Reply With Quote
Old 05-11-2018, 06:33 PM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My offer to calculate gains/losses from inertia still applies. Just need stock and your choice of aftermarket diameters and weights.
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (05-11-2018)
Old 05-11-2018, 06:40 PM   #18
I offer to check Spuds' math.
Spuds (05-11-2018)
Old 05-12-2018, 02:00 AM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
@Tcoat The calibration records of my foot?
If you check the posted Ecutek logs there isn't any change in the "Accelerator Angle (%)" value. It is always 100%. I started pressing the gas pedal from a smaller speed. Your arguments are even more laughable and the same test is very easily reproducable. It is a plain 2nd gear pull. So, waiting for results ...
Old 05-12-2018, 02:41 AM   #20
I've done this logging twice. The difference was in the range of .01 sec. If the road is level why to have a difference? Diff ratio will give an advantage to the other car, but we know how it works. It is a torque multiplier. If you 're trying to ridiculate the comparison, then you should ridiculate all the 40-60, 60-80 etc. results that manufacturers provide for their cars. It is not a car launch comparison that is also dependent with the way you launch. It is an acceleration test on rolling speed and with a fixed gear.
We are not trying to prove here how much the gains are, but if there are in general any gains at all. If not even a single person doesn't want to post a result (even for a stock car), then it means that you are just hiding behind your finger and for me the topic is closed. From now on I'll discuss if someone post times. Anyone?
Well, nikitopo, I for one, don't have a method of measuring this parameter, so, I can't participate in your experiment. I am not hiding behind my finger ...
nikitopo (05-12-2018)
Old 05-12-2018, 03:29 AM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Ok guys.
It looks that no one will post a result for comparison. So, I used the log file as an input to the Virtual Dyno app. I changed the tire diameter to my value, the fd ratio to a 3.727 value and changed the car weight to what you have normally in US (std weight of Limited MT model). Here is the output with an additional 80kg driver and the standard smoothing factor:
Anyone can cross-check the results with the attached Ecutek log file of my first post.
Result is 194 whp
Old 05-12-2018, 04:33 AM   #22
tomm.brz
Drives: brz 2017 hksv2
the day you do a real dyno and prove to us your car put dkwn 194 hp at the wheel i guess i ll get down on my knees and excuse me to you for when i doubted
anyway, assuming i m ignorant, why does thes weight matter in a power calculation? your car could weight 3 tons, it doesnt change the torque that reaches the whell
or you want to say that this power...is a "perceived" one?
but well i have no idea how this virtuak dyno works
wparsons (05-12-2018)
Old 05-12-2018, 05:36 AM   #23
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The way virtual dyno works is by calculating acceleration based on RPM per time data. It needs to include the gear ratios and final drive information, the tire diameter, the drag coefficient and the frontal area information. The last two are already known for BRZ and are included in the setup files. The car weight is needed to calculate the whp value. The result is after using a DynoJet correction factor. It is known to be pretty accurate. In general, it is not real whp for my car. It is like saying, you would need 194 whp on a 2798 lbs car with same gearing to achieve the same acceleration figures.
Old 05-12-2018, 05:41 AM   #24
tomm.brz
so not even catless stage2 cars with e85 have 194whp and you think is accurate? interesting
Old 05-12-2018, 05:50 AM   #25
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
@Tor has used it in the past very extensively. He can share more information about accuracy.
Old 05-12-2018, 05:57 AM   #26
tomm.brz
ok.
but in a logic way, you really are convinced your Cosworth canned Stage1 car with 2 cats and stock header, can do 194 whp, when not even proper tuned E85 cars do it?
just for info
FT86Z (05-12-2018)
Old 05-12-2018, 07:54 AM   #27
Lantanafrs2
Drives: 2013 frs red
Oh my God
Lantanafrs2 is offline   Reply With Quote
The Following 4 Users Say Thank You to Lantanafrs2 For This Useful Post:
scottman (05-12-2018), Tcoat (05-12-2018), Ultramaroon (05-12-2018), weederr33 (05-12-2018)
Old 05-12-2018, 08:00 AM   #28
tomm.brz
nikitopo if you put 4.55 cusco fd how much will you car fly to? 240whp? 285bhp "perceived"?
Basic/Easy/Cheap mods? Lakitu Scion FR-S / Toyota 86 GT86 General Forum 75 02-08-2017 03:08 PM
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) — General Topics 104 10-10-2016 12:45 PM
Basic Mods jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 05-09-2016 03:00 PM
2013 Scion FR-S(basic mods) $19,500 RavenFR-Sowner Cars for Sale/Trade 0 09-14-2015 11:46 AM
