Old 05-03-2018, 07:37 PM   #309
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by slyphen View Post
I got them from CSG. they came in aluminum, i just painted them red with metallic spray paint.
Do you happen to know what size they are?
I'm looking at picking some up, and I believe this is the right size. Just wanted to check.
https://www.counterspacegarage.com/h...3-to-56-subaru
mistople is offline   Reply With Quote
Old 05-04-2018, 08:11 AM   #310
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The size you need for Wedssport TC105N on a BRZ/FR-S/86 is 65 to 56.1 because Wedssport 5x100 wheels have hub diameter of 65mm not the typical 73mm. I got mine from CSG also
https://www.counterspacegarage.com/h...5-to-56-subaru
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
mistople (05-04-2018)
Old 05-05-2018, 02:22 AM   #311
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
BRZ hub diameter is 56.1mm, depending on the wheel, in TC105N's case its 65mm for the 5x100 bolt pattern. so you need a hub ring for 56 - 65mm.
slyphen is offline   Reply With Quote
The Following User Says Thank You to slyphen For This Useful Post:
mistople (05-22-2018)
Old 05-05-2018, 08:03 AM   #312
Apoc
Apoc's Avatar
BRZ hub diameter is 56.1mm, depending on the wheel, in TC105N's case its 73mm. so you need a hub ring for 56 - 73mm.
My TC105Ns must be defective since I have 65mm-56.1. or maybe this spec sheet is fake
http://nebula.wsimg.com/e9d732f621d5...&alloworigin=1
“The World is Flat”
[||•]=(86)=[•||]
Old 05-05-2018, 10:43 AM   #313
mistople
mistople's Avatar
I’ll dig a wheel out of storage to measure. Thanks for the doc!
Old 05-06-2018, 04:11 AM   #314
slyphen
Drives: Man
my mistake, i was looking at the wrong bolt pattern. it appears the non-5x100 pattern are all 73mm. i forgot what i got for a sec. looking back into my emails, yes it was indeed 65mm.
The Following 2 Users Say Thank You to slyphen For This Useful Post:
Apoc (05-06-2018), mistople (05-22-2018)
Old 05-07-2018, 02:16 AM   #315
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
my side shot from this weekend.
spicyricecake is offline   Reply With Quote
The Following 2 Users Say Thank You to spicyricecake For This Useful Post:
JMon85 (05-09-2018), Vic4uf (05-09-2018)
Old 05-09-2018, 11:15 AM   #316
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Is that Titan or Hypersilver?
SG02WRX is offline   Reply With Quote
Old 05-09-2018, 11:30 AM   #317
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
That looks to be TS (Titan Silver)
Kami Speed is offline   Reply With Quote
The Following User Says Thank You to Kami Speed For This Useful Post:
SG02WRX (05-09-2018)
Old 05-09-2018, 01:37 PM   #318
spicyricecake
it is TS.
Old 05-11-2018, 05:17 PM   #319
86raus
86raus's Avatar
Drives: 2017 blue toyota 76
18x8 on stock suspension, I wish they made a 18x9.5 option
Sent from my SM-G955F using Tapatalk
86raus is offline   Reply With Quote
Old 05-11-2018, 06:54 PM   #320
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Agreed! It looks kind of convex to me. Concave ftw!
SUB-FT86 is offline   Reply With Quote
Old 05-11-2018, 11:10 PM   #321
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
DuMa is offline   Reply With Quote
Old 05-12-2018, 12:00 AM   #322
spicyricecake
The Following 3 Users Say Thank You to spicyricecake For This Useful Post:
beltax90 (12-30-2019), JMon85 (05-22-2018), tigermack (05-13-2018)
dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport
Wedssport TC105N 17x9+25 5x100 YDNA Wheels and Tires 24 04-04-2014 01:05 PM
FS: Wedssport TC105n 17x9 +25 donutfilling Wheels and Tires 19 03-26-2014 06:59 PM
Wedssport TC105N 17x9 and 17x8 donutfilling Wheels and Tires 9 09-27-2013 04:04 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
